It is probably compatible with existing quad boards (same led distance) but using such optics (no legs) will cause many issues.
You mean such as twisting off the emitters when turning the pill? I don’t think he is making a quad S2+ but just one with host dimensions that can be modded into a quad.
There is a 21700 Amutorch VG10 coming out. Sounds pretty similar to me. However, the Ledil quads seem to fill this niche.
Yes, remeber amount of broken LEDs when S41 appeared?
I wouldnt give any suggest to the developer. Just let him do his job and stay tuned.
I received my copper spacers and they look awesome. Thank you.
Got my copper S2+ single and custom thin ring in. Machining is great as always. Threads for both the pill and custom ring were very smooth. Especially the custom ring that thing is like butter. Heat transferred well to the body of the light even without any thermal paste on the pill.
If you have a FET or boost single or the copper S2+ host you should be using this no questions asked…
Hi Kirill, any chance of you making the quad spacer for convoy M2 again?
Hi.
I have few spacers, but I need to find or machine rings for the set.
How many spacers do you have left?
I’m sorry I haven’t seen the set before, which ring did you mean?
2pcs
Is that link where I go to get a triple copper spacer for my S2+??
Sorry?
I posted link with g_damian build photos that shows how the ring is used in M2 build.
S2+ triple pills, spacers and P60 shells should be restocked in the end of January.
Nice, thank you for the quick reply!
Well used my last kiriba-ru P60 Quad copper pill. This is how to wake up an old Surefire 6P that was bored and hone to fit a VTC5A and press fit the copper P60 using these new V2 emitters. I mixed 2 5000k and 2 6500k to blend tints, well the output and tint are outstanding!
The Z59 tail cap is stripped and modded with a 10amp KAN9 Fwd Click switch 18awg bypass on one of Blue’s springs. Z41 bezel with double coated AR lens. Mtn. Guppydrv 3 FET+1 that the FET was changed to an Infineon FET 18awg Leads. Mtn. Quad Copper mcpcb Lumileds V2 6500k and V2 5000k emitters.
4500lm+ out of the Old Surefire 6P It was worth all the hours of hand fitting and polishing the pill/host for a nice smooth press fit, no need to copper wrap for heat transfer.
Can’t remember how many of these P60 pills I used of kiriba-ru’s, they are outstanding and I’m going to need 3 more when they are ready… thanks my man!
I’ll take aluminum p60 quad (when available) together with u11 quad and copper pill single led for s2+ (with custom slim retaining ring).
Great products!
Any pictures of the interior (led side) of the C8TT? Dimensions?
Thanks for offering these.
Thanks for the quick reply. One of the things I was wondering was if there were screw holes.
Also how it compared in size to the usual C8 head.
Thanks again and good luck with sales.
Non of my parts made for quad or triple mod used to have screw holes. Avoiding them makes parts more simple and build more user-friendly.
It is 9mm shorter than usual C8 head.
x5 spacers sold out?
