Wow! Has another stock driver been designed with more consideration for mods after buying? I may or may not get a BLF Lantern, but I certainly hope this trend in driver design continues!
75017525.pdf
1519.80 KB
No, I think that the switch LED, called indic is driven from pin 3 of the MCU, via a fixed R_indic.
The pot is associated with something different called loc. LED, and can either be permanently powered by R_loc, or instead via POT_loc and thence supplied either permanently or by a connection to the powerbank inductor, solder-splash jumper selectable.
The Loc LED circuit is shared with the remote thermal sensor pads, so with suitable configuration could drive some thing else. I see a lot of experimental ideas going on here.
It would be a lot easier to understand if Lexel would just publish a schematic diagram, and maybe a brief technical description.
the loc. Potentiometer and the resistor for it is simply connected to batt+, not sure if it will be fitted or wired to the internal switch at this point,
but having it there for user mods does not hurt
same with the NTC, it can be used without the high resistor as an addiotional LED output whatever in the firmware gets supplied
MTN uses NTCs on his firmware builds a lot why no add it to the firmware later
I voted to fit an NTC pads to the PCB it cant hurt there, even if not equipped
right now there is it on the driver it cant hurt even if its possibly not used in the final production light, but may find modders to get it working
Thank you for the clarifications, and it is very ingenious. Thank you for putting in so many innovative ideas and possibilities for further development. The large area of the driver allows so many more things to be used, or trialled, thank you for filling it up with yours.
Just one point, for accurate temperature sensing the last thing I would use is an NTC. I referred to “PTCs” because that is something easily understood, but what I really meant is silicon diodes using base-spreading-resistance to measure temperature.
Which have PTC characteristics, but are quite different. I provided a steer to a good source, many of the world’s best car manufacturers use these particular components, for good reason.
Here is another steer:
1519.80 KB
Please add me to the interest list for one.
Ok, -a thanks go out to member SKV89 for sending me four of Osram’s High-CRI emitter to test in the V1 BLF lantern prototype. (I use the V1 as the test-mule for measuring outputs, tints, etc of LEDs for lanterns)
The four LEDs sent to me for testing are the Oslon Square LCW CQAR.CC MQ-6U-L2 , MQ flux bin, 6U tint bin, and L2 forward voltage. MQ = 194 lm – 210 lm 6U = 2700K L2 = 2.90 – 3.00 V ) emitters.
They are a smaller substrate foot print than the 3535 XP sizes, ( more on the 3030 size, but they will flow onto a 3535 Cree XP board with no problems as i measured the center thermal-pad to be the same width, just the + & - pads are narrower on the Olsons.
- First positive i noticed is that the Osrams as nearly no angular tint shift, almost similar to the Nichia 119 or 219 series, but more efficient per amp input. (As almost all Cree emitters have very bad angular-tint shift, except for the MT-G2) the Samsung 351 series has almost as bad tint-shift, while Nichia and these Osrams has almost none, which is a great thing for a lantern to have full natural light tint consistency from all viewing angles.
For those wondering what angular tint-shift is, if your familiar with the horrible green tint caused by the original shallow-angled reflector Olight S20 then you know, or see this topic to understand: The CREE "Angular-Tint-Shift" flaw syndrome..It's causing brain damage.
The Lux output at 1 foot is comparable, (Samsung 351B > 42 on Medium , 167 on High) ( Osram > 43 on Medium, 165 on High)
as for tint to the eye, the Osram is much more “natural” . The Olson Square 2700K appears to my eyes as the closest light tint to what of a 25 ~ 40 watt Incandescent light bulb, probably due to the very slightly warmer tint, but much better tint emitted from all angles of the lantern, (less angular tint shift) than the Samsung 351B 3000K.
If i had a choice to have the production BLF lantern to have for the warn tint channel, it would be to use these Olson LEDS for the warm tints. I don’t know if they have a larger 5000K version, but the best 5000K tint LEDs to use for the cooler-channel is still the Samsung 351D 5000K, but definitely these Olson Square 2700K, as i really like the linear tint form the light angles.
As seen below, the greens & reds and ever other colors seem to just stand out much more natural from these Olson 2700K than it does from the Samsung 351B 3000K. (photos take with lantern on medium mode)
Yeah Den, keep teasing us while we patiently wait for the lantern
Those osrams are special for sure!
