(Cancelled)D1S+, CSLNM1.TG LED, 850lm, 320kcd
Hank can you make gasket for 7mm and 9mm hole reflector also? This is the two most common hole size.
Hank please put oslon white in the Meteor and D4S!
Does anybody know if i use a Sanyo GA in the D1S with oslon white, will it work?
With a flashlight that uses a direct driver like the D1S you need to add resistance, by using a high resistance battery (the GA is still too low resistance/high current perhaps a NCR18650B works) and using long thin led wires if you can get the driver out. If you are handy and smart enough to find a spot for it, you may be able to add an actual resistor somewhere in the current path. Unfortunately Hank’s springs are very low resitance, maybe swap the copper-alloy tail spring for a steel spring. Experiment, keep measuring current and see if you can get to 5A or lower.
I asked him refarding the d4s already. He said the beam doesnt look right. Would be awesome if he can get them in the meteor though. Love the focused beam.
Also Hank, please sell the oslon white centralizers on your store.
Like that you eliminate all the benefits of the low Vf of the White Flat 1mm².
are you going to add those gaskets for sale in your website as well ?
edit
ok you cann buy it with led and pcb.
But for what reflector hole size? 7mm for D1S? Hank please make them for 9mm also!
Thank you Hank for making these available, placed an order along with some other goodies :slight_smile:
Thanks Hank, for D1s + white flats + gaskets
Dave
If you use the gasket does that mean you don’t need to focus the led? I just ordered a gt mini and flat 1 from L4P a few days ago. I’m thinking I might have made a mistake.
what size gasket is it? for 7 mm?
It’s for 7mm hole size reflector.
How about the 2mm white flat in the D4S?
will there be one for 9mm reflector hole?
too bad this one is canceled. Maybe someone is going to build it anyway?
I was just thinking about how to add resistance in the D1S with 2mm^2 white flat. Is there enough clearance with the reflector for some 1 or 2W resistors in the head to the side of the MCPCB? You could attach them to the head with thermal adhesive to make sure they don’t overheat. For the 2mm white flat you need to add about 0.1 ohms to get the current down to 7A or so, so they need to dissipate between 4 and 5W.
Easy.
Just replace the BeCu spring with a regular steel spring of a similar size.
Yeah I guess that would be easier. Djozz measured steel springs to have about 50mOhms each.
Interested!
