13576 posts / 0 new
joechina
Last seen: 3 days 2 hours ago
pinkpanda3310 wrote:
The pictured light must be proto 3 ?
Prototype 3 was sent to Germany, unfortunately not to Toykeeper.
I wouldn’t call this a prototype, only anodisation samples to deside the color.
Tom Tom
Last seen: 10 months 2 days ago
Random Dan wrote:
Perhaps since Lumintop only intended to test anodizing, they didn’t bother cutting actual threads? That’s why the tubes look different and why the parts couldn’t be threaded together.
Good call. And thank you TK so much for confirming it with Neal.
Not sure why doing a nice anodise should be proving so tricky, isn’t that what anodisers should just know how to do, it’s their job after all ? Perhaps it’s to do with the alloy used. ISTR that it also took Convoy a while to develop their clear anodise to their satisfaction.
A clear anodise on a “raw” machined finish is also merciless in exposing the slightest defects in workmanship, when the machining marks are to be a design feature, not something to be covered up. Just handling the pieces, moving them around, keeping them almost surgically clean before processing, etc. needs care, individual bubble wrap etc. if you don’t want them dinged up, then a good hard anodise to then protect them. Unlikely to be real mil-spec HA3 stuff, but still something good, semi-hard.
It was probably unrealistic to hope for anything like that at this price-point.
Bead blast, a quick dunk in the tanks, then just chuck them all in a bin together is the production-engineering easy way out.
The solo artisan perfectionist, toiling at their lathe, can make things much more beautiful, and go from concept to execution in a few hours, but that doesn’t easily scale, as I think we are discovering.
Sitting behind a CAD screen, rendering, then perhaps coding for CNC (that’s usually a different, more practical, and dare I say more skilled discipline), is not quite the same thing as making swarf, and sometimes pieces don’t turn out quite the way it was hoped, or are simply un-manufacturable, and another iteration is required, and things can become delayed interminably. The skill is not to let that happen. And to use a team to review, accept constructive criticism, involve the production people as early as possible, and not just live in an ivory tower.
It looks as if they have got a nice looking bland result.
For those interested, you could take a look at e.g http://www.metroplating.co.uk and study their “services” options. Each provides a succinct summary of each process. Specialist finishers like these are crucial to the UK’s manufacturing competitiveness, particularly in motorsport, aerospace and defence, and metroplating one of the best and most nimble IME. There are hundreds more though to choose from, just Google e.g. “anodising uk”.
Or have a go yourself. It’s not difficult. Research it, or just buy a kit from e.g. http://www.gaterosplating.co.uk/index.php?route=common/home or https://www.chronos.ltd.uk/acatalog/Anodising_Kits.html
Something for modders to experiment with, and a bit more creative than e.g. just baking your torches.
Start with something cheap, strip off the old with sodium hydroxide (e.g. some drain cleaners), maybe buff it up a bit, and get practicing. Some battery acid, inkjet printer ink, some sort of DC power supply, a cathode, some Al wire, and you’r good to go. Perhaps in time for the 2019 Old-Lumens challenge. Use titanium instead, and apply by brush, use masking, and you could make a really unique work of art.
ToyKeeper
ToyKeeper's picture
Last seen: 2 days 15 hours ago
JasonWW wrote:
Did they mention whether the dark lines/overlap are now gone or perhaps hidden?
They did not mention. I did ask though.
All I have is a couple of pictures, and the pictures don’t show any seams.
ToyKeeper
ToyKeeper's picture
FWIW, Neal has asked to have a working sample made and sent to me for testing.
The firmware used should be this one: http://toykeeper.net/torches/fsm/anduril.2018-12-02.FW3A.hex
Recommended fuse values are:
  • Low: 0xE2
  • High: 0xDE
  • Extended: 0xFF
So, BOD is enabled. Without BOD, it’s very difficult to exit momentary mode because the standby drain is too low. It took several minutes to drain far enough to cause the driver to reboot, and with BOD it’s only a few seconds. This should also help avoid other theoretical issues with low voltage.
Factory reset isn’t included, because it’d cause too much delay making sure there are no bugs. I did a quick proof of concept but there were too many issues to move ahead with the change right before production. So I went back to the 12-02 version which, despite the date indicated, has been under test for about three weeks on various lights. It’s virtually identical to the 11-11 version.
Anyway, it seems things are finally moving quickly.
chadvone
chadvone's picture
Last seen: 4 days 23 hours ago
Does BOD mean brown out detection?
the ability to stay on through super short power cycle?
If so I think this would be a good thing.
Is it a good thing?
nottawhackjob
Last seen: 1 week 6 days ago
cabfrank wrote:
Nottawhackjob, the size and the firmware are elite for an edc. That is what does it for me. I suppose you are correct in that it is not a giant leap ahead, because of the Emisar, which is similar in some ways. I like them both, but have been holding off, waiting for this one.
Yeah the Emisar is watt I was comparing it to.
However there IS a nice subtle design aspect of the FW3A body I do like A LOT which stands out. The sleekly well-crafted ‘combat grip’ ridge right above the tail cap. Extremely useful and a feature I wish many of my rear switched single-cell flashes had incorporated.
Elegant simplicity.
I may buy this just for this brilliant point alone and the way it was executed.
Kudos to the brain that insisted it being there.
