If you want a pair of Lumintops EDC01 use the CODE: 2ndLUM to get them for $6.48/pcs
If you want ONE or 3 you better use my groupbuy code ;) – 2 pairs are again cheaper with the code above..
XP-G3(R5) 120LM
3 Modes
Mini Flashlight EDC
Keychain Light
Features:
1. Utilizes XP-G3(R5) LED with 50,000 hours lifetime.
2. 3 modes with a max 120 lumens output and an up tp 36 hours runtime.
3. Runs on one always available AAA Ni-Mh or Alkaline battery.
4. Compact and light-weight design, easy to carry.
5. Five colors optional, black, blue, pink, purple and golden.
6. Bead surface optical lens for soft and balance beam.
7. Glow-in-the-dark O-ring and optional diffuser easily locates the light in the dark.
8. Simplify twisty switch makes it easily access all modes.
9. Capable of standing up on a flat surface to serve as a candle.
10. Make of aircraft-grade aluminium alloy with wear-resistance painting.
11. Exquisite package fits for applications such as gifts, EDC, tools, etc.
12. 5 years free repair, limited lifetime warranty.
Package included:
1 x Lumintop EDC01 Mini Keychain Flashlight
2 x O-ring
1 x Keychain
1 x Diffuser
1 x User Manual
Martin, if you happen to get a nice code for the Nitecore EC30 that is about as good as the one for its predecessor (Concept 1) that would be just fantastic. :LOVE: Moreover, I would be very much interested in Nitecore's new chargers (UMS2 and UMS4). Cheers, Thomas
I would like to add that the SC04 would become much more interesting if they sold it with SST-20 5.000K 65CRI, i.e. SST-20-WDS-A120-L2501(L3-VK-DA). The 6.500K is known to be extreme cool white whereas the 4.000K 95CRI would not make sense to me in a thrower as HighCRI is more useful on close distances and as its efficiency is significantly worse than the 5.000K 65CRI.
Spotted a minor fault in the codes listing. For the NItecore MH12GTS, you’ve got a thumbnail image for an EC4GTS (it’s a repeat of the one right above it).
