Finally
5000k?
Part number breakdown for those who are curious. The order code will typically have the last six digits F4RTS6, which covers a relatively broad range of forward voltage, color temperature, and output ratings.
There is also a reel specific code that refines those last 6 digits: F2R1S2
F2 = 2.8-3.0V (good)
R1 = Tint bin straddling the BBL, 5000-5300K (good)
S2 = 380-400 lumens at 1050mA (fair)
Specs sound good.
I try to test led with reflector and frosted lens to mix everything
CCT = 4830K (Duv 0.0025)
Color Rendering Index (Ra) = 91.1 [ R9 = 56.1 ]
R1 = 91.5 R2 = 92.5 R3 = 92.9 R4 = 92.5 R5 = 91.2 R6 = 89.6 R7 =
93.9
R8 = 85.0 R9 = 56.1 R10 = 82.2 R11 = 92.9 R12 = 72.3 R13 = 91.6 R14 =
96.6
without reflector Duv changes from –0.007 in center to 0.007 at edges.
Hi Andrey,
Are you still planning to offer LH351D 3.000K 90CRI? I would be very much interested into some of these, e.g. for a nice triple individual of 3.000K/4.000K/5.000K. :-)
Cheers, Thomas
Hi , Thomas
When I sold all 4000K and 5000K I will try 3000k)
When you planned send 5000k?
I can begin to send at Monday. But it takes to send PMs.
i sent but without respond
Hi Andrey,
What are the chances to get some LH351D 5.000K 70CRI with better bin than W6 and/or some LH351D 5.700K 70CRI?
Thank you for the measurement. This result is resembling to a Nichia 219C of the same CCT regarding Ra (R9 could be a bit better, R2, R3, R13, R14 seems to be marginally weaker, R12 is marginally better) - which is a good result considering, that LH351D has better efficacy, than 219C.
What current did you use for the measurement?
Sent two message without your respond.
I decided to give up buying from you.
I’m sorry I was on a business trip then I was sick.
2.5A
Hi, Thomas
As always it necessary to order 800pcs)
(I just noticed SPHWHTL3DA0GF4PQR6 is listed but it is out of stock , may be it will be available in near future.)
Thanks! not bad for 80cri level)
LEDs that are curruntly in stock:
1)351D 5000K 90cri tint F2R1S2 300pcs 1.7$
2)351D 4000K 90cri tint F2T7R2 20pcs 1.7$
3)351B 3000K 90cri tint D2V7H1 60pcs 0.55$
4)351B 3000K 90cri tint D2VAJ1 20pcs 0.55$
payment sent!
Answer in PM .
I will be offline till 09 January . All payed orders are shipped , I will PM numbers today.
Are the LH351D 4000k still available?
If he is out I still have some that I ended up not using I could sell.
