I haven’t attempted to open one, but it looks like the driver is glued in. It’s a FET+3 design, roughly 23mm across, and has spring-side pads for reflashing… but I think the aux LED board must be unsoldered before reflashing will work.
Pretty sure the MCPCB is a copper DTP type, because that’s what Fireflies’ other lights use, but I haven’t taken mine out to confirm.
Goodnight/sunset mode starts at a low level, then gets dimmer for an hour, then shuts off.
Beacon mode uses the last-ramped level for its brightness. So yes, but the adjustment is done outside of beacon mode.
Candle mode’s timer can go for up to 4.5 hours. Each triple-click event adds 30 minutes to the timer.
[/quote]
THANK YOU so much ToyKeeper! This is the first time I have seen or read about the Goodnight, Sunset mode? I was sort of wishing there were settings of less that 30 minutes for the candle.
thanks for all these wild options! The Party Strobe can get really crazy while adjusting Lightning Storm is cool, Everett did that one a long time back.
Thanks. Glued in, ok, hopefully not to hard to remove. I will be replacing the driver all together. As it’s 23mm I’ll have to get new boards made. Can you see if it’s perfectly round or if there are alterations so it fits in place?
Yeah, it would be weird if it wasn’t copper DTP. It was just that the little that can be seen in earlier photos looks a little funny, but come to think of it, copper DTP boards can have any color with anything on them :person_facepalming:
For that matter, there should probably be some documentation. I haven’t written any yet.
All it has now is a text file I was using as a todo list while writing the code. I sketched out the UI concept there, then checked off the items one by one as I implemented them. Sometimes this gets mistaken for a manual.
Mine took a long time to arrive but worth the wait.
I opted for XP-L HI version, CW tint.
I have the same tint and LED in a Emissar D4 and D4S which I am really impressed with.
The E07 is brighter than both the Emissar lights. That was expected although not easy to accomplish. It stays brighter far longer and cooler than the D4 but again, that’s expected. I am running a Sofirn 21700 4000 mAh cell while I wait for higher amp capable cells to arrive.
I REALLY like this light. It’s a flooder but with effective throw. I like the UI. The AUX LEDs are cool. It’s extremely bright and well built!
My only complaint: 4 rapid clicks to lockout is silly. I twist the tail-cap anyway so all the AUX and switch LEDs go out.
Yea, really happy with this combination. They sure look purple to me, and you also. The order said they were blue. I think I would prefer purple. I didn’t have a choice but if I did I think mine would have been the clear body. Waiting to see pictures……
I received my E07 today, ordered with Nichia B emitters. I put a Samsung 40T 21700 battery in it (positive towards head) and the only sign of life I can see is 2 of the LEDs on the switch are on. Same goes for using a Sony VTC5A in the 18650 adapter. No function at all when pressing the switch. Or press and holding the switch. Thinking that maybe the light comes in lockout mode I tried 4 presses with no difference. Unless there is some secret series of presses needed to make the light work, it seems my light is DOA right out of the box. Not completely DOA because the 2 lights on the switch do come on, but I was hoping for more than that. There is a stamp on the side of the box where it says (checker) that says PASS and has the number 12 next to it. The shipping box looked in perfect condition, so did the inside product gift box. Not sure how a light could have been tested, passed inspection, then shipped and now DOA.
Can anyone think of something obvious that I am doing wrong to get this light working?
I am sending a copy of this post to Fireflies (whoever started this thread) via PM.
Any other suggestions would be greatly appreciated. Not sure right now if I feel this light is worth shipping all the way back to China to get fixed, if it is in fact defective.
FWIW, even the lockout mode should light up when the button is pressed… though only at a dim level.
It might be interesting to see what the light does if you click 7 times, or 3 times. But it sounds like something in the driver may be preventing the MCU from receiving power at all, because when the battery connection is made it should flash the main emitters briefly in order to confirm that it booted and is now operational.
Thank you for your response ToyKeeper. I tried 3 presses, then I tried 7 presses with no response. If I unscrew the tailcap (as in locking it out) the 2 LED lights in the switch go off, but when I screw the tailcap back on they go back on, but no main emitters flashing briefly.
I guess I will have to wait for response to my PM from FireFlies.
F-O-M, if you put the cell in and then use something to bridge between the negative end of the cell and the bare aluminum end of the battery tube, do the emitters blink the “go” flash? If not, then your battery tube may not be connecting to the driver for ground. Is the battery tube installed in proper orientation? There are other things to check, but most of that depends on the answers to the previous questions…
DB - I bridged the aluminum end of the battery tube to the negative end of the battery and no result. While both ends of the battery tube have anodization removed, the tube will only thread in the way it came. The opposite end threads (made for the tailcap) will not thread into the head. I contacted Jack of FireFlies via email, and he responded pretty quickly saying that he will send me another light using expedited mail (15 - 20 days) and asked if I would send the defective light into a US mailing address. I agreed to do that and asked him for the address, but still haven’t received a response.
Yes, I am in the US.
Thanks for your response DB Custom. Appreciate the effort.
