Definitely interested. Iāll buy the full light of I need to, but could I get an upgrade kit instead? At the very least that gasket, and whatever firmware you use to limit current on the stock driver so I can flash it. Maybe a link to that emitter.
Or if itās better for your cash flow to offer a driver+gasket+emitter combo like the GT70 did, thatās cool too, Iāll buy it haha.
A regulated D1S with the new osram emitter would be my ideal compact thrower.
I donāt guess Emisar will ever do boost driver lights because it wants to be an inexpensive brand though.
How much more expensive would it be to use a buck/boost driver? I would pay 20$ more. My guess is the other hesitation is that it would probably not have a ramping UI. If it was stepped ramping with good spacing, that would be good enough for me.
Also curious what the throw would be like in a D1 using this emitter
maybe 20$ more when using buck driver and white flat led, but not anyone willing to spend more 20$ than stock one
my wild guess this light is 5-10 bucks more expensive than stock d1s
Tried this led with D1. It simply doesnāt have good enough reflector. It top half and bottom half has a little different focal point whith doesnāt matter with larger led like XP-L HI. I played with focusing for hours.
It canāt get any better than this.
