It is like LVP, but built deep into the attiny85’s innards. Basically, if voltage drops below 1.8V at any time, even for a few microseconds, it’ll stop code execution completely. The main purpose of this is to make sure the MCU won’t attempt to do anything when it’s out of its supported voltage range, because its behavior is unpredictable when voltage is too low. This helps prevent random eeprom corruption and things like that.
The benefits outlined in the attiny manual don’t seem to matter for flashlight purposes, but it doesn’t hurt. I’m using BOD for its side effect — increasing standby power. Because it makes no difference to battery life but it makes a lot of difference when attempting to exit momentary mode. Without BOD, it could sort of get stuck in momentary mode because there was no fast way to force residual power to drain.
Without BOD, standby power was so low I had to use a high-end 6-digit Fluke meter to measure it. So, basically zero. Or ~0.0001 mA, if I recall correctly. This is impressive, but too low for this purpose. So with BOD, standby power is about 0.02 mA. Low enough to be negligible for battery life, but high enough to make the light shut down only a second or two after power is removed.
Agreed. As for the factory reset thing, knowing a little bit about some issues, you’d either have to have a complete duplicate set of incorruptible memory to re-programme the thing, and worry about bootloaders (also corruptible), or checksum it on startup and clear out anything looking wrong and start again if possible, or just declare it dead, return to manufacturer. Difficult to see how to do any of these hypothetical things.
Unless the worry is just about getting stuck in a loop due to a bug, configured into non-volatile memory with no way out. Which is quite another matter.
Or just trying to start again quickly with what’s still there, in a default configuration. Which makes sense.
Turning on BOD is the right thing to do at this point, despite resistance from some other people. It has been a controversial issue in the past, but I think the benefits are more accepted nowadays.
Yes, it should make things easier for printing in black and white.
I need to do some updates too, but I’ve been procrastinating about it because there’s not much room left to add anything. It could use some info about how to control aux LEDs, for lights which have those, but I’m not looking forward to rearranging things to make it fit.
