So much to learn about, it’ll make you wanna shout…
Texas_Ace BLF Calibrated Lumen tube / Sphere No math skills needed - Several spheres still available
Eldon Hoke is rolling over in his grave right about now.
Congrat’s, You got the gig now.
I got 980-1026 lumen on my fenix tk15 1000 lumen light…
Maukka got multiple readings from the ROT66 219B after I pointed out an anomaly to him. I get a similar anomaly with my convoy S2+ lights and thats that’s why I won’t order one off him.
My Fenix PD35 performs very differently to each battery used to test it, I was expecting the opposite.
So far I’ve recorded between 1018-1102 ANSI
Delusion trumps reality
Every time.
Finally received my calibration lights after 12 weeks in the post. I’m sure it was misplaced as the light boxes were completely soaked and the shipping label was barely visible. Amazing it actually arrived.
Just want to thank TA for an excellent job on my Lumen Tube. Tested it against Maukka’s lights and it was only 8 lumens too high. Used another small strip of tape and it’s within 1-2 lumens on both lights. Not going to bother getting it closer.
Great! Really glad to hear that these have panned out to be as accurate as they have been overall.
I still have one sphere available if anyone is interested.
That’s good to hear. Do you know what correction factor that equals out to for your tube?
If it is possible, I would like to have the last one of the 3,5” tubes, the number 27. Is it possible?
Had an opportunity to use my Texas Ace Lumens Tube in a short review HERE.
And it was dead-on accurate with Zebralight's spec.
Yes, thank you for your post. There I read about the tube
I replied to your PM.
I was technically sold out but I looked through the leftover parts and realized I had enough parts to put together 2-3 more if I order the missing pieces. I should have 2 or 3 that can be put together if anyone else wants a last shot at these.
Have any of you tested a stock convoy L6 since calibrating off Maukka? Just trying to get an idea if my own numbers line up with others
Sorry, my L6 has long been modded.
If you want to send a light my way I would be happy to take some readings and send it back if you want.
I’ll charge up a couple 30Q’s and test for you. Before I received the calibration lights I wasn’t getting more than 2850 lumens and at that time it was reading slightly high.
I only just now saw this post. LOL! I wish my channel had the views that Blippi does!
I think the consensus was the CW was around 3100 to 3200. The NW was a bit less. These might be older readings, I’m not sure.
My L6 has long been modded. I did just recently buy a Thorfire S70S and test it out. It should be very similar in output to the L6 since the current draws are very close. I measured it at 2930 to 3000 lumen depending on the battery I used. Link is in my signature.
2770 lumens using 30Q’s with NW tint
My TA tube is within 1-2 lumens of the Maukka lights
