[BLF special edition light] new Sofirn AAA twisty high CRI Yuji 5mm LED (CCT 3200K or 5600K) for 6.50 USD
2863 posts / 0 new
iamlucky13
Last seen: 3 hours 26 min ago
FYI, I do intend to keep updating the list until the planned 2000 are complete, just in case Sofirn checks user names before granting discounts. It will probably be after the US Thanksgiving holiday before I have much time to sit down and do it, however.
djozz
djozz's picture
Last seen: 1 hour 1 min ago
Thumbs Up Thumbs Up Thumbs Up
MascaratumB
MascaratumB's picture
Last seen: 2 hours 36 min ago
My C01s started “moving” today, 9 day after they were bought! I guess 11/11 is a really complicated time for shipping Wink
In 3-4 weeks they will arrive (probably) Wink
[REVIEWS] ACEBEAM: H20 / TK16 /// AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 /// BLITZWOLF: BW-ET1 /// BRINYTE: T28 /// DQG: AA Slim Ti /// FIREFLIES: ROT66 GEN II /// HC-LIGHTS: SS AAA /// KLARUS: XT1C /// LIVARNOLUX: 314791 /// LUMINTOP: Tool AA V2.0 + Tool 25 /// NITEFOX: UT20 / ES10K / K3 /// ODEPRO: KL52 / B108 /// OLIGHT: M2R Warrior /// ON THE ROAD: M1 / i3 / M3 Pro /// ROVYVON: A2 + A5R / E300S / A8 /// SKILHUNT: M150 /// SOFIRN: SF14 + SP10A / SP32A / SP10B /// WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 /// XTAR: PB2 Charger ///
Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 /// TIR Lenses: 1 / 2/// Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 ///// My Collection ///// My Review's Blog (PT)
OL Contest 2019
GIVEAWAY: 1 / 2
jon_slider
jon_slider's picture
Last seen: 7 hours 22 min ago
Mine too Smile
Your item was accepted at 9:14 pm on November 20, 2018 in CHINA
We will have them in time for Xmas, maybe Wink
hank
hank's picture
Last seen: 10 hours 25 min ago
Usually my packages from China arrive at the mailbox while the tracking has them somewhere over the Pacific Ocean.
Tally-ho
Tally-ho's picture
Last seen: 3 days 20 hours ago
The black 3200K and 5600K are back in stock.
Lagittaja
Lagittaja's picture
Last seen: 2 days 9 hours ago
Thanks for the notification Tally-ho, placed an order for my two pieces. Waiting for the price adjustment.
Edit: By the way, is it safe to run lithium primaries (LiFeS2) in this? The open circuit voltage when new is ~1.8V but once loaded it will drop below 1.6V. I presume it is safe but can’t hurt to ask.
slowtechstef
slowtechstef's picture
Last seen: 1 day 11 hours ago
Thanks Tally-ho for the update Thumbs Up
I edited the first post.
slowtechstef
These lights run perfectly fine on Lithium (LiFeS2) primaries, due to the voltage drop under load. For example see the Energizer whitepaper.
slowtechstef
To follow up an the Lithium primaries remark: these batteries are great for when using your flashlight in extremely low temperatures (at -40 degrees Celsius), or if you leave your light regularly in your car while in the desert.
Biggest advantage is their shelf life of 20 years at 95% percentage of energy contents (Energizer claim), and they do not leak in contrast to “alkaleaks”.
However, I am not quite sure that at the low load of approximately 60 mA of the C01 you will get really more energy (mAh) or runtime from an AAA LiFeS2 battery than from an AAA alkaline battery, as both are rated at approximately 1200 mAh at low current use.
Biggest disadvantage of Lithium primary batteries is their relatively high price (1.35 Euro/battery at NKON.nl), especially when compared with (LSD) NiMH rechargeables (1.50 Euro/Battery for 900 mAh Ikealoop) or Alkaline primaries (0.18 Euro/battery for Ikea AAA Alkaline).
DavidEF
DavidEF's picture
Last seen: 1 day 15 hours ago
Unless the input side driver components can’t stand the slightly higher voltage, I would expect it to run better with the Lithium Primary. This is using a boost driver already to get voltage up to the Vf of the LED.
- The YKK Philosophy
slowtechstef
I borrowed Djozz prototypes of the Sofirn C01 to experience the lights and their light (output) in real life.
It runs new lithium primaries fine, but I do not see a visible difference in output in contrast to full alkaline cells, or fully recharged NiMH cells.
When I measure current I also do not see any significant difference between a full Alkaline battery (with an open circuit voltage of 1.60 Volt) or a new Lithium primary battery (with an open circuit voltage of 1.80 Volt), or a fully charged NiMH. Alkaline measures 58 mA, Lithium 57 mA when the LED is on (with the 3200K-C01).
By the way this current when using full cells is the lowest of any 5mm flashlights I own. My both Fenix E01’s measure somewhere around 130 mA with new batteries (whatever chemistry). The Varta/Rayovac indestructible measures 230-280 mA (depending on chemistry). The GP Discovery CLE202 (praised for its long runtime) measures around 80 mA. The CMG Infinity Ultra measures 130mA for alkaline and 140mA for a lithium pirimary cell.
