Has anyone tested yet how much more current can be applied on this KD P2500 20mm buck driver? 2.8A is a bit low, so I'm wondering how far it can be driven with modding?
If it’s designed right, not much more. There’s a maximum current that can be pushed through the inductor before it starts saturating. The current will start to spike (ie, not be held back by inductance anymore), and it’ll just quietly cook itself to death without dumping any more current into the output.
If they designed it conservatively, maybe a bit more. But the inductor is most likely the limiting factor.
Yes but as far as I've heard these are e-switch drivers, running with NarsilM 1.2 that require a side switch like the Convoy L6. The L2 is a tailclicky only.
