Today’s mod was one of the more tricky ones for me but turned out well.
Got a Sunwayman V11R during the random eBay deal a few months ago that like 30+ of us jumped on
Thanks toddcshoe for that deal thread and moderator007 for documenting his previous mods on this one..
Broke this free with the underside of my huge gaming mousepad, I think it was red loctite. Now I have a cramp in my finger. Only managed one small scuff on the ano that you can see in the bottom right piece.
Original ~14mm MCPCB and XM-L U2, bye Felicia
Seeing how much I have to take off my 16mm XP board, aside from filing a few 20mm triple boards for the E2L I have never done this before.
The only grinder I have, it’s made for sharpening knives. 120 coarse belt never gets used on knives anyways, lets try..
Ugly, but it gets the job done. LH351D 4000K 90CRI, GET TO THECOPPAH
Hey, it works. Glad I saved this one. It was from a failed re-flow attempt on a Q8 where I killed 2/4 LEDs with turbo. These were first group buy 4K which I really like the tint of, glad she lives to see another day.
The super low moon this light is sometimes known for looks neat.
Beam is good
I left out the metal washer/spacer thing so I could tighten the head and get the slop out of the variable ring. Thanks moderator007. It’s possible to over tighten it now but it wont be an issue, easy to adjust.
Random XP centering ring from Kaidomain was a perfect fit.
I ended up thinning the MCPCB too but I wish now that I hadn’t. I’m sure it’s not flat/level on the bottom but hopefully it’s close enough to make a good heat path. At least we are using copper now..
Just did a very simple mod on one of my Emisar D4 lights.
Remove the retaining ring. Best way that I found is to use the nail file from a standard small Victorinox mini pocket knife. The tipe of the file tapers to a flat end. And unlike a conventional screwdriver there are no sharp edges so the rubber button shouldn’t be damaged. With the file portion of the file almost parallel to the button boot, insert it at a shallow angle over the top of the button. Dig the tip of the file into the rubber below the edge of the retaining ring, then lever upwards. The ring should pop right off.
Remove the rubber switch boot. On the underside of the boot is a tiny post intended to hit the switch.
Snip off this post using a small scissors. The scissors in the Victorinox mini are ideal for this purpose. The goal is to cut off the post so the interior of the button cover is flat. Take off only the post. Do not go deeper.
Reassemble. Place the switch boot in place and then insert the retaining ring. To get the retaining ring to lock back into place, I found that placing the switch upside down on a small anvil and then applying steady pressure by hand worked well (do not hammer). I tried to only have the edge of the retainining ring I wanted to press down on the anvil. Once that was in I rotated the light and repeated. I tried to avoid placing the center of the switch boot directly onto the anvil.
Result: The button now requires noticeably more pressure to depress. My guess about two to three times as much. It also clicks on at a deeper depth than with an unmodified boot. I can now place the light button-down on a desk and press and the pressure from the desk will no longer activate the switch.
The entire mod was quite easy and fast. It took less than 5 minutes. While this doesn’t eliminate chances of accidentally pocket activation it certainly makes it less likely.
My Yihua YH-858D hot air rework station arrived a couple of days ago so I’ve just done my first emitter reflows.
First I desoldered a few dead emitters and reflowed an LH351D 4000K 90 CRI from AEDe’s second group buy onto one of the old MCPCBs (destined for a Thorfire TK4A), then I decided to replace the CW XP-E in a SingFire SF-348 with a LH351B 3000K 90 CRI also from AEDe.
Above: Comparing the 3000K LH351B to a Nichia 219C “BLF” 348 with a particularly poor tint.The picture was taken on my phone so all settings were auto.
Now that I’ve finally started reflowing emitters my next goal is to make some illuminated tail switch boards before eventually assembling some drivers.
I KNEW I was doing something WRONG! I always hold the copper MCPCB by hand and use a 3” belt grinder with a 50 grit belt…. sucks when I forget the water…
Today I rebuilt an sk98 for Larry.
Filed and pressed a Cu disk into the pill, built a moonlight special (1+7 7135) driver for it running BLF A6 and swapped the XP-E2 Torch out for a more useful XP-L HI.
Optic loss is quite high (as with any cheap zoomie) but it’s doing 694 OTF zoomed out / 354Lm zoomed in at 2.94A.
