GearVita Daily Deal: Xiaomi Xiaobai Smart 1080P IP Camera - Panoramic HD, AI Humanoid Detection, Remote Alarm
LJC-118 snowman LED light is a very cute touch control sensor night light with music, the light color will change with the music and you will see seven different colors.
Product Features:
● The light color is gradually change with 7 different colors, and will play music at the same time.
● Lovely shape brings happy time.
● Touch control.
● The accessories are removable.
● Soft silicone material gives a nice hand feeling.
● Rechargeable built-in 3.7V 1200mAh Li-ion battery.
● USB charging, easy to charge and carry.
● Suitable for many occasions, like Christmas party, kids room, etc..
Christmas is coming, this is a perfect gift for your children or lover, also a lovely ornament in your home. Only $9.99 you can get it from GearVita: https://gearvita.com/ljc-118-snowman-led-light.html
You may like:
xiaomi mi max 3 4g smartphone in stock
xiaomi mi box s tv box global version in stock
The Lumintop HL AAA flashlight is a muti-function mini flashlight. Compact in size, it can easily carry in a pocket or in a pack-bag. Reversible two positions mounted clip offers various wearing ways. The strong magnetic tail cap can be easy suck on a metal surface, to meets different lighting demands such as vehicle maintenance etc. Bead surface optical lens, floodlight design for a soft and balance beam. Powered by one AAA battery, handy and compact yet multifunctional in use, surely you can trust on in camping, hiking etc.
Main Parameters:
Emitter: Cree XP-G2 R5
LED Lifespan: 50000h
Luminous Flux: 120 lumens
Beam Distance: 30m
Luminous Intensity: 228cd
Battery: 1 × AAA
Waterproof Standard: IPX-7
Impact Resistance: 1.5m
Output and Runtime:
High: 120 lumens ( 0.5 hours )
Mid: 30 lumens ( 4 hours )
Low: 1.5 lumens ( 36 hours )
Product Features:
● Utilizes Cree XP-G2 R5 LED with a lifespan of 50000 hours and a max output 120 lumens.
● One switch control, easy to use.
● Made of aircraft-grade aluminum alloy with nickel plating on the surface, 1.5 meters impact resistant test.
● Magnetic tail cap, easy to be suck on the metal surface.
● Stainless steel clip can be mounted on two sides of the body.
● Powered by one AAA battery, 36 hours max run time.
● High-efficiency digitally regulated circuit to maintain constant brightness.
● Bead surface optical lens for soft and balance beam.
● Waterproof to IPX-7 standard, suitable for rainy weather.
It can be served as a mini flashlight or an angle light, there are two emitter models on GearVita for you to choose from, Cree XP-G2 R5 and Cree XP-G3 R5: https://gearvita.com/lumintop-hl-aaa-led-flashlight-120-lumens.html
You may also interested in:
buy xiaomi mi max 3 4g smartphone
buy xiaomi mi 8 lite 128gb
Wuben L50 is a multi-function aluminum flashlight for outdoor use. Cree XP-L2 LED imported from US, simple function operation, stable circuit design, 18650 battery powered, built-in independent charging design, convenient, energy saving.
Main Parameters:
Emitter: Cree XP-L2 LED
Max Output: 1200 lumens
Max Beam Distance: 200m
Peak Beam Intensity: 10008cd
Max Runtime: 143 hours
Battery Configuration: 1 × 18650 Battery
Working Voltage: 2.8V-4.2V
Waterproof: IPX8, 2m underwater
Impact Resistant: 1m
Output and Runtime:
High: 1200 lumens ( 1.5h )
Med: 400 lumens ( 2.5h )
Low: 75 lumens ( 8.5h )
Eco: 5 lumens ( 143h )
SOS: 1200 lumens ( / )
Product Features:
● Fully press the tail button switch to turn on the flashlight and press it again to turn off the flashlight. When the flashlight is on, half press the tail switch to change the flashlight brightness.
● Turn on the flashlight, tap the tail switch to adjust the brightness: Eco-Low-Medium-High-SOS-Eco cyclically.
● Built-in 18650 battery, can be charged cyclically.
● High-tech smart constant current chip, to ensure smooth output brightness.
● Can be used immediately after charging, environmentally friendly, full of about 4 hours.
● With one folder, easy to carry.
● Grade III hard anodized aerospace aluminum body.
● Surface vibration grinding, beautiful design, feel more comfortable.
● Waterproof level IPX8, 2m underwater for 1 hour, cope with all kinds of harsh environment.
