Interested.
Judging by the picture, it seems the LED sits too far forward relative to the reflector.
I can see the beam get narrow half way and then get wider again.
Looks like you should try some extra shim between reflector and LED board.
interested
Just when I am about to order a d1s now I see this. I will definitely wait for this version.
Yes , I have all the others , so I gotta have this one !
Trust me I tried everything.
If I move reflector up then the beam starting to get parallel-ish but the corona starting immediately getting huge amd brighter and the hot spot also getting bigger and dimmer. Like the reflector has two parabolic curve.
I canât explain it better. Maybe with this image help. This is with XP-L HI. The edge of reflector and the area around close to the led is in focus. But If I go farther the white area getting yellow and the yellow area near led getting white. With white flat it is more noticable.
Interested
Yeah, i believe you.
It just looked like that in the picture.
Hmmm⌠Doesnât look like it shouldâŚ
Any anomaly in the optics will become very noticeable with this Flat White 1mm².
I have the same problem with a narrow beam TIR optic i wanted to use for the White Flat 1mm².
Seemed to work well with dedomed XM-L2 but itâs a messy compromise at best with this little LEDâŚ
I also wasted a lot of time on trying to get it rightâŚ
I would have expected a better reflector in your Emisar though.
Interested.
I doesnât blame them. It designed for XP-L HI and it is perfectly good tor that. Maybe the big corona what show something isnât perfect But 48 kcd still very good for this size.
Perhaps try the 2mm white flat in it.
Iâll buy one.
I will buy some so I will try them in some lights.
Interested
Iâm in for one D1S+
Iâm in⌠Take my money!
LookâŚIâm waving money at you.
Oh no, we donât have a flashlight problem
Yes ! Totally interested in D1,D1s,D4,D4s with âwhite flatâ
he yes Iâll take one! #DoTheBLueAgain