I then wanted to fix a personal light which died last week, diagnosed it as a dead switch and digging in my crap pile collection of good stuff I found a baggie of them and put the light back together only to discover the button cover didn’t make contact with the button! The culprit? Switch height difference.
So then I got my surgeon hat on and rebuilt the switch it’s self, took the tall button from the bad switch and put it in the good short switch and it works!
Does anyone have a link to get some more of the tall kind (the left one)? I didn’t realize there were more than one and all of them I have are the short ones.
RIP SPC Joey Riley, KIA 11/24/14. Now I am become death, the destroyer of worlds.
..or the fastest option: a drop of Norland64 (or other UV curing glue) on top of the switch, illuminate with your favourite 365nm torch for 10 seconds and presto!
Nice work everybody!
I am a bit jealous of you guys! I have never really been mechanically inclined, although there are Three engineers in my immediate family!
My specialty is being an expert battery re wrapper! in addition to being a fanatic about numbers,,,,battery cycles, run times, purchase dates. born on dates,,ect.which I all document.
My closest thing to a mod was changing the boot and tightening the retaining ring on the tail switch!
You have to start somewhere..My hiking buddy is an expert at soldering,,,27 years experience. His dad taught him when he was 15 years old. Maybe he could teach me.
ohhh yaaa,,I did take my computer apart once, removed the fans and lubed them w/ NO-OX-ID. It did turn out good, it just took me twice as long as it should have because I struggled remembering how all the parts went back in because I did not memorize/pay attention enough while I was dismantling!!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
Today i did not mod a light. But something that will help me mod lights in the future. I have no access to a lathe or a mill. So i bought a drillpress stand (and modified it) to be able to do small milling jobs on soft metall parts (like flashlights). But the old and tired dremel was not cutting it. So i bought a Hilda grinder from BG. But i did not notice that this grinder would not fit the 43mm Holder inside the stand. And making a adapter is not so easy when the head on the grinder is conical. After talking with kiriba-ru (i have to say thanks for his thoughts) i decided to use what i have and try to make something conical straight.
First i clamped a 6,5mm drill inside the Hilda grinder (max he can handle) and the other side inside the vise. From the top i use my dremel and turn the Hilda grinder slowly by hand. With a sliding table i controll the left right movement.
First i decided to let a 3mm ring at the upper end of the head. I did this because i was thinking that i could open up pockets in the material if i take to much material away.
Working slowly turn after turn (it took some time with the old and tired dremel)
In the end i decided to take the upper ring down i first had left there. This was not the best idea because i was right with the pockets. On every of the 3 corners i opend a pocket in the material. I used some “bigger” aluminium shavings and mixed them with JB weld and filled the pockets up. A day later i grinded everything down and used some sandpaper to get a better surface finnish. Now i have a straight 35mm area on the front. Next step is to get a 35mm to 43mm adapter. When ready i will have a lot more torque campared to my dremel. And i can use tools up to 6,5mm inside the Hilda grinder (dremel max 3,175mm).
I guess you didn’t lose any intensity
The 2mm² variant has more current capability, mine is fed by a Liitkala 26650 through a TA FET driver.
550kCd in an Amutorch JM70
Nice! How many lumens?
I have a black flat in my jm70. 605 kcd 780 lumens.
You can find them on ebay or aliexpress, there are sets with 400-600 pcs (20-30 types x 20 pcs), they are only 6-8$ or something like that. Link Check out this ones.
I didn’t made a Lumen Box yet, and don’t really have stock lights to calibrate it…
I’ll have to check the tail current but it’s not easy with that construction.
I would guess at least 1200 lumens, we’ll see
"-X3-, is there any place in your house without a flashlight ?"
Oh, a double post…
Sorry I forgot the last mod.
Done yesterday :
Black Convoy S2
OP reflector
Samsung LH351B 2200K
Biscotti driver with only 1*7135 and mode 8 so only 50% on High (175mA so about 60 lumens !)
Blue illuminated tailcap but tamed with 2*5kOhm resistor
*Protected *3400mAh Olight 18650 inside
You got it, it’s for my 2yo son
I’m lucky enough to have a lathe…. motivated enough to use it too The last few days I’ve been putting in some time here and there. Head is bored out, pill is made, bezel is made, body is bored and threaded at one end. Taking my time getting the fit and finish nice. These are the only pics I have so far.