It is suitable for camping, fishing, hunting, hiking, searching, working and so on, get it on GearVita now: https://gearvita.com/wuben-l50-led-flashlight-xp-l2-1200-lumens.html
Hot sale products:
xiaomi lyej05lm in stock
The Nitecore HC65 headlamp improves more power to the popular HC60 headlamp by adding secondary red and high CRI LEDs. Equipped with a primary Cree XM-L2 US LED, delivers a 1000 lumen wide angle output beam, capable of a 120 yard throw, useful for mid-range illumination activities like hiking, biking and camping. A high CRI auxiliary white light renders colors more like sunlight and can be used for an upclose flood of light when reading or working while an auxiliary red light helps users preserve night vision in dark environments.
Main Parameters:
LED: Cree XM-L2 U2
Max Output: 1000 lumens
Max Beam Distance: 110 m
Peak Beam Intensity: 3000cd
Battery: 1 × 18650/2 × CR123/RCR123 battery
Waterproof: IPX8
Impact Resistant: 1.5m
Output and Runtime:
Turbo: 1000 lumens ( 1h )
High: 550 lumens ( 2h 45min )
Mid: 280 lumens ( 4h 45min )
Low: 80 lumens ( 16h )
Ultralow: 1 lumen ( 800h )
Auxiliary White Light: 26 lumens ( 25h )
Red Light Illumination: 11 lumens ( 20h )
Red Caution Light: 11 lumens ( 32h )
Strobe/SOS/Beacon: 1000 lumens ( / )
Product Features:
● Equipped with high CRI auxiliary white light and red light.
● Integrated precision digital optics technology for extreme reflector performance.
● A maximum beam intensity of up to 3000cd and beam distance of 360 feet.
● Highly efficient constant current circuit runs for up to 800 hours.
● Intelligent memory functions stores last used lighting level.
● Intelligent Li-ion battery charging unit, built-in micro USB charging port.
● A flood lighting system provides 100 degree beam angle.
● Integrated advanced temperature regulation technology.
● Tilt mechanism allows for 180 degree adjustment.
● Power indicator displays battery voltage, accurate to 0.1V.
● Reverse polarity protection.
● Constructed from rugged aerograde aluminium alloy.
● Rugged HAIII military grade hard-anodized aluminium alloy.
Buy it from GearVita and get ready for your next adventure: https://gearvita.com/nitecore-hc65-u2-led-headlamp-1000-lumens.html
You may like:
cheap lenovo z5 pro 128gb
cheap yi 4k action camera floating grip
The Nitecore LR10 camping lantern with 9 high CRI LEDs offering a max output of 250 lumens up to 26.2 yards. With a CRI rating more than 90, the LR10 emits a beam that resembles natural morning sunlight to prevent eye fatigue and reveal subtle details of objects. A highly translucent PC diffuser evenly distributes light to provide 360 degrees of illumination for your surrounding environment. The LR10 also includes a built-in location light for finding the lantern in the dark as well as a battery indicator to let you know when power is running low. A magnetic base and metal hook provide multiple mounting and hanging options for this highly versatile lantern ideal for outdoor excursions, working at night, everyday carry and more.
Main Parameters:
LED: High CRI LED
Luminous Flux: 250lm
Max Beam Distance: 24m
Max Beam Intensity: 38cd
Color Temperature: 4500K
Output and Runtime:
High: 250 lumens ( 1h )
Mid: 65 lumens ( 5h 15min )
Low: 8 lumens ( 38h )
Caution Light/SOS/Beacon: 250 lumens ( / )
Product Features:
● Utilizes 9 high CRI LEDs (CRI≥90, temperature color of 4500K) to emit maximum output of 250 lumens.
● Built-in 1200mAh Li-ion battery.
● Integrated intelligent charging circuit for micro-USB charging.
● A single switch controls 3 brightness levels and 3 special modes.
● Takes advantages of highly translucent PC diffuser, allowing all light source to be well distributed.
● Built-in power indicator reports remaining battery power, doubles as a location signal.
● High efficiency constant current circuit.
● Magnetic base for multiple scenarios.
● Made from durable PC materials.
● IP66 waterproof with 1.5 meters impact resistant.
LR10 is a lightweight camping lantern that can even put into the pocket, get from GearVita, it will bring much convenience for you in your trip: https://gearvita.com/nitecore-lr10-led-pocket-camping-lantern.html
You may like:
cheap airdots headset
buy honor watch magic
OEM CL018 LED light is a USB rechargeable night light which is very good for home use. It has 2 modes adjustable, constant light mode and human body induction mode, so you can choice as you need.
