Cannot wait
I’ve never been so excited to own a tiny expensive yellow square
Sure you didn’t “find” those in an “abandoned” warehouse??
Can’t wait to see what you do with ’em. Did you study physics or engineering by chance? Just curious.
Always interested in your builds. Being laser powered this one has my attention.
such a cool looking project
I anticipate another enderman’s epic build…with several LEPs ?
Hahaha I actually had to pay for these!
I’m currently in engineering.
Thanks
Nah just one, but minimum order quantity was 5.
Probably a good thing though because I’m sure I will burn through at least some of them…
Cool!
The world is becoming more interesting since you can just buy anything now that used to be only available to specialised companies.
I’m sure that you will have more than $300 worth of fun with these!
Sure hope so!
I wonder what would it do on top of White Flat die…
If I knew how to remove the phosphor layer from a white flat I could try it.
All I know is that Saablaster claimed to be able to swap phosphor from SST-40 to XHP35. As well as to lift the die off the XHP35 package and put it on a diamond heatsink. Osram LEDs are different, but maybe he would be capable of doing a similar surgery to them as well.
Would he be willing to help you with that? I have no idea.
Very nice! Do you plan on beating polar-li’s BFF (farthest thtoewing portable light)?
Good idea
My plan was to kill a Weltool
take the inside
and put it together with a 120 mm lens and Collar.
But I do not do this,cause the power is to less,
If yo wanna sell 2 pieces of the single crystal YAG:Ce phosphors
I will buy it.Send me a message please .
Thanks in advance
Xandre
Which one? Is it on the list or am I missing it?
Sounds good, I’ll let you know if I have spares
This light , the BFF, will beat them all. We don’t really need a measurement to know that. He is using a special bulb with an extremely high luminance that I never knew existed before.
A conservative estimation puts the throw at around 250Mcd.
Oh cool
Well I only have very rough theoretical numbers which are probably not anywhere close to real performance, but I have high hopes.
Once I order the laser and start doing intensity test of the phosphor crystal then I will have a better idea.
Sounds like a fun project!
I know you are all about the luminance, but I wonder how much output you can get. Say you get a 10W output blue laser. Max theoretical efficacy for excited phosphor is 300 lumens/W. Say you get half that to account for phosphor inefficiency and light emitted backwards. Then that is 1500 lumens. Is that on the right track?
You could put a hemispherical reflecting collar on the bottom too to recycle the light going down.
Yeah probably about that much.
A research paper got 4k lumens with 14W of lasers.
The highest power single blue laser is about 7W though, so about 2k lumens, not sure how much will be wasted out the back, maybe 50% or maybe less.
Possible, but I need to have cooling on that side so I can’t fit a second collar.
