[Sofirn Lightning Deal] Sofirn SP32AV2.0 only 20.99 on AMZ us
Maybe Sofirn can implement the same feature, however it works it’d be vary handy to enable locking out reliably.
They have it in SP31. Link here - Amazon.com
Interested in 1 gold only.
Compared to the SP32A, the SP32A v2.0 has:
(Sofirn really should cut down on the model suffixes, decide on one way to iterate, and stick to it)
+ATR
+Battery indicator in switch
+CR123A compatibility
+other unspecified changes improve reliability
+Gold and Silver finishes
-v2.0 driver loses the electronic lockout
-Reduced output in Turbo mode in exchange for longer run time and stability
Fine light, good service, but like I said above, when even light enthusiasts have trouble sorting out all the models and their differences, it's a problem.
I received a gold SP32AV2.0 today. Shucks, I did not anticipate this group buy.
But let me encourage those of you who are interested in this light with some observations:
What I like about it:
Looks very nice – a rich, titanium gold.
The build quality is rugged. Feels like it could be passed down a generation.
Nice balance between flood and throw.
Bright. One of the brighter single 18650 EDCs out there.
It retains its brightness on Turbo much longer than a D4. I did a simple test, starting both on turbo simultaneously with fresh identical batteries. While the D4 started out far brighter, after 30 seconds, the SP32 v2 was much brighter as the D4 had stepped down 5 times.
It is slower to heat up and does not get as hot as a D4.
Very pocketable.
Easy to switch between step and ramp modes: From off, press and hold 3 seconds.
The disorienting strobe is full turbo brightness.
Battery level indicator light embedded in side switch.
Battery charge lasts a long time.
Takes any kind of 18650 - protected, unprotected, flat top or button top.
What I would like better:
A warmer color emitter; this one is 5500K, a little on the cool side of neutral white.
The switch light stayed on for 30 minutes instead of 5 seconds.
All in all, this light is a winner - as is. (Not that you couldn’t mod it better!)
I didn’t see this mentioned, but the v2 has better ramping, doesn’t it?
I’m interested in one kit & one gold.
yes V2 ramping is faster than V1 and smoother
but V2 moon mode is way too bright compare to V1. Hence i still like V1 due to low moon mode and long runtime :slight_smile:
This video review compares the new SP32 v2.0 with the original SP32: https://m.youtube.com/watch?v=HHy2YNTWNeY
I found ramping to be a little on the slow side - enough so that I wanted to explore the manual 4 steps setting which the light arrives with as the initial setting.
Regarding moonlight, the manual claims it’s 5 lumen. I found it bright enough to search for stuff under my car seats, bright enough to read with, to see a few yards ahead on a dark path, but not so bright as to disturb a sleeping tent mate. It’s a useful level that the manual claims can last 260 hours on a fully charged 3500Mah battery.
Yep, ramping takes 5 seconds; which is a bit slow… but I still prefer it to set outputs.
I totally agree about the moonlight mode, for me it is a usable setting as it is not super low. It is bright enough to be usable in many situations but not bright enough to be a bother to others in close quarters.
The first batch of SP32A v1 had slow ramping (about 7-8 seconds). The later batches of SP32A v1 has ramping of about 3.5-4 seconds (I think Emisar D4 is 3 seconds?) I believe the SP32A v2.0 has similar ramping speed as the SP32A v1.
Yes, regarding the lowest mode on v2, I also find it a bit too bright. I often like a true Moon mode (1 lumen) for EDC flashlights…
We’ve just had a three day power outage, so my recent discovery of the vast world of flashlights came in handy!
One Black Kit
One Gold Only
Thanks
1 gold only!
Nice picture, thanks for sharing it!! :+1:
Lucky…
I keep hoping for an outage so I could show off my lights. :smiling_imp:
Is it really that color in Real Life™, or just the way the pic came out?
Mine’s a sort of greenish-grayish-gold color, hard to describe, especially as it seems to change color depending on ambient light. I called it a sort of “pewter gold”.
I like it, as it’d certainly unique, but hey, I’d love a gold-gold color like is in the pic.
I inderstand what you mean about the color. It picks up and reflects the color of the light around it. My photo was taken under a 2700k (soft white) house lamp. The flashlight picked up the warm yellow. Outside, it is much the color you describe. I think that’s cool!
Aha.
Yeah, I’m not even sure what to call that color. I recall seeing it before, but no idea on what, or what it might’ve been called.
Should call Ford or GM and ask what name that color would be. They have “interesting” names for colors, not just “red” or “green” anymore. Probably something like “Mediterranean slate”…
Hmm, like on my car:
Exterior Colors
  • Atlantis Blue Metallic [Blue]
  • Carbon Black Metallic [Black]
  • Champagne Silver Metallic [Beige]
  • Crystal Red Tintcoat [Red]
  • Mocha Bronze Metallic [Brown]
  • Storm Gray Metallic [Gray]
  • White Diamond Tricoat [White]
Mine’s the “White Diamond Tricoat”. :laughing:
Is that how the new SP32A v2.0 gold looks like now?
It used to look like this, very "pale gold", as it was called that time. More like a light brown color.
(SP32A black -- SP32A v2.0 silver -- SP32A v2.0 pale gold)
the SP32A v2.0 silver comes in 2 types, depending on batch probably -- I've noted a glossy silver and a matte silver)
Interested in gold
d_t_a I doubt the manufactured color has changed. How it looks to the eye or camera depends on the color of the surrounding light. I am going to guess your photo was taken near a daylight window or under cool florescent lights - a high kelvin number. The light bulbs in my house are 2,700 to 3,100K so it comes off looking a warmer tone. Outside at night, well, they all look black :slight_smile:
I am liking this light and might pick up a few more for Xmas stocking stuffers.
