IMALENT DX80, "The End of Darkness", is a rechargeable LED flashlight with intelligent design that focused on maximum brightness and runtime that can be applied to all kinds of environments. Its 8 pieces of American Cree XHP70 2nd generation LED make it capable of a max output of up to 32000 lumens. With its advanced circuit design, the OLED display can show the output, voltage and modes, the ease of use that this brings for outdoor activities will change your world. It allows you to plan effectively, and lower the risk of ever running out of light in the dark.
Main Parameters:
Emitter Type: Cree XHP70.2
Light Color: White light
Battery Configurations: Built-in 8pcs 3000mAh battery pack
Luminous Flux: 32000 lumens
Max Range: 806 meters
Color Temperature: 6500K
Waterproof: IPX-8 waterproof 2 meters
Impact Resistant: 1.5m
Output and Runtime:
Turbo: 32000-7000 lumens ( 3+100min )
High: 13000-7000 lumens ( 8+122min )
Middle High: 13000-7000 lumens ( 2h 25min )
Middle: 5000 lumens ( 5h 40min )
Middle Low: 500 lumens ( 40h 46min )
Low: 120 lumens ( 168h )
Product Features:
● Utilizes 8 pieces of American Cree XHP70 2nd generation LEDs, with a lifespan of up to 50000 hours and a maximum output of 32000 lumens.
● The shot distance is up to 806 meters with wide beam range.
● The multi-functional OLED display can show various parameters and settings.
● Built-in battery pack includes 8pcs 3000mAh 18650 Li-ion batteries with high discharge performance.
● High efficiency constant current circuit will maintain constant brightness.
● Anti-reverse battery protection.
● Intelligent temperature control, when the body's temperature is up to 50 Deg.C, the LED display flashes 8 times for 30s to give a warning. It will also automatically adjust the current to keep the flashlight to work under 50 Deg.C for long time.
● Low power warning, when the battery voltage is under 13V, the battery symbol will flash 10 times per minute to remind user to change or replace the battery.
● Ultra clear toughened glass lens, the light transmission is up to 99pct with scratch and impact resistant.
● Aluminium OP reflector.
● Aerospace-grade aluminium alloy body, wear-resistant Type III hard-anodized surface treatment.
● Waterproof level up to IPX - 8 ( 2m submersible ) the flashlight can work normally even in heavy rainstorms.
● 1.5m impact resistant.
● Tail stand function.
IMALENT DX80 can be used in all kinds of situations, such as adventuring, search and rescue, night fishing, industrial use, etc,. Applying the coupon code "IMDX80" on GearVita, you can get $120 discount, it will definitely become your good helper: https://gearvita.com/imalent-dx80-led-flashlight-32000-lumens.html
You may like:
xiaomi mi pad 4 plus 4g review
xiaomi mi box s tv box global version review
