Fireflies E07 preview
2054 posts / 0 new
contactcr
Last seen: 1 hour 21 min ago
Can anyone tell if the glass is AR coated? Having trouble spotting it on this one
saypat
saypat's picture
Last seen: 1 week 23 hours ago
Product Description:
Made of 6063 aluminum alloy and 304 stainless steel
Body color: Matt Black , Gun Grey and Desert Yellow
HAIII Anodising Surface Finish
1× 21700 / 18650
25 degree angle TRI lens
98% AR coating glass lens
Digital current regulation on lower brightness
IPX6 waterproof
with Aux leds ; with switch leds
Size: 112mm(L )x 37.5mm(Head) x 26mm(Body)
Net Weight: 125 gram
contactcr
I realize what it says in the description. I can usually reflect it on a ceiling light and see an obvious coating but it’s not so apparent.
RobertB
RobertB's picture
Last seen: 2 hours 20 min ago
klrman wrote:
RobertB wrote:
Enjoying mine. XPL-HI 5000k. Love the mild diffuser on it.
Pics like those make me happy that I also chose the XPL-Hi 5000k
 Did you happen to notice how long it could sustain that max output before getting too hot?
It was cold outside, so I really didn’t hang out very long to find out. I would guess I was outside for at least 3 or 4 minutes, but it was 25ºF outside. No stepdown and the light warm but not hot
joechina
Last seen: 13 hours 35 min ago
ToyKeeper wrote:
Yeah… I haven’t updated the diagram yet because there’s nowhere left to fit more actions. Also, because some lights don’t have aux LEDs so they don’t have the extra functions.
I should probably also do something to make it easier to read when printed in black and white. On a cheap print, the green lines look almost the same as the black lines.
Hello Toykeeper, you have mail
I reduced the Andúril chart, gives a bit room to add stuff.
One version is a 90% reordered (not pretty) version.
klrman
klrman's picture
Last seen: 20 hours 38 min ago
RobertB wrote:
It was cold outside, so I really didn't hang out very long to find out. I would guess I was outside for at least 3 or 4 minutes, but it was 25ºF outside. No stepdown and the light warm but not hot
I'm still surprised it could even hold it that long considering it's size even with the cooler weather.  I was expecting you to say something like 20 - 30 seconds.
RobertB
RobertB's picture
klrman wrote:
I’m still surprised it could even hold it that long considering it’s size even with the cooler weather.  I was expecting you to say something like 20 – 30 seconds.
Maybe it was more like 2 or 3 minutes. It wasn’t long though. I only had a tee shirt and jeans on
contactcr
It’s easy to miss the step down without a meter. It probably did begin to ramp down before that
klrman
klrman's picture
RobertB wrote:
Maybe it was more like 2 or 3 minutes. It wasn't long though. I only had a tee shirt and jeans on
Anything over 30 seconds is a winner to me in that size category.  Not sure if it will make a huge difference but I did order mine with a 40T instead of the 30T.
Newlumen
Newlumen's picture
Last seen: 1 month 1 week ago
Thanks robert. Nice beamshot. I am waiting for my e07 xpl 6500k…
klrman
klrman's picture
Newlumen wrote:
Thanks robert. Nice beamshot. I am waiting for my e07 xpl 6500k...
I ordered both 5000k and 6500k.  Will be interesting which one I like more.
Lux-Perpetua
Lux-Perpetua's picture
Last seen: 2 days 10 hours ago
Here is a nice comparison of the D4S between SST-20 6.500K and XP-L 6.500K.
https://www.taschenlampen-forum.de/threads/emisar-d4s-sst-20-6500k-beamshotvergleich.67526/#post-958201
While the SST-20 tends to have a green tint shift at lower currents the XP-L HI has no tint shift on all current levels.
Glenn7
Last seen: 1 day 16 hours ago
That SST-20 looks a yucky green!!
Firelight2
Firelight2's picture
Last seen: 11 min 11 sec ago
Waiting for my E07 with XPL HI 4,000K.
Reading this thread is making me drool!
klrman
klrman's picture
That green is enough to keep me away from the SST-20, not very appealing at all.
DB Custom
DB Custom's picture
Last seen: 19 hours 59 min ago
joechina, the actions part of the manual is critical, needs to be front and forward so it’s the first thing you refer to before digging into the UI… without knowing the actions the UI is confusing, understand how to get there and everything is easy. Wink
joechina
I know Dale. It’s the not pretty version.
Others have the line description on the bottom or lower right. I think with so much different lines I guess a user searches for the explanation.
I made three versions, this is the 90% where I pushed things around and with the most free space.
The other two are a 90% and a 95% version where I moved nothing.
We both don’t know how much space the misses needs. Wink
I lost track at the moment of the changes in Andúril, but the not pushed ones should be good for 7th click and a bit of text.
(It reminds me a bit at Narsil: Boy the cheat sheet is so packed, no way to add more stuff. And the next week Tom E had new features. Ok, I must push stuff around)
Also the lines for Hold, 3 fast clicks and other actions need probably a bigger spacing.
