It has to be an e-switch driver for the Emisars.
I think Lexel may have something available.
I’m still waiting for led4power’s e-switch version of his FET CC driver…
But iirc Emisar uses 20mm drivers?
Either way, i’m guessing there are a few people on BLF who would be more than happy to come up with a suitable driver and PCB layout, if Hank can’t find a solution.
Yep, the e-switch is the issue for those drivers. If the driver designers didn't take into account parasitic drain, an e-switch may never work on that driver design.
Again, our ramping UI's should work fine with a 7135 bank + 1, or even without the +1. I got NarsilM working on a FET only driver because the 7135's were constantly getting blown - yes, lots of amps for 16 XHP50's...
With a flashlight that uses a direct driver like the D1S you need to add resistance, by using a high resistance battery (the GA is still too low resistance/high current perhaps a NCR18650B works) and using long thin led wires if you can get the driver out. If you are handy and smart enough to find a spot for it, you may be able to add an actual resistor somewhere in the current path. Unfortunately Hank’s springs are very low resitance, maybe swap the copper-alloy tail spring for a steel spring. Experiment, keep measuring current and see if you can get to 5A or lower.
I asked him refarding the d4s already. He said the beam doesnt look right. Would be awesome if he can get them in the meteor though. Love the focused beam.
Also Hank, please sell the oslon white centralizers on your store.
