[Optisolis/E17A/E21A] Jetbeam Jet-µ
292 posts / 0 new
DavidEF
DavidEF's picture
Last seen: 14 hours 3 min ago
Thanks for being cool clemence. Cool
Sorry for the off-topic about color LEDs. I can’t remember what I voted now, so I will go ahead and cancel my vote, whatever it is, and make it for the E17A/E21A choice. So, my vote might be changing, or it might be staying the same. We’ll see. Silly
- The YKK Philosophy
clemence
clemence's picture
Last seen: 2 hours 8 min ago
Friends,
Couldn’t decide myself. So I made both version: the Optisolis and E17A/E21A.
The prototyping is done with better result than expected. Looks like months of various TIR optic shopping is now paid off. Optisolis is finally flashlight enabled with correct TIR optic. This is the pickiest LED I’ve known so far. No reflector, no plain TIR optics, even the micro lensed (peebled) TIR optics choices are limited to only few. While wide angle optics be it reflector or TIR will fix the ugly beam issue, to get usable beam angle narrower than 30° is quite a challenge.
I haven’t test the E21A version as it will be so much easier. Let’s take a look at below pics and video:
Quick test at white wall (Optisolis and 30° Microlensed TIR optic).
Stay tune for more test results!
EDIT: forgot to include the output
Preliminary test result using sm505 P9 Optisolis:
OEM Cree XPE2 [unknown bin and CRI]: 96lm – 18lm – 1,3lm (advertised as 135lm max.) Flat Stare
- some artifacts (stock TIR optic)
Optisolis [p9 rfa00]: 65lm – 13lm – 0,9lm
- limited to 30° micro lensed TIR optic only, the rest cast ugly unusable beam
E21A [D240 sm653 R9080]: 65lm – 14lm – 1lm
- very throwy, the hotspot is only half XPE2
- super nice beam without visible tint shift and no artifacts (stock TIR optic)
It’s interesting that at 230mA, the efficiency of Optisolis matched E21A R9080 very closely
- Clemence
Pavlo
Last seen: 2 hours 17 min ago
Looking forward to the final options!
Perfectly regulated, efficient, and best Tint and CRI, what is there not to love??
maukka
maukka's picture
Last seen: 1 hour 14 min ago
Superb! Can’t wait to get one of those Optisolis EDCs. Or maybe a 2000K E21A, or both…
clemence
clemence's picture
Below is the runtime test with stock plain optics except for the Optisolis which used 30° peebled TIR optic. The E21A still needs some refinement as it’s so thin and sunk 0,7mm below the optic’s holder (centering ring). This make it outputs less than it supposed.
The Optisolis as expected, with it’s higher Vf has the lowest runtime. The warmer Optisolis will have longer runtime for their lower Vf.
This new generation Jet-μ is very good at maintaning almost flat regulated output. Although measured less than advertised 135lm, it’s still very good at 94lm for almost an hour! E21A with it’s lower voltage gives ~2,5 more minutes. With D320 E21A (R70 unfortunately) we can get the same output.
Beamshots (1 meter from the dirty wall, each marker are 10cm apart, 5600K WB):
- Clemence
Tjohn
Tjohn's picture
- Clemence
Gadzooks!
The Jetbeam bosses must be wondering how to put Mr. Wizard on their payroll !
clemence
clemence's picture
Another run time test. This time uncooled (previously was fully submerged in a room temperature water bucket). Started in an air conditioned room at 24°C – 25°C. The light temperature only reached feverishly warm (I just made up this term… Silly ).
Higher die temperature lowers the required forward voltage. Here we can see less than 5 lumens output decrease and ~7,5 minutes longer regulated run time. I spoke to Maukka, about the possibility to make me another standard measuring lights with several CCTs using this Jet-solis.
Next: Optic improvement for E17A/E21A version. I need to bring the LED 0,7mm higher to at least level with the plastic centering piece. Not just the centering peace block the light, I also suspect the photon bounced between the LED and the optic centering piece was heating the LED, reduced the output.
- Clemence
staticx57
Last seen: 16 hours 16 min ago
This is amazing!
Random Dan
Last seen: 1 week 5 days ago
Great work! I’m looking forward to an E21A for sure, maybe even both.
adam7027
Last seen: 4 days 2 hours ago
I will surely take 3 different CCTs of Optisolis (6500K, 5000K and 4000K or 3500K).
Again, I am too weak to resist.
jon_slider
jon_slider's picture
Last seen: 8 min 1 sec ago
Hard to go wrong with Clemence.
My most used lights:
l-r E21A, N219b 4500k, N219b 4500k
clemence wrote:
Green beacon is very eye catching from afar.
Yes, a Slow Green campsite beacon in Rural Jungle seems fine.
As a pedestrian, or cyclist, in the Urban Jungle, I would want Fast Red or Fast White flashes.
aswang
Last seen: 6 days 17 hours ago
Lovely work Clemence. I’m starting to love my Sofirn C01 and I’d definitely get this. E21A 2000K and optisolis 5000K would be my first choices for this light.
Tjohn
Tjohn's picture
For a better idea of what has been accomplished, comparisons can be made with the review UPz provided.
Optisolis 5K 9080 output similar to a Nichia 219B sw45 92+ Cri …but with better runtime and final slope.
