A MOSFET switch is the best option, but that currently is a total DIY solution. Alternatively:
- switch tests: KAN-28, update: stock switch UF-1405 in post#12
- switchtesting , (june13th2015:additional test by MRsDNF in post#44)
Cheers ^:)
Cheers ^:)
Mr. Barkuti, i see what you mean. I was looking at loneocean gxb172 driver and found this switch!
https://budgetlightforum.com/t/-/50404
Is this what you mean by mosfet switch? It looks like I can make my own with the files on the page. This looks like ideal solution. The KAN28 is too big to fit in some flashlight tailcap, but the 'small Omten switch" looks like it works OK even at 16A. Is anyone tried making mosfet tailswitch?
Is there bridging that can be done with a H1-A driver to set it to HIGH only mode?
I wish more drivers came with the “simple man’s” bridging stars.
Thanks
This is just a guess. It be better if someone more knowledgeable confirmed it.
In this post Buck and Boost Drivers, Testing, Modding, and Discussion (Pic Heavy) - #20 by Jensen567
Cutting the trace after the 47k resistor leaving the opa333 is my guess. In the datasheet tps61088 it shows a typical application where the voltage divider is by it’s self (fully on). I’m assuming the opa333 controls voltage the resistor divider is reading to control voltage feedback and modes from the pic.
Just a guess :question:
This could work but with how the remaining divider (R1, R2) is set up, it is only voltage regulated and it will put out ~6V and kill a 3V LED.
You’d have to set up the ILIM pin of the TPS61088 correctly.
With the stock 10k for R4, it means practically no current limit. This needs to be changed!
The H1-A driver changes mode only if less than 2 seconds have passed since last power cycle or so. Under normal operating conditions this means you can leave it at whatever mode, turn it off and on and it will remain the same.
As a tinkerer I can understand Funner's viewpoint but, is it worth such effort?
Bear also in mind that if you leave the driver with just one “high” mode, I advice you to select a current output your flashlight can handle without cooking the emitter or overheating above what you may consider permissible, even in tailstanding condition if applicable.
Cheers
The H1-A driver mods you all speak of is way above my modding level.
I didn’t know if there was a simple bridge or bridge/jump with a wire for this.
Thanks for the Knowledge fellers.
Happy Day All
Maybe, here’s the idea:
red = cut trace (or lift the MCU pin 5 off the board)
black = bridge wire
Current regulation would stay intact.
But what Barkuti says is correct, this means e.g. thermal throttling (idk if the H1-A does it) would be disabled too.
That’s exactly how to do it kikkoman. And yes, thermal throttling (if it does it) will be disabled on the PIC. Only the Boost IC overtemp. protection can then save it.
The PIC may use the EN line to shut down the TPS but I don’t even know if the PIC can sense temperature on its own.
Plus, I think LVP (cutoff, not throttling) stays intact, but the warning flashes at low voltage may disappear.
Sure. Surprisingly this is the best photo of H1-A stripped down I have, this is the driver without the inductor and MCU.
You don’t have to remove the inductor and MCU to do the mod, but it will be easier if you do.
You’ll need to cut a trace on the PCB where I drew the blue line (top right) and then connect your switch with small wires between the two purple circles. When the switch is pressed you are just quickly cutting power to the MCU as if a clicky were half-pressed.
Keep in mind since it is on-time last mode memory, if you have been on one mode for awhile it will need a double click to switch modes the first time.
Thanks for explaining the possibility to switch the H1-A with a momentary button.
I plan to switch modes with an external microcontroller. Basically i only need two modes (33% and 100%) and i want a microcontroller or bluetooth remote to switch through the modes for me. By chance do you know the voltage and current of the pcb trace, which needs to be cut? I could measure it myself, but the driver is still in shipping.
I drew out the schematic for the AliExpress LC15 driver for 12V 12W LED:
LC15 12V 12W
…or here:
“(There is also an LC15 6V 3A version)”:https://www.aliexpress.com/store/product/22mm-3A-3000mA-1-cell-5Mode-Boost-Driver-Circuit-Board-for-Cree-XHP50-XHP50-2-6V/113294_32853667712.html?spm=2114.12010615.8148356.20.522b14086QdjU2
…or here:
And here’s the LC15 PCB layout, front side:
And rear side LC15 PCB layout:
Here is an recent image from a H1-A driver ordered 01/2019.
I need to find a way to have only two modes 33% and 100%. Because i don’t have any idea how to program a PIC, i had the idea to use an external microcontroller to switch through the modes for me. The MCLR pin seemed to be a good solution. Pulled to the ground, the PIC should do a software reset. Therefore i desoldered the MCLR-Pin from the board and pulled the pin temporarily to ground. But nothing happens. The driver just works as before.
Besides a custom firmware, which would be great, do you have any idea how to get only two modes?
Here’s a driver which will run an LED from body heat using a TEG or Peltier stack. Input voltage polarity does not matter and I found it works well. Custom Thermoelectic and TXL Group sell these boards for $19US or you can get the unipolar version for only $14 (it has half the component count).
Here are pictures of the LC15 driver for which I posted a schematic a few posts earlier:
And here’s another energy harvesting driver which will run an LED off of body heat via a Thermoelectric Peltier or TEG, only 25mV required! The resistor and capacitor in center can have two different value pairs, depending on the design revision. The caps with question marks need to be pulled off the board and measured out of circuit. They’re 0402 parts! You can buy the PCB for only $12 from the usual electronics component distributors.
Hi, please do not post embedded images, as they cause server load issues. All of the ones in this thread were just removed. Thanks.
Hi, please do not post embedded images, as they cause server load issues. …