In contrast: my Zebralight H53Fc runs at 20 mA when I select an output mode that is comparable to the output of the 3200K C01. However, it will not turn on with depleted cells at 0.9-0.8 Volts, which the C01 will turn on with, albeit with lower light output.
So I guess for the ‘regulated’ part of the runtime, the C01 light currently probably has the longest runtime within its class of single-cell 1.5 volt battery vampire 5mm led lights.
In order to enact a zombie apocalypse preppers doomsday scenario flashlight fantasy, I did a runtime test with an “AAAA” cell I salvaged from a 9 Volt battery I took from the battery recycling box at an Ikea store. When opened up it contained two leaking alkaline cells measuring 0.1 and 0.2 Volts, and four cells measuring around 1.30 volts. This type of “AAAA” alkaline cell is rated at 500-600 mAh capacity when new. One of these 1.3 Volt AAAA cells ran the 3200K-C01 for over 18 hours until there was no visible light output anymore. I experienced around 10 hours of low light, 7 hours of moonlight low, and finally 1 hour of really dim low light.
Kudos to the Sofirn C01 engineer who cloned the great design of the Fenix E01 boost driver. Thumbs Up
jon_slider
slowtechstef, kudos, respect, applause, and Happy Turkey Day
your dream has become reality, and it is touching the lives of many people around the world
for those who still think a Fenix with its angry blue low cri LED is worthy of your money, that is still an option. It costs more, and the LED cannot compare to the Yuji in the Sofirn C01, but I wont judge.
Speaking of lights that cost more, with LEDs that cannot compare.. anyone who is interested in the ARC AAA, that the Fenix copied imo, can still buy one today, for even more money.. Go Here to spend the big bucks on Low CRI.
dealgrabber2002
Last seen: 1 day 4 hours ago
Who has the skills to disassemble it to see if the potting material harden (like Sofirn said) or will it still be gooey?
hank
hank's picture
Ha. I still have a bunch of Arc AAAs, “snow white” — in regular use on keychains, and several on the shelf with different color LEDs —aqua, red, blue. Never did get a red-orange.
Bill S.
Last seen: 1 year 4 months ago
I’d love to know if these are indeed as tough as the E01.
Have four coming my way.
defloyd77
Last seen: 1 week 6 hours ago
textileRef:11247316845e81d74eb5656:linkStartMarker:“Speaking of lights that cost more, with LEDs that cannot compare.. anyone who is interested in the ARC AAA, that the Fenix copied imo, can still buy one today, for even more money.. “ Here”:https://www.ebay.com/itm/ARC-flashlight-LED-cpf-edc-free-shipping-to-the-USA/253992014642 to spend the big bucks on Low CRI.
Let’s not get too far ahead of ourselves just yet. There’s only a couple of these in that have been in the hands of forum members so far, the E01 and Arc didn’t gain their fame over night with just a few lights tested. A nice LED won’t save this light if QC doesn’t measure up or if the tested samples were hand selected.
Lagittaja
Lagittaja's picture
About 5 hours later price changed from 17.76$ to 13.00$. Paid.
My thoughts exactly.
Thank you for testing, at least short term there will be no damage. Not sure about long term, I guess I will see. I mean the driver will briefly see the higher voltage but like I did say the voltage drops under load. I just figured it wouldn’t hurt to ask.
Obviously lithium primary will kick alkaleak out of the water at high loads. Not so much at really low loads.
Though even at low loads the lithium primary will still be measurably ahead, up to around 40-45mA load, below that the difference will be so low it’s not worth mentioning.
At 100mA constant current it has 15% more capacity and 30% more energy. (Yes, I know 100mA is 1.6× 60mA)
So…zooming in on the datasheet, Energizer claims that at 60mA CC load (to 0.8V) their lithium primary does 12.6% better (1242mAh) than alkaleak (1103mAh). Sounds about right to me.
But I’d focus on the energy part. Especially after you consider…
…that this 60mA current draw you measure is only at full voltage with fresh cells?
The lithium primary will hold the voltage higher for longer. “Area under the curve” rules in my mind. Lithium primary wipes alkaleak off the table in that regard.
I will leave these links for reference:
I don’t know what is the absolute best alkaleak AAA but let’s just take Fujitsu Premium as an example. It sounds good and I did browse through a bunch of them and it’s curve looked nice at 100mA.
https://lygte-info.dk/review/batteries2012/Fujitsu%20Premium%20AAA%20UK....
And here’s Energizer Ultimate Lithium
https://lygte-info.dk/review/batteries2012/Energizer%20Ultimate%20Lithiu...
If some people don’t care to look behind the links for discharge graphs the main point would be that at 100mA CC load that particular alkaline drops below 1.4V/1.3V after 1h/3h while for Energizer Ultimate Lithium primary it is 8h/12h respectively.