Truly a well executed labor of love from our Mr. Wizard !
http://budgetlightforum.com/node/38081
clemence
clemence's picture
Thanks Tjohn =)
BTW, I made some optic refinement for the JetE21A and still doing a runtime tests between packing the orders. The beam pattern is now looks almost similar to stock Cree XPE2 and the output increased to about ~10ish lm (will measure it again). The LED also runs cooler now. Will report back soon.
Happy saturday night guys
Jerommel
Jerommel's picture
Where did you get those nice little LED boards?
clemence
clemence's picture
I grow them in my backyard LOL
No, I made them of course. But this only designed for up to 350mA. Just normal good copper MCPCB. At this power level even the stock aluminum non DTP MCPCB already more than enough. I made them with copper because I am pretty sure you guys will question me if it’s only aluminum Silly . In my test, it’s shows no measurable difference at all (Cree XPE2 250mA current).
- Clemence
Jerommel
Jerommel's picture
I hope you will ‘harvest’ enough of them so i can buy a few too with my next order.
SKV89
Last seen: 59 min 30 sec ago
Tjohn wrote:
For a better idea of what has been accomplished, comparisons can be made with the review UPz provided. Optisolis 5K 9080 output similar to a Nichia 219B sw45 92+ Cri …but with better runtime and final slope. Truly a well executed labor of love from our Mr. Wizard ! http://budgetlightforum.com/node/38081
Thanks Tjohn, that really puts it in perspective. The 219B used in the Eagtac judging from the Eagtacs I own, are not even 9050 because I have real 219B 9050 to compare with. I think those are just 219B 9000, which is usually much more efficient than the better color rendering, better tint versions. What Clemence is making is absolutely amazing since the 9080 or more like 9090+ Nichias will look FAARRR better and still offer about the same or better efficiency as the 219B Eagtac.
clemence
clemence's picture
So far I recorded 74lm (79,11lm at start) for 1hour 3minutes uncooled for the Jeteria (JetE21A)
- Clemence
Tjohn
Tjohn's picture
SKV89 wrote:
………..that really puts it in perspective. The 219B used in the Eagtac judging from the Eagtacs I own, are not even 9050 because I have real 219B 9050 to compare with. I think those are just 219B 9000, which is usually much more efficient than the better color rendering, better tint versions. What Clemence is making is absolutely amazing since the 9080 or more like 9090+ Nichias will look FAARRR better and still offer about the same or better efficiency as the 219B Eagtac.
…..to further your point even more, I used to think my Eagtac MX25L3C Nichia had much better tint, until Clemence drop shipped the first Group Buy of sw45 9080 Nichia leds via Texas Ace, before his Bali store opened.
Those jewels make my D25aaa and Eagtac Nichia 6 led thrower look mucous yellow-green in side-by-side comparisons.
Indications are Eagtac looked for above the ANSI BBL stock for more lumen output, since according to Clemence, above or below was formerly the typical manner in which Nichia offered their sw bins.
teacher
teacher's picture
Last seen: 1 year 3 days ago
I just found this thread & happy I did. I love this little AAA light, & have one in my pocket all the time.
Looking forward to this one….. Thumbs Up
clemence
clemence's picture
Still testing the runtime for the third time. There’s something weird going on here.
The JetE21A output vary between 74lm – 79lm between lights. This is OK because I measured the current output vary from 230mA to 245mA, and each LED’s output also slightly different. In theory and observations, hotter LED will have lower forward voltage, correct? This usually results in longer regulated runtime albeit reduced brightness. This apply to either boos or buck driver. But in JetE21A the case it’s the other way around: uncooled (much hotter body temp) results in LESS reduced output over time and LONGER runtime! This is weird
Can someone help me explain this?
- Clemence
maukka
maukka's picture
I don’t know what could cause it but I experienced something similar with a Lumintop Tool AAA. Output was higher and more consistent without cooling. Runtime was longer just like in your case. After I turned a fan on, the output dropped following a slight increase in output. Maybe it does have something to do with the Vf being higher with lower temperature.
clemence
clemence's picture
One possible cause could be the Eneloop drains more at hotter temp. The tube temperature was 40 °C. Anyway, this is an unexpected benefit in hot wheather. But expect reduced runtime in colder temperature. Did you use Eneloop in your test?
- Clemence
maukka
maukka's picture
Yes, it was the normal white Eneloop.
clemence
clemence's picture
Hmmm looks like better NiMh chemistry in hotter temp is the case. For the Jetsolis the voltage could be too high for the boost driver that better battery chemical reaction is not enough to boost the runtime.
- Clemence
maukka
maukka's picture
Maybe test it with a bench PSU.
clemence
clemence's picture
Yup, that’s what I thought too.
- Clemence
Noir
Noir's picture
Last seen: 1 week 3 hours ago
Standardized testing of batteries is done at 20°C to 25°C, but most batteries (including NiMH and Li-Ion) actually work a bit better at higher temperatures. At temperatures of around 40°C to 45°C (or even up to 60°C) the voltage level is higher and you get slightly more capacity and a decent amount more energy out of the cell. This info is unfortunately not in the Eneloop datasheets, but I found a graph which was on the eneloop.info website back in the day.
Some datasheets of Li-Ion batteries (e.g. the UR14500P datasheet) have such a graph included.
While higher temperatures are good for getting the maximum out of the cell, they are also detrimental to the life of the battery, but that is of course a different topic.
clemence
clemence's picture
Thanks Noir, that confirmed my suspicion. It’s good to learn new things. I will use the cooled runtime for base reference then.
- Clemence