With the help of my brother who has more soldering experience than me, I finally did the driver swaps in my Convoys. We struggled a lot with a too-weak soldering iron, but in the end I can proudly say none of the lights in my house have the dreaded blinky 3/5 firmware now
More adventures with the HarleyQuinn flashing key. The partially assembled driver is now running Anduril. Specifically the tint mixing (Lantern) branch
I swapped leds in a grey D4 twice today and both leds are not what I hoped for.
Start: grey D4 with XP-G2 S4 2B. I had a D4 before with these leds and they were the old type that had the best throw when dedomed. This grey one has new type XP-G2’s.
On fresly charged 30Q, at 10 seconds:
3030 lumen
16.1 kcd
When removing the ledboard, the heatsink paste left on the shelf had a distinct pattern, likely it accumulated at distinct postions when the light heated up during use, which does not sound ideal to me. It will be replaced with AS5.
First led swap: 4000K Luxeon V2, from Arrow. I expexted a comparable tint as my D4 with Luxeon V’s, but it was not so. The hotspot was a bit yellow-ish and the spill a bit pinkish. Only a snob is bothered by it but I hoped for the close to perfect tint that the Luxeon V has in my D4. Perhaps the smaller dome makes it behave different in the TIR, not just making the smaller hotspot. I must check this led in a reflector light as well these days.
On a freshly charged 30Q at 10 seconds:
3714 lumen
18.8 kcd
The output at least is pretty good!
So further to another led swap: 4000K 80CRI LH351C’s. I found those at Arrow for 80 cents a piece with free shipping. The 90CRI variants that maukka tested were too much above the BBL, perhaps these are better, just like the 4000K 80CRI Cree’s often have good tint. But no, the tint of the hotspot was also above the BBL so not perfect either. At least the beam is slightly better than with the Luxeon V2: not yellow in the hotspot and this time some bkue in the spill. Btw, nothing of this can be seen on photographs so I won’t bother with beam shots.
2817 lumen
Did not measure throw.
So the output is less than both the XP-G2 S4 2B and the Luxeon V2, but with this so-so tint the 80CRI is not really worth that IMO.
Result today: a not so impressive D4 with messed up ledwires after 2 swaps, and some new knowledge about 2 leds I was curious about. Up to the next promising led to check out
I did 2x L1V2 4k and 2x L1V2 5K, it probably takes the yellow out some but the pink remains I believe. Need to double check. I liked it better than the 80CRI 219C 5K that was in it but, like you, I think the original Luxeon V 4K is really nice and even.
Speaking of the D4, here is mine with its new Neodymium magnet :
I put the body and tailcap in the lathe at work and did a 15mm hole through it.
I then put a 3mm thick magnet and glued it along with the spring board with some loctite
Mine’s a lot smaller than most of the mods in this thread, but I swapped the emitter in my Nitecore TUBE with a 95 CRI 5mm YujiLED. I’m very happy with the results. The current limiting resistor also had to be swapped. I put in a 33 ohm resistor. This should give me about 36mA to the LED.
Reviewer for ThorFire, Olight, Sofirn, and others.
Not something I physically created today but I did the layout on this 15mm Utorch S1 3 channel driver. 1+4×7135+FET built for Anduril. Probably the most insane routing job I’ve ever had to do. Space was at such a premium I had to put a resistor under the Tiny85 (which has bent pins to fit on a T13 pad so it’ll be slightly raised off the board)
Here’s the copper layer
I was going to suggest to drill a small hole between the pads to let R4 sink into the board, but then I saw that even in that small gap is a trace running.
Not something I physically created today but I did the layout on this 15mm Utorch S1 3 channel driver. 1+4x7135+FET built for Anduril. Probably the most insane routing job I've ever had to do. Space was at such a premium I had to put a resistor under the Tiny85 ...
I "think" I have an S1 and would be very interested in this as well, thanx CK!!
You probably know this, but I think the most important parts are the C1 cap and the R5 resistor (4.7 before the diode). That 4.7 was the key to cleaning up the signals, DEL discovered. Not sure if the 47 ohm and 100K are that super important. Of course the diode itself is optional, but adds reverse polarity protection.
