Is it too late to make the FW3A into a wifi hotspot as well? That’d give us the need for even another button and would be so cool in a flashlight. I’ll bet nobody has ever thought of that. That would rule.
There’s no market for it since you can already do that with your phone.
I recall Imalent released a variable color temperature light a few years ago that sounded pretty cool. It had 2 emitters: one at something like 2700K and the other at 6800K. Supposedly you could smoothly change the color temperature of the light with a touchscreen slider. The light varied the tint by dynamically changing the output of each emitter, with the result that the light could output any color temp between the two emitters.
I wonder if someone could do something like that with a BLF light. Might be pretty cool.
Well……fine then. There must be some kind of ……………
No, there isn’t………….there’s nothing you can’t do with your phone, is there? I stand corrected.
Not everyone is aware that there used to be some flashlights controlled by Bluetooth a few years back. You could remotely turn the light on and off, adjust the brightness, change the settings such as strobe rate, the number of brightness levels, have “dico” mode, etc… It seems pretty cool, but the one light that I’m thinking of didn’t actually sell very well because the flashlight itself was not very good. Then you have the problem of the company needing to keep the app updated. Eventually you’ll lose the ability to control the light through the Bluetooth and then you’re stuck with a really expensive regular flashlight. Even in 2019, I’m not sure there is a market for Bluetooth controlled flashlights.
Sorry for off topic.
Sign me up!
I’d be interested in 1 LH351D.
Imagine if a BLF light could do all that, but it didn’t require a phone, and it would be available soon.
Not sure how much longer until it goes to production, but I think the goal is to do it before CNY.
IIRC, the touch screen was built into the flashlight. No phone necessary.
Here we go, the Imalent SA04.
Reviewed by JohnnyMac 2014.
Sign me up. Thx!
I’m interested too. Thank you!
Im currently on the list for one light, i guess the xpl hi is choosen by default?
So i want one of each.
Please also add me to the list for one LH351D. Thank you.
In for one, Samsung LH351D 4000K 90CRI.
Thanks!
I posted before, but don’t see my name on the list. I’m in for one of each. Thank you, and I’m sorry if you just haven’t got around to updating the list yet.
The list hasn’t been updated yet !
When it is, your name will be on the list :+1:
Please put me down for an FW3A with the Samsung LH351D 4000K 90CRI emitters.
At some point once the multi-button UIs and drivers are done I’m sure varied emitter tint lights with tint ramping will be a thing. Its already a reality with the Zanflare T1 (despite the obvious differences there), I dont see any reason it couldn’t be done in a regular flashlight other than some possible weird beam profile.
Like the Jetbeam FL-12? It essentially ramps the two different LEDs up/down inversely to control output from 3000k to 5500k.
FWIW, the Viltrox L116T is a nice high-CRI light panel which can be powered by a wall adapter and mounted on a gooseneck thingy or tripod. It adjusts from 3300K to 5600K in 100K increments, and stays below the BBL the entire time.
Can also be battery powered, but I don’t use it that way.
I’m already on the list but should I clarify which emitter now that there’s two choices?
If so I’d like one of the LH351D 4000K 90CRI please.
Patiently excited!!
