It's difficult to mimic reverse clicky with forward clicky switch, mostly you can do only simple operations.
L4P, are you going to sell the Luxeon V2?
I’ve noticed it’s in stock on Digikey and Mouser.
L4P, are you going to sell the Luxeon V2? I’ve noticed it’s in stock on Digikey and Mouser.
Maybe later, reels of V2 have 2500pcs, not the usual 1000pc.
Osram KW CSLPM1.TG (2mm2) is available now:
https://led4power.com/product-category/leds1/osram/
Kills XP-G2 in throw, while having 1500lm+ output, which is great for factory undomed 2mm2 LED with pure white tint. Vf is ridiculously low, 3V@3A,3.13V@5A,3.3V@8,5A.
The 3rd best bin this time.
Can’t wait for more precise results to know what the 1500+ actually is. Q8WP was just as throwy as Black Flat. This one would need about 1900 to compete with White Flat.
That Vf is truly extreme.
kikkoman:L4P, are you going to sell the Luxeon V2? I’ve noticed it’s in stock on Digikey and Mouser.
My error, Mouser doesn’t stock it yet, but Digikey offers the following quantities (L1V2-4070000000000):
- 1000 $0.8464
- 500 $0.8667
- 250 $0.9750
- 100 $1.0834
- 25 $1.2460
- 10 $1.6790
- 1 $1.9000
MascaratumB: contactcr:LOL. Glad I wasn’t the only one. Maybe L4P can update the description for us and create a “discount” pricing tier
Yup, adding a 2 x “6mmx0,5mm” would be more elucidating I have one doubt about the LD-A4! I am using mine with a foward clicky switch on the OTR M1! I have it configured with Moonlight + 3 modes, with the 2x clicks for Turbo. However, when I double click it (half press as it is a FC switch), it doesn’t assume the “go to turbo” most of the times! Also, sometimes I have to click 2 times after being on “momentary” moonlight so that it goes to turbo. Maybe this is related to being a FC instead of a reverse clicky switch?! But another strange thing happens! Imagining I am on mode 2 (low, after moonlight) and I double click (half press), it will go to mode 4 (turbo) but it always take a bit longer on the mode 3; meaning, from modes 2 to 4, it always passes and “waits” on mode 3 to slightly step up to 4… This happens both with FC and RC switches. Is this normal? Or can it be related to some bad installation I might have done? Thanks and sorry for the confusing questions
It’s difficult to mimic reverse clicky with forward clicky switch, mostly you can do only simple operations.
Thanks for the answer mate! My suspicions were correct! I will probably get more but to use with RC switches!
About this, and sorry for the dumb question, does it mean that using this led above 3A will not produce a) so much heat and b) so much battery drain?
I am planning to use one in a 16340 flashlight with a LD-A4 driver, but I’d like to know if it will be better to use it with a 2A-3A or 4A-6A driver!
Thanks in advance :+1:
Hi,
would the combination of MOSLED EXTREME ( MosX ) Ceramic Insulation XP 3535 MCPCB work with the OSRAM KW CSLPM1.TG – 2mm2 LED soldered to it?
Thinking about upgrading my XP-L Hi Convoy C8.
led4power: MascaratumB: contactcr:LOL. Glad I wasn’t the only one. Maybe L4P can update the description for us and create a “discount” pricing tier
led4power:Osram KW CSLPM1.TG (2mm2) is available now:
I am planning to use one in a 16340 flashlight with a LD-A4 driver, but I’d like to know if it will be better to use it with a 2A-3A or 4A-6A driver!Thanks in advance :+1:
With a linear driver like LD-A4 Vf doesn’t affect heat/battery drain but only how long will it run before output starts dropping. With a buck driver it would be more efficient.
MascaratumB: led4power: MascaratumB: contactcr:LOL. Glad I wasn’t the only one. Maybe L4P can update the description for us and create a “discount” pricing tier
Thanks for the answer Agro! Getting a buck driver with a nice UI as the L4P drivers is something I don’t see as possible currently, so…maybe I should stick withe 3A driver to avoid major drops. I believe this LED will give a nice throw under a zoomie lens !
Thanks again !!
Is there any 16340 capable of 6A?
MascaratumB:About this, and sorry for the dumb question, does it mean that using this led above 3A will not produce a) so much heat and b) so much battery drain?
I am planning to use one in a 16340 flashlight with a LD-A4 driver, but I’d like to know if it will be better to use it with a 2A-3A or 4A-6A driver!Is there any 16340 capable of 6A?
Currently available I guess not! There is/was the AWT IMR16340 15C but those are hard to find!
Most of the cells handle 3A but not much above it :zipper_mouth_face:
g_damian: MascaratumB:About this, and sorry for the dumb question, does it mean that using this led above 3A will not produce a) so much heat and b) so much battery drain?
I recently asked Vapcell about a high current 16340 and after some discussion how that would sell (the 16340 format is hardly used in vaping so it would just sell for flashlights) Dennis from Vapcell promised to look into it. The AW 16340 15C from years ago (tested by HKJ) proved that a high current 16340 is well possible.
MascaratumB: g_damian: MascaratumB:About this, and sorry for the dumb question, does it mean that using this led above 3A will not produce a) so much heat and b) so much battery drain?
Most of the cells handle 3A but not much above it :zipper_mouth_face:I recently asked Vapcell about a high current 16340 and after some discussion how that would sell (the 16340 format is hardly used in vaping so it would just sell for flashlights) Dennis from Vapcell promised to look into it. The AW 16340 15C from years ago (tested by HKJ) proved that a high current 16340 is well possible.
Yup, I noticed that in the thread
The only issue is that the 15C is very difficult to get (at a good price at least)! I really hope they can get it done, would be a fresh air in the 16340 flashlights!
Btw, I ordered some of these KW CSLPM1.TG leds, really curious how they do in some of my lights
I’m interested to see the results
But I’ll probably not buy them myself though, I would rather wait for the larger CULPM1.TG for better cooling and more lux.
Hi, would the combination of “MOSLED EXTREME ( MosX ) Ceramic Insulation XP 3535 MCPCB”:led4power work with the "OSRAM KW CSLPM1.TG – 2mm2 ":https://led4power.com/product/osram-kw-cslpm1-tg-2mm2-throw-bare/ LED soldered to it? Thinking about upgrading my XP-L Hi Convoy C8.
Hi,I didn't test new Osram leds on mosX 20mm pcb, but I guess it would start to loose performance at >4Amps due to high power density. You could use standard Cu DTP and well cooled LD-A4.
MZ leds - next week 100%
18,24,30Amp drivers, FET switch,spacersnext week 95%
I did not found the spacers for the C8 and FET Switch is not for sale now.
Due to larger number of orders and some other projects that I must finish, those stuff is unfortunately postponed.
At least I have ordered my 3 Q8 MCPCBs yesterday.
I hope some others will order them too and you will get your invest back.