Product Features:
● 5 pcs environment friendly and energy-saving LEDs to light up your night life.
● Super bright LED bulbs, up to 20 lumens output, stays off during daylight hours.
● Automatic sensor auto-on within 10 feet, auto-off after about 25 seconds of no motion detected.
● Turn on only when it is dark and only when motion is detected.
● Included super strong 3M double-sided tape, just stick it to anywhere you want.
● No wiring, multiple ways of use, also can be hung on a nail in the wall, or put it on the table.
● 600 milliampere cycle rechargeable lithium battery.
It is placeable, pasteable, hangable, ideal for anywhere such as bathing rooms, hall, shoe closet, cellar, corridor, etc., and available on GearVita at only $7.49: https://gearvita.com/oem-cl018-mini-led-light.html
Hot sale products:
best airdots headset
buy huami amazfit 2 stratos
What emitter is used in this “bedside” light source?
Is there any blue in the emission spectrum of this light source that would interfere with sleep?
https://www.sciencedirect.com/science/article/pii/S0022395617308592
(Most LEDs do have significant blue emission, no matter what color temperature they produce.
The Xiaomi Aqara ZNLDP12LM smart bulb can adjust the brightness and color temperature freely, it has built-in Zigbee wireless communication module. After binding the gateway device, it can flexibly realize remote control, time switch, and multi-device control. E27 interface, high-energy-saving LED bulb, large light-emitting area.
Product Features:
● Acrylic material, strong light transmission.
● Simple bulb design, practical and durable.
● E27 holder, easy to match.
● 9W low consumption, safe, energy-saving and environment friendly.
● The brightness and color temperature can be adjusted freely to meet a variety of scenes.
● Intelligent linkage, achieve more intelligent scenes with Mijia or Aqara other smart products to make life a little cooler.
● When someone comes, the light will be bright; when someone goes off, the light will turn off.
● Intelligent voice control, through the Siri, you can turn on the lights, adjust brightness and color temperature with a simple command.
● Time switch, you can set different lighting modes at different times, such as get up mode, reading mode, relaxation mode, etc..
● APP remote control, just turn on your phone and you can control the light anytime, anywhere.
The smart bulb is suitable for bedrooms, living rooms, bars, hotels, gardens, etc., you can get from GearVita. Not only the the small body exudes a lot of energy, but also the nice appearance will bring you a good mood: https://gearvita.com/aqara-znldp12lm-led-smart-bulb.html
Hot sale products:
buy huawei honor band 4 running version
buy lenovo z5 pro 128gb
The new Xiaomi Mijia Aqara Hub Gateway can works with Apple HomeKit, which means you will be able to control their smart products with the Siri voice assistant. It can be linked with up to 32 smart devices including smart lights, the Aqara flood sensor, wireless switches, wall sockets, body sensor, temperature and humidity sensor, and Aqara motorized curtain. When connected to the Apple HomeKit, you will be able to use Siri on their iPhone, iPad, Apple Watch or HomePod to control any of the smart devices.
Product Features:
● Smart Home Center
Aqara Hub is a control center for an entire smart home. Connecting via Zigbee protocol, Aqara accessories can still work smoothly even if your home network is unstable or disconnected.
● Works with Apple HomeKit
You can use Home app to control the Hub and its connected accessories. Aqara accessories can also work with other HomeKit-enabled accessories to provide you a smarter home.
● Siri Voice Control
You can control Aqara accessories with Siri on your iPhone, iPad, Apple Watch or HomePod. Just tell Siri "I'm home", then the lights turn on, the curtains are closed, and a comfortable home is waiting for you.
● Nightlight Function
When motion is detected in the evening, the Hub light automatically turns on.
● Smart Doorbell, Personalized Ringtone
With a press of the wireless mini switch, the hub plays your preferred ringtone.
● Security Reminder, Guarding Your Home
With the door and window sensor, you can turn on alarm mode when you leave the house or you are asleep. If a door or window is opened, the hub will sound an alarm and send your phone.
● One Button, All Accessories Under Control
With the wireless remote switch, set your own night mode and turn off all by one button.
● Humidity and Temperature Adjustment
Link the smart plug with a humidifier to improve indoor humidity.
● Water Leak Alarm
With the water leak sensor, when a leak is detected, the hub will sound an alarm and send a notification to your phone.
● App Control
With the Aqara Home App (IOS or Android), you can control your home from almost anywhere at any time.
