Low-cost copper pills, spacers, optics, drop-ins. Custom parts.
1679 posts / 0 new
Agro
Agro's picture
Last seen: 1 min 31 sec ago
Dunno maybe it wouldn’t. But the stock driver is very thick. And I have a similar construction by CRX in a Thrunite host, so that was an obvious inspiration. 3s 10160 is an option too. Wink
Agro
Agro's picture
White Flat would need a SMO reflector to really perfofm. And bezel is quite thick. Though low Vf is interesting. Anyway, not for me, I want a pee light, ideally with 1000+ lm. Wink
KyleGates
Last seen: 1 hour 40 min ago
Just received two Copper P60 Quad shells. Excellent quality as always, awaiting parts to build with.
Lightbringer
Lightbringer's picture
Last seen: 15 min 11 sec ago
Yeah, dunno if I mentioned this when I got ‘em, but the pills for S2+ triples came in perfectly, nice sturdy box to hold everything, and shiny! LOL
MikeMacD
Just received my S2+ copper pills. Thanks!
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 3 days 20 hours ago
Hi Kirill, do you offer Convoy C8/C8+ retaining rings?
“Everyone, deep in their hearts, is waiting for the end of the world to come.” (Haruki Murakami, 1Q84)
kiriba-ru
kiriba-ru's picture
Last seen: 20 hours 50 min ago
Im sorry I cant find C8 pill ATM.
Does C8 rings interchangable with S2+?
SeniorXJ
Last seen: 3 months 4 weeks ago
Have you started a batch of copper S2+ full triple pills yet?
kiriba-ru
kiriba-ru's picture
Sorry, dont see it reasonable since Hoop’s pills will be available soon.
SeniorXJ
Do you have a link to Hoop’s pills please?
kiriba-ru
kiriba-ru's picture
SeniorXJ
SKV89
Last seen: 12 min 17 sec ago
Received a large order from Kiriba-RU. Everything looks good as usual. Thumbs Up
Dmitriyrus
Last seen: 1 week 3 days ago
I just, quite accidentally found out about the existence of “C8TT”. This is very, very cool!!
Yokiamy
Yokiamy's picture
Last seen: 12 hours 35 min ago
kiriba-ru wrote:
S2+ single pills are ready.
They have slightly non-standart design (I was not 100% satisfied with current design custom rings, have developed new version that required pill changes) with deeper retaining ring thread. New rings are not ready yet, but you can use them with regular convoy rings or previous custom rings. Havent checked yet but I suppose even convoy rings will allow using 2-side 7135 drivers.
2018-10-24-14-46-42
Do you have more details about this? It looks really nice, but i don’t see how to use it
kiriba-ru
kiriba-ru's picture
Im building big belt grinder. It took very long time, same time Ive made a batch of parts that allow use angle grinder as belt grinder. I could not wait longer to try 3M green belt in some difficult job so I temporary set my battery powered angle grinder as belt grinder and tried to sand flat C8’s stainless bezel. Tiny machine dont work as good as big one but anyway it didnt take much time.
Regular SS C8 bezel sanded flat with some laser engraving. How to use it? Probably will make another one for special C8TT set for 2k post GAW.
contactcr
Last seen: 2 hours 53 min ago
I’d be in for a flat one
Yokiamy
Yokiamy's picture
Looks nice Kirill !
I have done it myself some time ago…
SeniorXJ
Does anyone make a more narrow optic that fits your heat sink head?
This one is a bit too floody for me. I would like to mimic the beam profile on the stock convoy C8 with an orange peel reflector.
Thanks
kiriba-ru
kiriba-ru's picture
If you are searching plug and play decision – no, noone.
I think blf members have build several thousands of lights using cute-3 optics. Somebody used to sand optics top flat and polish it clear.
Another optics (angie-s) do exist but:
1) Im not sure it will give more throw
2) It have different diameter and height
3) the only place where you can pcb for angie is led4power.com. If you want to try you can ask Neven about suitable hosts and parts…
kiriba-ru
kiriba-ru's picture
Mike C wrote:
Still interested in Kiriba-ru’s pin solution for single LED MCPCBs. Care to share?
Edit: This is thread hijack… I’ll start this discussion elsewhere. I can at least gather from here that there won’t be any Led4Power MCPCBs with holes.