I'm not a fan of the triple channels - I prefer the simpler FET+1. I had a lot of troubles getting the FET+bank+1 ramping looking smooth and it's still not that smooth. Not sure if TK worked out the kinks in Anduril, but if she did, would love to see how. I believe, not sure, she overlaps the channel transitions which may have smoothed it out. The NarsilM FET+1 tables ramp great, but the triple has a noticeable transition. Of course to create the ramping tables, I used TK's tool, a Python script, to build them. The other major problem with triples is they use up my limited supply of eagleclaw 7135's.
Not a problem because I can still use this driver as a FET+1 with NarsilM v1.3.
Ugly, but it gets the job done. LH351D 4000K 90CRI, GET TO THE COPPAH
Beam is good
Cool! I have one of those Work Sharp knife sharpeners too. Love it.
BLF Member Map Add your name and location.
Looks great!
contactcr, excellent job AND writeup
Or when you shoot it into outer space.
crap pilecollection of good stuff I found a baggie of them and put the light back together only to discover the button cover didn’t make contact with the button! The culprit? Switch height difference.So then I got my surgeon hat on and rebuilt the switch it’s self, took the tall button from the bad switch and put it in the good short switch and it works!
Epoxy a small disc on top or silicone an extra piece of rubber on the boot.
- LEDs & Other Stuff - - UI CheatSheets - - CRX Mods & Builds - - Stuff for Sale -
- The Old Lumens Flashlight Modders & Builders Challenge is Now Open - Link -
link to djozz tests
WOLFDOG
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
That is really cool Docc! The result looks professional, you would not expect the make-shift method from that.
And of course to let the old tool make its successor is a very satisfying concept
link to djozz tests
Link
My Flashlight public album (mods, emitter swaps, eye candy)
My reviews channel (French language, Olight, Thorfire, Sofirn, Lumintop : 60+ lights tested)
My personal channel (including Olight SR mini, S1, S2, S1A and S-mini disassembly)
M4DM4X blog, saves you $$$
Oh, a double post…
Done yesterday :
Black Convoy S2
OP reflector
Great job Docc
7th O-L comp -- Big PITA build -- Head only build --Vape conversion #4 -- Gold paisley -- UF2100 Makeover -- Ti-mo -- 6th O-L comp entry -- Titanium Build -- Hunting Light -- 21700 Tube Light -- Stripey mtg2 Light -- UV Light -- Colour V4A Light -- Copper 26650 Light -- Quad xhp35 Light -- Finger Sizzler -- Mechanical Mod Light
What driver are you running it on? I’ve got a host (amutorch AX3) inbound that I think will be a good test platform for the lantern branch of anduril.
3030 lumen
16.1 kcd
3714 lumen
18.8 kcd
2817 lumen
link to djozz tests
Very elegant solution on the D4!
I’am building a fet+1 driver now and it will go in a Skilhunt DS20 with Luxeon V2 led and Andúril firmware.
Reviews: Sofirn SP40, YLP Panda 3R and Unicorn, Armytek Prime C1 Pro, Acebeam M50, Imalent MS18, Convoy M3, Nitecore TIP2, Imalent RT70, Wuben T70, Sofirn SP32A, Thorfire VG15S, Thorfire VG10S, Thorfire TG06S
Mods: Astrolux MF01-20K, Small sun T08 MT-G2, Eagle eye X6 triple XPL, Ultrafire F13 MT-G2, Convoy C8 XHP70, Solarstorm T3 triple XP-L HI
Big flashlight measurement and beamshot collection
3D printing stuff for flashlights
My flashlight related Instagram
My Flashlight related Youtube channel called Zozzlights
My Patreon page to support my reviews and mods
Mine’s a lot smaller than most of the mods in this thread, but I swapped the emitter in my Nitecore TUBE with a 95 CRI 5mm Yuji LED. I’m very happy with the results. The current limiting resistor also had to be swapped. I put in a 33 ohm resistor. This should give me about 36mA to the LED.
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
link to djozz tests
Wow.
Love your work.
djozz quotes, "it came with chinese lettering that is chinese to me".