I’m surprised that Oslon Square 96CRI compares so well to the LH351B in efficiency because the color rendering is so much superior to the LH351B. The R9 is a whopping 96. This has the best color rendering of any emitter I’ve seen besides the Optisolis. I really hope we will see this emitter in the production lantern.
Here is the test result someone posted for the Oslon Square 96CRI 2700k
Here is the test result for the LH351B 90CRI 3000k by Maukka. The R9 is only 70 and it has an above the BBL DUV of 0.0023, which puts it on the green side.
Depending on price, i would like 5 of them….if that’s ok
What is the Duv of the Osram? Generally it’s typical for warm LEDs to have a lower Duv compared to neutral ones.
I would love to know too but comparing with my other WW emitters, it’s definitely not above the BBL. Its one of the best WW tints I have seen and I have seen about a dozen or more
I am very impressed with the Osram emitter. From my testing of the ones you sent me, the output for the same amp-load is roughly the same as the 351B, but i do like the more natural rosier tint better of the Osram, because it just looks more “natural” and a better replication of an incandescent light bulb than most others i have tested. Barry of the factory also told me that those Osrams are easier to get in large numbers than other High CRI warm white LEDs, so it may work out. ( to have the Osrams as the warm-channel at 2700K and Samsung 351D 5000K (or Cree XP-L 5000K) for the cool channel as a reserve LED if the Samsungs are hard to get. (with nearly 1400 BLF lanterns awaiting to be bought, Barry’s factory has to order 5000+ of each for the warm channel and 5000+ for the cool channel.
Here is a close up comparison to what the Osram Olson Hi-CRI 2700K to the Samsung 3000K 351B ( the 351B as a smaller die than the 351D, so it compares better to the Olson die size, or somewhat to the very in-efficient Nichia 119 smaller-die series which can’t match either the Osram or Samsung variants in the 2700 to 3200K color range for lux output versus amps-load.
Below the samsung 351B on left, and Osram Olson Square on the right: ( lantern was on medium-mode, both pulling 0.74 amps from the four 3600mah Panasonic cells, (roughly 0.18.7 amps per cell, so tested to give a run time of roughly 27+ hours of light output equivalent to a 25-watt incandescent light bulb on one charge.
Update to the interest list, the next 10 entries:
1132 Plotthound
1133 niktak11
1134 ZozzV6
1135 ZozzV6
1136 jaharkes
1137 kntx
1138 kntx
1139 kntx
1140 kntx
1141 kntx
1132 Plotthound
1133 niktak11
1134 ZozzV6
1135 ZozzV6
1136 jaharkes
1137 kntx
1138 kntx
1139 kntx
1140 kntx
1141 kntx
Thanks OP list updated!
DBSAR,
Here’s the source of the measurements.
(binned above the BBL)2nd generation square 3000k 95 CRI:7 pieces OSRAM OSLON® Square LED 3000K CRI 95 2W HIGH POWER 3030 GW CSSRM1.BM | eBay [image] [image] (binned below the BBL)1st generation square 2700k 96 CRI: 7 pieces OSRAM OSLON Square | 2700K | LED 3030 | CRI 96 | 2W | LCW CQAR.CC | eBay (binned below the BBL)1st generation square 3500k 96 CRI: https://www.ebay.com/itm/7-pieces-OSRAM-OSLON-Square-LED-3500K-CRI-96-2W-HIGH-POWER-3030-LCW-CQAR-CC/282084772891 [image] [image] [image] …
The reason these are so good are the tint bins. These are analogous to a 219B SW45k. Tint binned on and below the BBL.
If Barry can get these awesome bins I’d be one happy camper. I :innocent:
DBSAR,
High CRI leds, comparing R9 values, XP-G3 N219c N218b XM-L2 XP-L2 - #67 by staticx57
Thanks for the link. Either way, the tint and color rendition of these Olson 2700K LEDs are the best pleasing natural warm white i have seen & tested so far from any LED to be as be close to a Incandescent bulb light, or light from a Coleman gas lantern to the eyes.
Cannot wait for this to come to out, especially if the Osrams make it in.
I think we are looking for a recommendation for a 5000K Osram LED as well, chime in if you have a recommendation.
Please add to interested list x1