● Technologically Advanced
Aqara hub adopts one body shell design and uses NXP i.MX6 CPU, 256M DRAM, 256M flash, and an MFi chip. It has two high gain built-in antennas. By utilizing FR4 PCB with a large area ventilated base, the ventilation creates an airflow from front to back, increasing the heat dissipation and ensuring the hub's reliability over time.
If you are interested in grabbing one, it is available for purchase on the GearVita store: https://gearvita.com/xiaomi-mijia-aqara-hub-gateway.html
You may also like:
best xiaomi mi 8 lite 128gb
buy xiaomi airdots bluetooth headset
The Xiaomi Philips smart E14 LED bulb comes with 8 LEDs whose brightness and sharpness can be adjustable, widely used for indoor lighting decorations. With only 3.5W consumption, the bulb is safe and energy-saving. The candle bulb can be controlled by APP, turn on and turn off the switch, brighten and dim the brightness, you can simply use your smartphone to do all that. It is made of a high-quality plastic material, to ensure ultra-long lifetime that is up to 10 years.
Product Features:
● Crystal Version, Bright as Star Light
The shell is made of high transmission engineering plastics, clean and transport. The lotus-shaped lens inner can fully reflect and refract the light beam, emit a star-like bright light for you.
● Scrub Version, Soft as Moonlight
The shell is made of opal plastic, after full reflection and filter of milky white shell, light beams are softer, the same as gentle moonlight.
● E14 Holder, Match with Varieties of Lamps
Equipped with a standard E14 holder, the bulb can be directly replaced the traditional E14 bulbs and brighten every comer of your home to give your home a new glow.
● Adjustable Color Temperature and Brightness to Create Personalized Lighting Scenes
3000-5700K color temperature and brightness can be adjusted in the Mijia APP via WiFi. In addition, there are 4 scenes for you to choose.
● Delay-off Function, Let the Darkness Come Later
According to your settings, the light bulb can be delayed off at any time within 6 hours, let the dark come later.
● Smart Linkage, Lighting More Intelligent
The light bulb can be used in conjunction with Xiaomi other smart products for more functionality. With Xiaomi body sensor and windows and doors sensor, the bulb will automatically turn on when someone passes through a specific location or switches the doors or windows.
● 10-year Lifespan to Provide You Longer Lighting
15000 hours life, not only environmental friendly but also keeping you away from replacing bulb frequently.
● 3 Steps, Easy to Use
Install the bulb, download Mijia APP, find and add devices via WiFi.
It comes in two version, the crystal or scrub version, both can be found on GearVita at $14.99 and offer the best when it comes to lighting experience: https://gearvita.com/xiaomi-philips-zhirui-smart-e14-led-candle-bulb.html
You may also like:
cheap xiaomi mijia aqara hub gateway
best xiaomi redmi note 5
Is anybody there? Information requested
Open the “bedside lamp” up and show us a picture of the LED, if you don’t know what you’re selling.
We can figure it out.
Or you can use an inexpensive spectrometer to assess whether it’s emitting blue light that interferes with sleep.
Here’s one:
https://publiclab.org/wiki/desktop-spectrometry-kit-3-0
nobody there, this just a ad promotion thread, they sell light and android phone and many other products
so don’t expect they can be very professional on every product
Using high-quality LEDs, the Xiaomi Yeelight YLDP05YL smart LED bulb supports 2700 - 6500K color temperature. 10W low consumption and 25000 long lifespan support over 10-year using time. Open Yeelight APP and choose the light you like, or control with Amazon Alexa or Google Assistant.
Product Features:
● Adjust color temperature 2700K - 6500K and brightness for meet your different needs.
● APP control lets you change light color and color temperature by connecting with Yeelight APP in your phone.
● Intelligent voice device control can work with Amazon Alexa and Google Assistant.
● 25000 hours long lifespan for over 11-year runtime.
● 10W low consumption for saving electricity.
● Lightning protection, overheating protection and overload protection.
● Standard E27 socket, suitable for various types of household lighting fixture.
● Compatible with Android 4.4/iOS 7.0 and above systems.
Sync the lights to your favorite song and explore how lights change with the rhythm. Get it from GearVita, spice up your party or holiday decorations with changing colors: https://gearvita.com/xiaomi-yeelight-yldp05yl-smart-led-bulb-dimmable-ac-100-240v-10w.html
buy xiaomi 70mai dash cam pro
buy airdots headset
The Xiaomi Philips Zhirui downlight can not only be controlled individually, but also can be grouped by multiple downlights, and operate multiple devices via a single button to achieve intelligent control of the whole house lighting. Its brightness is infinitely adjustable and life expectancy is as long as 15000 hours.
