I’m interested!
maybe 20$ more when using buck driver and white flat led, but not anyone willing to spend more 20$ than stock one
my wild guess this light is 5-10 bucks more expensive than stock d1s
I’d be interested in one and even more interested in D1 more throwy version!
D1 and D4 throwy version.
For sure will buy one. Also would like to buy centering ring and driver separately too.
What chromacity bin and flux bin is this emitter? Will you be selling these on your website?
As a suggestion, I would love to see a 21700 usb rechargeable version. Some of my less hardcore friends won’t buy unless it has built-in recharge.
I would be more than interested in a centering ring + driver kit.
interested
Definitely interested
Tried this led with D1. It simply doesn’t have good enough reflector. It top half and bottom half has a little different focal point whith doesn’t matter with larger led like XP-L HI. I played with focusing for hours.
It can’t get any better than this.
Jerommel:This LED begs for a current regulated driver.
That’s what I was thinking, but for time and money I would expect just a firmware limit on the same driver.
Yeah, i get the same impression…
And then you still need a topped up cell at 4.2 Volts to get maximum output…
Pavlo: fjass:A regulated D1S with the new osram emitter would be my ideal compact thrower.
I don’t guess Emisar will ever do boost driver lights because it wants to be an inexpensive brand though.How much more expensive would it be to use a buck/boost driver? I would pay 20$ more. My guess is the other hesitation is that it would probably not have a ramping UI. If it was stepped ramping with good spacing, that would be good enough for me.
Also curious what the throw would be like in a D1 using this emitter
Linear FET CC driver shouldn’t be much more expensive though…
Interested
Thank you for this, might of saved me some money and time.
Interested
ZozzV6:Tried this led with D1. It simply doesn’t have good enough reflector. It top half and bottom half has a little different focal point whith doesn’t matter with larger led like XP-L HI. I played with focusing for hours.
The D1S is good BTW. Much better reflector than GT mini.
Interested.
Judging by the picture, it seems the LED sits too far forward relative to the reflector.
I can see the beam get narrow half way and then get wider again.
Looks like you should try some extra shim between reflector and LED board.
interested
Just when I am about to order a d1s now I see this. I will definitely wait for this version.
Yes , I have all the others , so I gotta have this one !