Now because lithium primary holds voltage higher for longer my brain says that it means that with lithium primary the C01 will stay in regulation for quite a bit longer than it would stay with an alkaleak.
Because when the alkaleak voltage drops > boost circuit draws more current > alkaleak voltage drops and so on and so on.
That is, alkaleak will leave regulation and drop intensity sooner than it would with lithium primary.
This would also mean that when lithium primary leaves regulation it would be after really big chunk of the energy has been extracted.
What will the runtime with output lm look like? I seriously don’t know and I don’t have the equipment to test it.
I expect the runtimes to be similar. Maybe lithium will be slightly ahead. Whether it’s on par or slightly ahead or quite a bit ahead I fully expect that it will have a much longer regulated runtime and that would be more important to me.
Since you mentioned NiMH, I hope no one intends to use NiMH with the C01. I imagine the lower nominal voltage won’t be good for regulation time and if you forget to recharge it…
Yes I know the environment and such. To each their own.
I would be ready to send some euros through Paypal to someone who has the equipment and who is willing to do the runtime test with output lm logging between high quality alkaline and Energizer Ultimate Lithium.
7YP160214
Last seen: 3 months 4 weeks ago
If signing up for the interest list means Sofirn is more likely to make more of these, then I’ll take two 5600k and a 3200k
MascaratumB
Read post 1:
Quote:
The focus of this thread:
Sofirn is producing an AAA twisty with 5mm high CRI Yuji LED (one version in 3200K, other version in 5600K). Special price with BLF discount mentioned by Sofirn is 6.50 USD. Sofirns plan is to produce 2000 lights with Yuji leds, half 3200K half 5600K, 1200 black, 500 red, 300 blue.
You can buy the lights from AliExpress,the list was to express interest on the flashlight, I’m not sure Sofirn will do more lights now, besides the 2000 above mentioned!
OL Contest 2019
GIVEAWAY: 1 / 2
teacher
teacher's picture
Thank you for the update Tally-ho!! I just happened to see your post minutes after you posted it & went straight to AE & placed my order for 9 of the 12 I asked for. (Saving the other three in case they really do make the Red & Blue models. Wink )
I was not sure I had ordered correctly, but much to my surprise the price changed to $6.50 each a few hours later & I paid. Thumbs Up
Thanks again for the ‘heads up’ Tally-ho & thanks to Sofirn also. Beer
Format is:
Qty 3200K; Qty 5600K – Username (post#)
  • 3; 2 – litenutz (277, 528)
  • 4; 8 – teacher (278, 677, 937) // [purchased 3; 6]
  • 3; 3 – sma (280)
7YP160214
MascaratumB wrote:
Read post 1:
I realize it’s still only an interest list, but I was hoping the favorable response from the community would mean Sofirn would make more of these. Even if the Yuji LEDs are unavailable, a not-completely horrible 5mm LED would still be palatable in such an otherwise great light. Admittedly I know nothing about manufacturing and business management in China, but I would have thought the math for Sofirn would work out to “making/selling more of these” == “good idea.” Oh well. Sofirn has been a very cooperative company with the BLF community; if they don’t continue manufacturing the C01, I can respect their decision.
staticx57
Last seen: 9 hours 33 min ago
Can I make an impassioned plea to change the title from tint to color temperature? 3200k and 5600k are color temperatures NOT tints. Tint describes something different.
That being said, I cannot wait for mine Big Smile
lightboks
lightboks's picture
12 hours later.. sold out again? this seriously sucks.
is it possible to set a pre-order for when it is back in stock somehow?
djozz
djozz's picture
I think that the release of this new Sofirn light in this busy sale period is seriously affecting production capability. And I remember Barry telling me last month that for the 11-11 sale Sofirn had to produce old models and that it was holding up the production of new models. This is very chinese: they give priority to products that they have an idea of how well they sell over new models that have not proven themselves yet, however promising they seem. This is still true while Sofirn is way less conservative than other chinese budget flashlight manufacturers.
lightboks
lightboks's picture
ok.. but something is weird.. I always get to the dutch ali express when I click on the link in post#1. When I set the page back to english there is no way to find the product on aliexpress with the search bar. are out of stock items not searchable?
also it still says 151 orders. so if there was a second batch available yesterday evening, why are the new orders not shown?
djozz
djozz's picture
As soon as the C01 was out of stock, I could also only get the page via the link in this thread. Maybe their new stock was not ready after all and just the old page (that they did not link anymore via the Sofirn store) became active again for some reason.
Kame Sennin
Kame Sennin's picture
Last seen: 35 min 1 sec ago
If someone can change the OP link to this one it's the "general" shop instead of NL one
djozz
djozz's picture
Kame Sennin wrote:
If someone can change the OP link to this one it’s the “general” shop instead of NL one
That “someone” is only slowtechstef. He’s around a bit more often now so the OP is updated more regularly too. Smile
Tally-ho
Tally-ho's picture
This link in the first message goes straight to sofirn’s store on the global Ali in english :