Product Features:
● Color temperature and brightness can be adjusted steplessly.
● Operating multiple devices via a single button to achieve intelligent control of the whole house lighting.
● Can set the timer switch light, no longer limited to the wall switch.
● Meets ICE photo-biological safety requirements for safer eye protection.
● Compact and simple design, using for different decoration styles.
● Embedded design, easier installation.
● Life expectancy 15000 hours, has a long lifespan.
● High temperature and humidity resistance.
Xiaomi always tend to trill their fans with amazing value products, this one is no exception, the free combination of light and simple shape make your family more warming. Don't miss this downlight, get it from GearVita, it will not let you down: https://gearvita.com/xiaomi-philips-zhirui-adjustable-color-temperature-downlight.html
lenovo air tws bluetooth earphones
q50 kids gps smartwatch
AC110-240V laser projector light is a LED laser light which is very suitable for using in Halloween, Christmas, New Year and party. It has 16 film patterns including clowns, peace doves, bright stars, maple leaves, Christmas and other beautiful landscapes. The projector has a snowflake card, different ways means to bring you different feelings.
Product Features:
● Small size and easy to operate, moving automatically, take more fun for your party and festival.
● 16 film patterns - clowns, peace doves, bright stars, maple leaves, birthdays, hearts, butterflies, clovers, Christmas, Halloween, smile, and beauty.
● The projector has a snowflake card, different ways to bring you different feelings.
● Flash speed, moving speed and time setting can be adjusted by the remote controller, easy and convenient.
● IP65 Waterproof, can even use in the rain weather, but can't use in the heavy rain weather.
● Easy to install, up to 180 degrees lighting angle, package included base and spike, can be installed on a wall or inserted in your garden lawn.
● Great for kids, perfectly in home party, bar, pub, Halloween, Christmas, etc.
Although Christmas and New Year have passed, it is also a very good choice for parties. The price on GearVita is not expensive, can be given as a gift to children, it will be a great fun: https://gearvita.com/ac110-240v-laser-projector-light.html
Hot sale products:
cheap huami amazfit 2 stratos
best xiaomi poco f1 lte 64gb
That’s what I expected.
The On The Road M3 Pro flashlight is a Type-C USB charge flashlight with Cree XM-L2 U3-5C LED emitter, powered by one CR123A or RCR123 or 16340 Li-ion battery, perfect for professional outdoor camping or household use. It features 1020 lumens high power output, mini portable, max 60 hours long runtime, IPX8 water resistant and so on.
Output and Runtime (with 700mAh 16340 Li-ion battery):
High: 720 lumens ( 35m )
Mid: 360 lumens ( 1h )
Low: 160 lumens ( 2h 15m )
Ultra Low: 5 lumens ( 60h )
Turbo: 1020 lumens ( / )
Product Features:
● Type-C USB Charge
Can be charged either positively or nagatively without removing.
● Magnetic Adsorption
Built-in magnet at the tail, easy to attach to the iron surface.
● Light and Portable
Weight only 38g, lighten for your outdoor activities.
● Mode Switching
4 optional lighting modesto meet different scenes, 1 hidden emergency flashing mode to self-defence.
● At A Glance
Built-in battery power shows the remaining quantity of electricity is clear.
● Charge Quickly
Support 1000mA quick charge to save your time.
● Protection Plug
Waterproof, dustproof and sandproof, easily respond to outdoor harsh conditions.
● Smart Temperature Control
Base on the operational time, regulate the temperature automatically.
● 1020 Lumens
New Cree SC5 technology platform, 350mAh provide up to 200lm/W effect.
● A Wide Range of Lighting
100° beam angle, wide range of hard light covering.
● Long Last Runtime
As 5 candles burning for 3 days incessantly.
Come to GearVita to learn more about the M3 Pro, you will instantly attracted by it: https://gearvita.com/on-the-road-m3-pro-u3-5c-led-flashlight-1020-lumens.html
Top sellers on our website:
cheap qcy t1c mini wireless earphones
xiaomi mi 8 lite 128gb in stock
On The Road U16 flashlight is a USB rechargeable mini flashlight, it is a USB charging version of M3, the functions are consistent with M3, and USB direct charging is added.
Product Features:
● Compact in mini size, easy and convenient to carry.
● The side switch controls five brightness and three special modes.
● When installed one 700mAh 16340 Li-ion battery, the flashlight can be used for 140 hours in low mode.
