Excellent review, thanks. I appreciated the graphs and analysis. Strange that PWM is present only on M2. The waveform certainly seems similar to the other lights you examined in your optical sensors review, found in your signature.
Not being an electronics expert myself, what are the units of the y-axis in your optical sensor graphs? And is the difference in peak and trough the light switching on and off?
The oscilloscope waveform graphs are voltage (Y) over time (X). The voltage is merely the output of the sensor itself - defined by how bright the light is. The actual unit of time is dependent on the time scale setting on the scope. Same for voltage. So both may be different for each measurement. And yes, a clean square wave represents the light turning off, then back on, usually too fast to see with the naked eye (in most cases), unless it's strobe.
Thanks a lot for the review. The runtime graphs are excellent and they are one of the very few ZL reviews to actually include them. The thermal regulation looks great and 2,000 steady lumens is really impressive under the right cooling conditions.
I must say I’m almost sold, but I’d love to see some outdoor beamshots first.
Looks like a nice 21700 light.
But considering the light only has 900lm output (turbo doesn’t count) and for me Zebra is mostly known for extreme PWM, I’ll skip this light.
Baby it's cold outside - and wet and rainy up here in the Pacific Northwest - so I can't motivate myself to go outside for beam shots - and I'm not as bothered by tint variations as some. I assume the "other" forum will have beamshots up soon. I wanted to focus on the technical stuff I'm good at.
Are more recent Zebralights (say the last 2-3 years) known for PWM? Although I've seen some minor ripple, I haven't detected any obvious PWM on my other three Zebralights (SC600fd IV Plus, SC600w III, SC53Fc).
Great to see that the light hits Zebralights claims. Even the temperature is on spec (on all current Zebralights with PID the target temperature in the default setting of the PID is 50°C/122°F).
It would be interesting to see (in case you want to and/or have time to do some further testing) what the sustained brightness (and runtime) is with the PID turned all the way up (and possibly down as well), i.e. runtime graph with PID +5°C (and perhaps -5°C).
Yeah Zoomie’s impressions are quite a few generations old now. I’ve got lots of Zebras, from the old to the new, and visible PWM hasn’t been an issue for a long time now. What has been an issue, however, is their reliance on Cree’s latest-gen emitters which tend to have…um… less-than-perfect tint and tint-shift. Some folks are more bothered by it than others of course, like PWM for that matter, but if anyone is holding off on these newer Zebras because the old ones had slow PWM, they should stop holding off. Current Zebras are awesome lights that definitely do not have noticeable PWM.
Thanks for the review Terry. I’ve been on the fence about this one because of the XHP70.2’s weird tint-shifted corona issues, but the light is almost nice enough to make me overlook that
Did you notice that I snuck in a graph for the SC600Fd IV Plus? It's gives a nice comparison for both lights at about 583 lumens. The SC600Fd graph (@ 557 lumens) was done last summer for my own interest, don't have any graphs for higher levels on the SC600Fd.
Don’t know how I missed that. Thanks!
One good reason to upgrade to buy the SC700D is that it can run at a much higher sustained output over the smaller siblings.
Great review, I also linked it in the german TLF.
Looks like Zebralight delievered us a technically perfect flashlight again, I can’t wait to get mine.
And it would be great if you would write the temperatures also in celsius so that every non american reader don’t need to read it with a calculator at hand.
I got my sample last week and it is amazing to think how far ZL have come as a brand. I wasn’t super early to adopt (SC50/60 era) but jumped on as soon as I saw the critical acclaim the 750L SC600 received.
This is slightly bigger, obviously, diameter wise, but not much changed in terms of length. The main thing is it is so much brighter and efficient and is also HI CRI!! Not only that but it will look after itself and not over heat. Marvellous!!
I used mine as a bike light and the max output was fine for pretty fast offroad trail riding. I wouldn’t hit downhill at night anyway but others may find it bright enough to inspire confidence for that too…
Overall it is a great light and I see ZL selling A LOT of these…
I actually want the flood version now too to replace my SC600Fd just because the 700 seems so much more stable in terms of output
I would also be interested in the floody version. I emailed Zebralight sales, and asked if they could do a custom order for a floody SC700d with the frosted lens. Their response . . .
"We will release SC700Fd in mid or late Feb, 2019."