My thread is always open for such offtopics Mike.
This is not solution, just experience with multi-core vs solid core wire.
Multi-core wires were developed to use in moving construction, or when it is necessary to pull wire through some angled tube so it should be flexible.
If you need to solder and you have limited place for the connection, multi-wire is not best choise. Imagine that solder layer smallest thickness is limited (lets say 0.05mm) and each core is surrounded with this solder. It makes no sense in mechanical or electrical connection, just takes spare place.
About practice:
Can you find some lacquer insulated wire from old ac/ac transformer/motor/stator etc? You can open (scratch out coating) copper core just from one side and use a tiny amount of solder paste. Nothing compared with multi-core wire when pcb pad is always fully covered with solder. This way you can move your connection closer to the pcb outer border.
If it is not enough and this wire still contacts reflector, you need some custom contact piece (for example, nickel plated copper contacts that wires are crimped by in automobile) so your contact could be wider but smaller height (same area but more distance to reflector).
In few words, any solid piece of brass or copper can be more usefull than flexible multi-core wire if you need to limit solder covered area. For sure you need to solder (crimp) another wire to the end of this contact piece, but probably there is more place on the side neither under reflector.
P.S. Technical lacquer (for repairing transformers/motors/stators etc) is not rare item and can be easily found. DC power require times less insulation properties, probably thinest layer over custom contact/refletor bottom can help to avoid short-circuits.
Mike C
Mike C's picture
Last seen: 1 day 9 hours ago
I’ve seen Old Lumens similar solution here: http://budgetlightforum.com/node/33061, and Cereal_killer mentioned using battery contact tabs. I can do these things, and I’ll try drilling too, but ultimately I’d be much more happy if I didn’t have to. Just a plan wire through a through hole, just like those cutter MCPCBs but for single LED MCPCBs would be perfect. It would make everything so much easier, I don’t see any good reason as to why MCPCB manufacturers haven’t made them.
kiriba-ru
kiriba-ru's picture
I suppose manual soldering is not something big manufactures are thinking about, so technilogies are moving to the other side. Small connectors, point welded nickel strips, tiny laser-welded pins etc.
Not sure through hole is best solutuon, most would like rather big hole (like 2mm), if hole in shelf or pill is 2.5mm it leaves just 0.25mm to sides. If you are assembling light with wires as short as possible and fixing driver first and that soldering pcb, there is no ways to look and check if there is no solder leaked through the wire hole.
P.S.
I suddenly invented perfect decision which can fix two problems – pcb rotation and solder point under reflector bootom.
PCB with two extra half-circles protruded outside. With solder pads on them (outside reflector bottom).
Cons: you will need dremel and mill two cuts.
33618258284-f64934b859-c
Mike C
Mike C's picture
Should be easy enough to check for shorts, just put one DMM probe on the pill/head and check for shorts by probing each LED wire solder blob.
Yeah, that’s the downside. I’m interested in a solutions that require less work. Your design is for custom MCPCBs anyway, if your going to go custom I’m still convinced that two through holes in place of two of those wire notches would be an easier solution. If people can successfully drill their own holes and solder without shorts, soldering with pre-existing holes should not be an issue. But yeah, I have to put my money where my mouth is and try drilling first.
kiriba-ru
kiriba-ru's picture
Through isolated hole in metall core pcb is another technology.
It took many years to move from fr4 to metall core.
And several more years from metall core to DTP.
How long will take next step? Nobody knows…
n10sivern
n10sivern's picture
Last seen: 3 weeks 3 days ago
Any X6 copper or aluminum heat sinks available?
Three tomatoes are walking down the street- a poppa tomato, a momma tomato, and a little baby tomato. Baby tomato starts lagging behind. Poppa tomato gets angry, goes over to the baby tomato, and smooches him… and says, Catch up.
MtnDon
MtnDon's picture
Last seen: 1 hour 48 min ago
For a triple? Those are listed inthe first poet of the topic
n10sivern
n10sivern's picture
I didn’t realize it. I PM’d him.
SeniorXJ
Is there any chance of you making an S2+ triple copper pill? The other guy still hasn’t made them yet.
kiriba-ru
kiriba-ru's picture
There is a chance but I dont want to name any date right now.
