The Lumintop HL AAA flashlight is a muti-function mini flashlight. Compact in size, it can easily carry in a pocket or in a pack-bag. Reversible two positions mounted clip offers various wearing ways. The strong magnetic tail cap can be easy suck on a metal surface, to meets different lighting demands such as vehicle maintenance etc. Bead surface optical lens, floodlight design for a soft and balance beam. Powered by one AAA battery, handy and compact yet multifunctional in use, surely you can trust on in camping, hiking etc.
Main Parameters:
Emitter: Cree XP-G2 R5
LED Lifespan: 50000h
Luminous Flux: 120 lumens
Beam Distance: 30m
Luminous Intensity: 228cd
Battery: 1 × AAA
Waterproof Standard: IPX-7
Impact Resistance: 1.5m
Output and Runtime:
High: 120 lumens ( 0.5 hours )
Mid: 30 lumens ( 4 hours )
Low: 1.5 lumens ( 36 hours )
Product Features:
● Utilizes Cree XP-G2 R5 LED with a lifespan of 50000 hours and a max output 120 lumens.
● One switch control, easy to use.
● Made of aircraft-grade aluminum alloy with nickel plating on the surface, 1.5 meters impact resistant test.
● Magnetic tail cap, easy to be suck on the metal surface.
● Stainless steel clip can be mounted on two sides of the body.
● Powered by one AAA battery, 36 hours max run time.
● High-efficiency digitally regulated circuit to maintain constant brightness.
● Bead surface optical lens for soft and balance beam.
● Waterproof to IPX-7 standard, suitable for rainy weather.
It can be served as a mini flashlight or an angle light, there are two emitter models on GearVita for you to choose from, Cree XP-G2 R5 and Cree XP-G3 R5: https://gearvita.com/lumintop-hl-aaa-led-flashlight-120-lumens.html
You may also interested in:
buy xiaomi mi max 3 4g smartphone
buy xiaomi mi 8 lite 128gb
