I didn’t pay any tax, I live in Wisconsin for the record.
My guess is maybe Ali has a warehouse in your state?Online tax paying is always kind of weird. You can buy something from a chain of stores based from another state and the item is stocked and ships from another state, but if that chain has 1 store in your state, you have to pay your state tax.
I believe the 3200K Yuji LED used in the first run is the 30 degree 95 BC ones (if I'm wrong someone will correct me) and they are discontinued. The 45 degree 3200K are out also, but the 60 degree 3200K version is still available so logic dictates that if Sofirn makes a second run they'll probably use the 60 degree LED for the warm 3200K version. So no need to panic about not getting a Yuji LED in your C01 just yet. Just my opinion.
Does anyone else’s tracking number work? Mine was marked shipped a little while ago and shows as “number not found” on 17track. Isn’t that usually because it’s not a real tracking ID?
IMHO 17track is one of the best tracking sites around, but it is not allmighty. Especially when it concerns AliExpress parcels. But Ali has it’s own tracking system. Go to “My AliExpress” => “My Orders” and in the right row of your particular order you’ll find the button “Track Order”. Pushing it will reveal you something like “Shipment accepted by airline”. With Ali parcels it is even quite accurate (and detailled) to follow parcels in the destination country, a notorious weak-point in most tracking systems.
Both 3200K and 5600K versions have 60 degrees leds and that is clearly mentioned close to the top of the OP, including a beamshot comparing them to a 45 degrees Yuji led (but that one is wrongly called a 30 degrees led, sorry about that). Is that good enough?
Indeed, it is, and I missed it as it was in the first paragraph of the quote [Update 2018-10-29 (Update from djozz)]!
Guess that should be enough Thanks mate !! :+1:
See, I told you people would correct me lol. There's no problem with Yuji LED being sold out currently, so people can calm down. Even after the first run of 2000 lights are sold out Sofirn can make more if there's a demand for it. So grab one when they are ready.
As has been stated many times, there is no ‘sign up list’ per se. Members were asked to add their names to an interest list in hopes of convincing Sofirn that the project was worth while. Now that Sofirn has created the lights, they are first come first served on their store at Aliexpress.
At the moment, the first batch of production has sold out, but more are on the way. A total of 2000 lights will be produced, half for each of the two CCI options.