On A4 paper size its ok, but manufacturers print normally in a much smaller size.
I haven’t made print out in A5
A option for the “3 fast clicks”-line could be
Nicolicous
Nicolicous's picture
Last seen: 1 hour 17 min ago
few more beamshots while the neighbours are sleeping hahah
just a quick photo snaps so dont expect too much Silly
Nico -.-
JordanZHP
Last seen: 4 hours 1 min ago
Thanks for the pictures! If you order the blue aux leds, do the button leds always remain purple?
Umpi2000
Last seen: 3 hours 53 min ago
Man do I want the clear ano E07!
DB Custom
DB Custom's picture
Ah, but joe, I HAVE been speaking with her… the chart needs space in certain area’s for the addition of new functions… not necessarily a new block but more info in some of the old blocks. And only some lights that use Anduril would require this information, so it’s a toss up as to whether or not to add it in. Mostly it’s the aux led’s of a couple of manufacturer’s lights, not really applying to the normal version we flash.
Gonna have to be a couple of versions of the manual I think, one expanded for the auxiliary lights and the other not.
TK has her own methodology, someone else writing the manual the language seems off… probably best to let her do it so the speak reads true to form for the Author.
Mildlyangryjohnny
Mildlyangryjohnny's picture
Last seen: 1 year 1 month ago
Just got mine, nichia, blue/purp, gray. (Fyi: My order was placed on nov 28)
This is a really pretty light. Next to my zebra light 60whatever 3 plus thingy my current, er, which is to say former edc, it looks like jewelry. MAN-jewelry.
I was a bit leary this past month about whether or not it would pocket edc well…but it is really smaller than expected, i think it will be fine in my pocket.
Pretty psyched.
I will post a pic in a bit with some former edc’s for size comparison for those interested.
What a pretty light. It’s just so handsome. Seriously. Nicest looking torch in my collection, easily. I dont collect—i use—so most of my lights are pretty utilitarian. So, those with fancy copper, heat treated titanium art projects may be less impressed. But i’m impressed, and i am not easily impressed. I am also—relieved, that it seems alot smaller than i thought it would be.
Pix in a bit.
Jan_Ds
Last seen: 2 days 5 hours ago
Yes!
Realized after ordering blue aux.
I hope the mismatch isn’t too annoying…
noboneshotdog
Last seen: 1 day 19 hours ago
Pretty psyched.
Pix in a bit.
Congratulations! Would love to see your ZL SC600 in the comparison pic. Thumbs Up
Thier ain’t no bones in a hot dog. F. York
Mildlyangryjohnny
E07 SIZE COMPARISON WITH SOME CURRENT AND FORMER EDC’S
Wow. Doing pictures is hard. I think i got it worked out.
Unfortunately, i do not see the pic when i am in edit pane so i cant do a relevant comment, description. I.e. whats in the picture. So if you want that follow the link.
Link to description, if curious: http://imgur.com/gallery/hfkdEdD
Fyi. My lights get used. I put shrink tubing on the caps so i can hold with my teeth. And i put shrink tubing on the clips because i wear the lights alot on my belt and without the shrink wrap the clips tend to pop off. Thats whats on the lights that looks like tape. Its tooth protection. Oh, and sometimes i use heat shrink wine cork covers. Their slimmer.
Eagtac 18650 uv
Eagtac 16340
Pl47
Zebralight sc600fdiii+ 18650
Nitecore mh20 18650
Tn40s 4×18650
Lumintop sdmini/mh20 18650
Acebeam ec50ii 26650
Nitecore srt6 18650
noboneshotdog
Wow! There’s a man who uses his lights. Noticed some V54s. What’s your CPF screen name?
Mildlyangryjohnny
I prefer working at nite, so i use my lites a little bit.
Names the same over yonder but i dont do the comments much—unless i am on the hunt for a new lite. Been excited about 21700s, so i have been here alot lately—following fireflies. I will hang for a bit longer to see what they come up with next then i wont be back till i get the itch again.
Oh, that little lumintop sdmini is a fiat lux!
SKV89
Last seen: 2 min 33 sec ago
Mildlyangryjohnny, the E07 is very front heavy. You must have strong teeth.
noboneshotdog
M A J, sweet! Good that you have been around lately. I enjoy your contribution. That’s a nice Fiat Lux.
I have a E07vn on order with Oslon W2 LEDs. The 21700s have definitely brought some excitement to the forum! I have the PL47 and E07 is being built.
Thanks again for the pics my friend!
djozz
djozz's picture
Last seen: 2 min 35 sec ago
contactcr wrote:
what’s the cheapest device to get a decent measure for CCT/CRI/DUV in a flashlight?
I did not do an extensive search on the chinese sites (I would worry about correct calibrations with unknown brands) but I’m afraid that these devices do not come cheap at all, I have not seen anything under $1200 yet.
