I would like it w/50.2 or SST 40, 21700 and Narsil
Simon Mao: Yokiamy:Maybe we should open a new thread with requests, to see what people like. On this way Simon can see what might be a succesful lights. We all love convoy, since it it is proven quality an its mod-ability friendlyness, with a bunch of spare parts to change the light to our wishes. I would like for example a single cell light like a Emisar D4 from convoy, with Narsil UI but with a smooth Stainless steel bezel (like the Jaxman E2L.) It would be nice to have the option for multi or single emitter with optics or reflector (like Emisar has multiple choices) Or something like a XHP50 on a single cell from Convoy with a new sleek design. Regards Pieter
i’m ready to launch an new model ,single cell ,XHP50.2 it seems not meet your requirement,I can refer to your request and design an flashlight with side switch and stainless steel bezel and type-C port, what battery are you ready to use?
any link or information about Narsil?
i dont know this firmware
Release v1.3: Here's the latest NarsilM v1.3 files: https://drive.google.com NarsilM v1.3 You will find a readme.txt file listing the .HEX pre-configured files there. Please note v1.3 has no changes to the UI, therefore earlier manual revs still apply. Here's the revision history for v1.3: Vers 1.3 2018-08-11: - make SaveConfig() safer by disabling ints, ensure 0xff's get written in old position, using library routine first eeprom writes and not using eeprom erase - limit mode…
I don’t have any 21700 cells, but i can Imagine those cells will be good available in a short time.
For now i would be happy with 18650.
Usb recharching is not a must, but a nice to have, i can Imagine people find it useful. Personally, i’d like to change cells myself.
As you can read in all above reactions, people love lights with an electronic sideswitch and Narsil firmware.
For more info about Narsil please ask Tom E or Toykeeper (both respected BLF members)
They will be more then happy to help you if you ask them.
Nice light Simon!
Hi, it’s possible to buy the Nichia version with S2+ Desert Tan model?
I don’t find charging circuits in flashlights useful. Flashlights are bigger and less waterproof. It’s easier to swap a battery and continue using the flashlight.
Simon, what about L2 with side switch? Many users would be very happy.
I am curious about this new light :o
that light looks interesting with the xhp50.2 emitter, so probably a very floody light?
In Simon’s video here:
It appears the BD03 might have an e-switch in the tailcap due to the battery carrier device. Is this the case? If so, we could put a nice driver in this one.
This looks great. 21700 with Type-C recharge will be awesome! Can we request that the driver is separate from the USB C recharge so it can be replaced? I’m sure many people will like to mod this flashlight with spacer and quad emitters.
Also, would be nice if you can come out with a 21700 S2+.
yes,and what driver and reflector?
It depends on personal habits.
Similarly,some are used to tail button, some prefer side switch
only side switch ,no tail switch,right?
yes, floody,it couldnt be a thrower because the diameter of the head is not big
Ryzbor:Great to see you on BLF Simon!
Nice you started offering high-cri convoys. However most producers seem to implement the SST-20 or LH351D high-cri leds instead of the somewhat oldish 219C.
Imho the OP reflector should be by default in the S2+ instead of the SMO since the S2+ is an allrounder/EDC light, not a thrower.Please consider using the well regarded and desired XPL HI 5D or 5A with a nice tint instead of the ugly and yellow XPL HI U6-4C.
Emisar sells the 5D with great success.Thanks,i will consider to use SST20 or LH351D ,too
S2+ is not a thrower even installing SMO reflector,but the OP reflector can make the light spot even.
5D and 5A is a little redish ,i will try them
TIR optics is really even.
…and cheaper !
https://www.youtube.com/watch?v=Ju-jzbmNq00It appears the BD03 might have an e-switch in the tailcap due to the battery carrier device. Is this the case? If so, we could put a nice driver in this one.
it’s 1288 switch inside, my friend
Simon Mao:i’m ready to launch an new model ,single cell ,XHP50.2
Separating the type-c port and driver increases difficulty of flashlight assemblement and driver production.
i can ask driver manufacturer to produce several kinds of driver what you need.
21700 S2+ was added in my plan
Simon Mao: Ryzbor:Great to see you on BLF Simon!
5D and 5A is a little redish ,i will try themTIR optics is really even.
…and cheaper !
yes, i agree
