Any test result of the throw ?
Ordered, now just waiting…
My FT02 prototype has close to 700m throw (120Kcd+). You can expect higher readings for retail version, as FT02 undergo driver upgrade and better polishing for its reflector.
Will they change the battery compartment to support flat top 21700 batteries before they start to ship the orders?
Maukka and manufacturer do not have problem using their Samsung flat top. However, my stock LiShen unprotected 21700 will not work with this light because of the size of anode connector is too big for the opening.
Manufacturer will look into this issue.
freeme:My FT02 prototype has close to 700m throw (120Kcd+). You can expect higher readings for retail version, as FT02 undergo driver upgrade and better polishing for its reflector.
Satan@103TFS:Any test result of the throw?
My unprotected flat top LiitoKala 21700 4000mAh battery which is supposedly a Lishen does work just fine.
Ordered.
I will wait until some review come out.
Interested!
No problem. [quote=Satan@103TFS] I will wait until some review come out. [/quote]
interested
Done. [quote=Micmania] interested ;) [/quote]
Interested
Freeme, is there any update on the quiescent current? I don’t want a dead battery after a month sitting idle. Thanks.
It consumes about 5mA of the battery with breathing light ON. You can further reduce the drain by disabling the breathing function for final retail version. (Note: unable to disable on prototype due to incomplete firmware).
Please put me on the list for this one
Interested!
Is there any notification as to when these will begin shipping?
When not in use for long periods, just turn the tail cap for zero parasitic drain.
JohnnyUtah:Freeme, is there any update on the quiescent current? I don’t want a dead battery after a month sitting idle. Thanks.
ooof, put that into perspective with the standby drain of the Q8: 0,135mA with the switch LED being shiny!
Isn’t this a bit too much? It would drain a 4000mAh battery in a bit more than 33 days o.O