● CR123A battery and RCR123 batter are also suitable for this flashlight.
● High efficiency constant current circuit board always provides a sense of security.
● After twisting the tail cap, you can clean the memory by changing to month mode.
● Ultra-clear mineral glass with antireflective coating.
● The integrated power indicator on the switch shows the remaining battery power.
● HAII Military grade hard alumite finish aero grade aluminum alloy.
● Has the function of low voltage reminder indicates and reverse polarity protection to protect the light from the damage of improper battery installation.
● Magnetic tail cap with stand function.
● Safe and water resistant, highest water resistant level of IPX6, impact resistance up to 2 meters.
The On the Road U16 is a compact, capable, well made flashlight. For $27.99 on GearVita, it has good value: https://gearvita.com/on-the-road-u16-u3-1a-mini-led-flashlight-1020-lumens.html
cheap xiaomi airdots headset
best lenovo z5 pro 64gb
The Yeelight YLSD03YL LED downlight, a ceiling lamp with excellent brightness. It is manufactured from thickened metal to provide a lightweight body, has corrosion and discoloration resistance characteristics. It selects a high quality LED as a light source and high transparency metal as a screen. The material is definitely high quality and the workmanship with which it was made is excellent. This Yeelight LED downlight has an integrated heat dissipation structure, thickening material can effectively promote heat dissipation and at the same time keep the source separate from the heating components to ensure a very long service life.
Product Features:
● Superior in Material, Excellent in Workmanship
Use thickened metal as light body with the features of rust-proof and fading-resistant, select high-quality LED as light source and high-transparency material as lampshade.
● Multiple Protection
Built-in constant current driver to give overload protection, short circuit protection, under-voltage protection.
● Integrated Heat-dissipation Structure
Thicken material can effectively promote heat dissipation and simultaneously and keep source apart from heating components to ensure long lifespan.
● Energy-saving and Long Lifespan
Provide 400 lumens brightness with only 5 wattage, quite energy-saving yet highly bright 25000h effective working time, practical and durable.
● Render The Brilliant Colors
Render the original color of objects and effectively eliminate the impact from low color rendering index on vision.
● Simple Yet All-matched Design
Designed in round shape in classic white, can easily match with a variety of home style, comes with a curved light-emitting surface to divergent a softer light.
Yeelight LED downlight installed in the corridor, aisle, entrance and other small space at home, the warm and gentle light can lighting this place. It do not to take to much space and money, only $10.99 needed on GearVita, but will be able to create a comfortable and warm atmosphere: https://gearvita.com/xiaomi-yeelight-5w-400lm-4000k-led-downlight.html
xiaomi huami amazfit bip smartwatch
qcy t1c mini wireless earphones in stock
The Nitecore MT42 is a high intensity hunting flashlight that specially designed for night hunting and searching. It uses a Cree XHP35 HD to produce maximum beam intensity of 55400cd and beam distance up to 470 meters. With a max output of 1800 lumens and five total brightness settings, you'll have just the right amount of light for any task. Three special modes add even more functionality for emergencies and location signaling.
Output and Runtime:
Turbo: 1800 lumens ( 1h )
High: 800 lumens ( 3h 30m )
Mid: 280 lumens ( 12h )
Low: 68 lumens ( 45h )
Ultralow: 1 lumen ( 530h )
Strobe: 1800 lumens ( / )
Beacon: 1800 lumens ( / )
SOS: 1800 lumens ( / )
Product Features:
● Utilises a Cree XHP35 HD LED to emit a max output of 1800 lumens.
● Integrated precision digital optics technology provides unparalleled reflector performance.
● Compatible with 2 × 18650 Li-ion batteries.
● Boasts a peck beam intensity of 55400cd and a max throw of 470 meters.
● Side switch controls 5 brightness levels and 3 special modes.
● Power indicator light displays remaining battery power.
● High efficiency constant circuit provides unwavering output up to 530 hours.
● Advanced temperature regulation module regulates outputs and adapts to the ambient environment.
● Intelligent memory function, returns to the previous used mode the next time turned on.
● Constructed from aerospace aluminum with HAIII military grade hard-anodized finish.
● Waterproof in accordance with IPX8 (2m submersible), 1m impact resistance.
Detailed parameter informations please click: https://gearvita.com/nitecore-mt42-1800-lumen-high-intensity-flashlight-for-hunting-search.html
Hot sale products:
xiaomi redmi note 6 pro 32gb
xiaomi mi a2 lite smartphone
