Yes , I have all the others , so I gotta have this one !
Trust me I tried everything.
If I move reflector up then the beam starting to get parallel-ish but the corona starting immediately getting huge amd brighter and the hot spot also getting bigger and dimmer. Like the reflector has two parabolic curve.
I can’t explain it better. Maybe with this image help. This is with XP-L HI. The edge of reflector and the area around close to the led is in focus. But If I go farther the white area getting yellow and the yellow area near led getting white. With white flat it is more noticable.
Interested
Yeah, i believe you.
It just looked like that in the picture.
Hmmm… Doesn’t look like it should…
Any anomaly in the optics will become very noticeable with this Flat White 1mm².
I have the same problem with a narrow beam TIR optic i wanted to use for the White Flat 1mm².
Seemed to work well with dedomed XM-L2 but it’s a messy compromise at best with this little LED…
I also wasted a lot of time on trying to get it right…
I would have expected a better reflector in your Emisar though.
Interested.
I doesn’t blame them. It designed for XP-L HI and it is perfectly good tor that. Maybe the big corona what show something isn’t perfect But 48 kcd still very good for this size.
Perhaps try the 2mm white flat in it.
I’ll buy one.
I will buy some so I will try them in some lights.
Interested
I’m in for one D1S+
I’m in… Take my money!
Look…I’m waving money at you.
Oh no, we don’t have a flashlight problem
Yes ! Totally interested in D1,D1s,D4,D4s with “white flat”
he yes I’ll take one! #DoTheBLueAgain
Yeah, the blue was definitely very… different…
but in a good way, in hind sight…
Didn’t appeal to me at the time though, but i’ve changed my opinion.
I am more interested in a more standard anodizing finish like that of the D4S instead of the chalky D1S.
Interested
Very interested!!!
