put me down for one please!
1 please
I would like one please.
I’m already on the list, would you put me down for a XPL-HI & a Samsung emitter.
Thank You and Happy New Year
Please add me for a third one.
My plan is to get one of each version, and a second of which I like best.
Happy New Year everyone!
I was going to just subscribe to this thread but I couldn't find the button... how embarrassing.
Anyway, I'm in for 1 :D
I just ordered an A6 and one of these two will hopefully become my EDC for the days I just need something a little bigger than my 2x AAA penlight.
Also thanks in advance to anyone welcoming me to the forum! :3
At the bottom of the first post of every thread
I’m in for 1
:person_facepalming: lol, thank you! I had already convinced myself that there isn’t a subscribe-button…
Just click it once. It sometimes takes a couple of seconds to change. If you click it “furiously”…. each click counteracts the previous one.
@ Streamtronics…… Welcome to BLF!! . :+1:
Anyone with a prototype have a photo of the driver from the battery side?
Diameter?
Hopefully I will get one of these. Put me down for one, I don’t think you’ll have much trouble selling it if I don’t get on BLF for awhile or don’t have the money or something
So it will need about 9A batteries? It looks like this is more of a flood than thrower? Or is the beam somewhat focused?
I might actually prefer the LH351D, but as long as it’s 4875K or 4000K, idk that i’m that worried about it.
By saying something in the thread you are automatically subscribed. No need to hit the button at all.
The driver isn’t perfectly circular. One side is flat to hold it in the correct orientation and prevent it from spinning when the retaining ring is tightened.
It also isn’t easily replaceable since the driver was designed specifically for this light. I don’t expect generic drivers to fit. However, it should be easy to reflash if desired. It just requires unsoldering a couple wires and loosening a retaining ring to let the driver come out.
OK, Thanks I can wait.
I’m not sure what your saying about the battery. Do you mean a battery capable of 9A continous? That’s kind of irrelevant. I would just use a good middle of the road high drain and high capacity cell like the 30Q or VTC6 3000mah.
A really high drain cell like the VTC4 2100mah or 20S is probably not needed.
You could probably use a high capacity like 35E or MJ1 and still get decent turbo output along with reduced heat and extended runtime.
Unless the lens has changed without me realizing, the beam should have some decent flood to the side due to the frosted lens. You can also polish the lens to remove the frost and make it more throwy.
I plan to use NCR18650GA's.
They're flat tops, and I hope they'll work fine.
Post #6000!
(at the moment)
how does this project go, any eta on release yet ?
I’m in for 1.