Thumbs Up Beer
PS. I wanna clarify that this finger grip ridge isn’t uncommon per se. Just that it appears the FW3A’s is actually large enough for even glove wearers butt yet isn’t too large as to be ugly and out of proportion to the rest of the outer design. Plus it looks well smooth machined and thus comfortable. Sharp ridges and fingers pressing down don’t work for me. Cool
“In many things in order to truly understand the small picture you have to understand the big picture first.”
teacher
teacher's picture
Thank goodness!!Thumbs Up Thumbs Up Thumbs Up
ToyKeeper
ToyKeeper's picture
Yes.
It is like LVP, but built deep into the attiny85’s innards. Basically, if voltage drops below 1.8V at any time, even for a few microseconds, it’ll stop code execution completely. The main purpose of this is to make sure the MCU won’t attempt to do anything when it’s out of its supported voltage range, because its behavior is unpredictable when voltage is too low. This helps prevent random eeprom corruption and things like that.
The benefits outlined in the attiny manual don’t seem to matter for flashlight purposes, but it doesn’t hurt. I’m using BOD for its side effect — increasing standby power. Because it makes no difference to battery life but it makes a lot of difference when attempting to exit momentary mode. Without BOD, it could sort of get stuck in momentary mode because there was no fast way to force residual power to drain.
Without BOD, standby power was so low I had to use a high-end 6-digit Fluke meter to measure it. So, basically zero. Or ~0.0001 mA, if I recall correctly. This is impressive, but too low for this purpose. So with BOD, standby power is about 0.02 mA. Low enough to be negligible for battery life, but high enough to make the light shut down only a second or two after power is removed.
amars7
Last seen: 2 months 1 day ago
Put me down for one!
supanate7
Last seen: 2 months 23 hours ago
Please add me to the list for one!
GreenBolivian
Last seen: 1 month 2 days ago
Put me down for one please!!
rebelbayou
I would be interested in for sure. Thanks!
joechina
@Toykeeper
I redid the Andúril UI graphic a bit and sent it to the BLf adress on Toykeeper dot net
Any comments if good or useless?
Ramrod
Hi there, cool looking project!
Put me in for one.
id30209
id30209's picture
Last seen: 1 hour 37 min ago
2 more please!
WTB Titanium 4sevens Quarks & Jetbeam TCR1
Marc E
Last seen: 2 days 11 hours ago
Late to the party but i’ll have 2 (one of each LED config).
Thanks!
matik42
Last seen: 4 hours 57 min ago
interested from one LH351D
chadvone
chadvone's picture
joechina wrote:
@Toykeeper I redid the Andúril UI graphic a bit and sent it to the BLf adress on Toykeeper dot net Any comments if good or useless?
Can the rest of us see it?
Tom Tom
ToyKeeper wrote:
Yes.
Agreed. As for the factory reset thing, knowing a little bit about some issues, you’d either have to have a complete duplicate set of incorruptible memory to re-programme the thing, and worry about bootloaders (also corruptible), or checksum it on startup and clear out anything looking wrong and start again if possible, or just declare it dead, return to manufacturer. Difficult to see how to do any of these hypothetical things.
Unless the worry is just about getting stuck in a loop due to a bug, configured into non-volatile memory with no way out. Which is quite another matter.
Or just trying to start again quickly with what’s still there, in a default configuration. Which makes sense.
Turning on BOD is the right thing to do at this point, despite resistance from some other people. It has been a controversial issue in the past, but I think the benefits are more accepted nowadays.
ToyKeeper
ToyKeeper's picture
joechina wrote:
I redid the Andúril UI graphic a bit … Any comments if good or useless?
Yes, it should make things easier for printing in black and white.
I need to do some updates too, but I’ve been procrastinating about it because there’s not much room left to add anything. It could use some info about how to control aux LEDs, for lights which have those, but I’m not looking forward to rearranging things to make it fit.
Depot_Shredder
Last seen: 2 months 6 days ago
I’m so looking forwards to this. Am I on the list already? If not, I’d love to buy at least one with the LH351D LEDs.
Firelight2
Firelight2's picture
Last seen: 7 min 8 sec ago
Nice to see this project coming together!
When do you think it will go into production TK? 3 months? 6 months?
wyatt1209
Is there any idea of how long after the first run the LH351D run will happen?
JasonWW
JasonWW's picture
Last seen: 44 min 10 sec ago
This looks like your first post on this thread.
Click this to go to signature links.
raccoon city
raccoon city's picture
Last seen: 15 hours 15 min ago
I'm so looking forwards to this. Am I on the list already? If not, I'd love to buy at least one with the LH351D LEDs.
Yup, that's what I see as well.
Panoptic
Interested in 1.
Mikesch54
Last seen: 3 hours 50 min ago
Interested in two. if there are 2 variants of LEDs, please one each. I have already posted this in the German TLF, but the tread does not seem to live anymore.
Edit:
TLF Tread is going on. Please ignore this post
wheresryan
Last seen: 9 months 4 hours ago
I’m interested in one, thanks!
xborax
Last seen: 8 months 4 weeks ago
Interested in Samsung LH351D 4000K 90CRI version .
JasonWW
JasonWW's picture
Panoptic wrote:
Interested in 1.
Welcome to BLF. Give it at least a week for your name to be added to the list.
