Thanks for the testing djozz. The lower vf should help alot with single cell builds.
Hey Djozz Nice work.
Today I just finished 3 Sofirn C8f triples with these new LG led’s based on your previous testing and posts. I already had a c8f with triple Seoul Viosys Z5 to compare it with. Anecdotally both lights put out similar quantity of light but the hotspot on the LG light is about twice the size. (the Z5 seems to throw twice as far). Also I had the same problem as you with dirt and wish they just sold emitters. Thanks again for putting in all the work to do this testing.
In another post you mentioned a relatively high power 75mw UVC emitter. Do you know where I can purchase on one of these ?
You have been busy!
Yes, in my test above, at 1.6 A, the new LG puts out just 6% more light than the old LG that performed the same as the Seoul Viosys led, assuming all currents are the same. A 6% output increase will hardly be noticed especially when the hotspot has a different size.
A 75mW UVC emitter costs hundreds of dollars, as far as I know (example). Coincidently Scientist may be sending me a high power UVC led for testing but I would not spend that money on one myself.
305nm 100mW is a bit more affordable but as UVB less efficient to kill bacteria
https://shop.irtronix.com/products/lg-305nm-100mw-leuva66h00ku00
Yeah Djozz I may have a problem shipping those out of the country. I will PM you if I can get approval.
Sure, no hurry, I see it as a lucky opportunity if you succeed
If you do no torture test on this LED I may buy it after you are finished
LOL, such an expensive led is not going to be torture-tested for sure , but I will not sell what I have not payed for, sounds not very fair to Scientist.
Is the new led on the left hand side still dirty in the last picture?
No, it is the cleaned one , probably it will not influence performance but the silicon has some pits here and there.
Probably not the correct place to ask this question, but was wondering…
Convoy sells the Convoy S2 with LG UV LED. I wonder if that Convoy S2 uses the older LG or the newer LG UV365 LED?
Thanks again Djozz for the testing!! Djozz-mW...that's funny :D
I can Pay Scientist
Thanks for the test, djozz.
Looking at if from the other direction it means the radiant output at 3.7 V is not 1070 djozz-mW (at 0.8 A) but 2100 djozz-mW (at 2 A).
That is a huge difference.
This is probably hijacking your thread a little, but the knowledgeable folks who I have conversed with over the centuries are here, and the topic is UV LEDs.
Despite all the recent claims of 4 watt, 5 watt, overdriven, turbo Convoys (7135 drivers), I believe there ain’t no such animal. The engineers in our fluorescent mineral group have watched the ridiculous power claims climb over the past three years with amazement At the power levels folks are claiming today these little lights should literally be burning your hands. They aren’t - this blog post explains why, all comments welcome: Convoy false power claims
dude the 7135 is a linear regulator
Sure is, but I don’t understand your point
I'm not sure what you're getting at. You may be correct regarding the high Vf of the UV LEDs preventing high output on the UV Convoy, but the Convoy hosts are capable of dissipating over 7W of heat. I've personally run a Convoy on a fresh cell for hours at approximately 2A. Not much sag on that cell, but I'll be generous and assumed 2A * 3.5V for the power dissipation. For short periods, they handle significantly higher power well - not just the stock 2.8A that the white Convoy's come equipped for, but so-called hot-rodded Convoys can pull currents in the high teens.
Even your own chart shows the Convoy doing 3 Watts at 3.9V, which could be sustained for a while before the battery got that low - definitely more than just a few minutes.
700mA is very little current, it won’t burn your hands (but it could damage the Nichia LED if the heat transfer to the star and pill is not good enough as that LED is quite small, the LG LED can handle more current but has more visible light). Even 1400mA shouldn’t get too hot. 2100mA (6x7135) and 2800mA (8x7135) can indeed get quite hot to painful levels if left unattended. There was a temperature test of the 8x7135 driver: How hot does an S2+ get at 2.75A? Comparing an anodised Convoy S2+ with a fluorescent yellow powdercoated Convoy S2+
I guess that a 4.35V cell like the LG ICR18650E1 would be better for extended usage of the Nichia version.
Edit: you are making your claims based on a ‘typical’ 2200mAh cell. Nowadays 2200mAh would be either an obsolete or cheap cell, or a cell optimized for very high current for power tools or vaping (20A-30A) rather than capacity, not a typical 18650 cell. A modern cell 4.2V cell like the NCR18650GA can keep the voltage much better. In fact a 4.35v cell isn’t a large improvement over the 18650GA. From HKJ’s battery comparator :
