Martin,
any chance for a new code for Rofis MR70?
my first deal is still working (prices did raise lately)
but sure - i can ask if its possible to get a better deal
Hi M4D,
Is it possible to renew the code for the nitecore hc60?
Thanks!
will try!
Hey
please remind me after the Promotion (no code would work now)
Hi Martin,
any code for the
HaikeLite MT01 Trekker XHP50
clearance!
some stuff that must go...
https://m4dm4x.com/clearance-deals/
since my deals get stolen from BLF to be published on commercial pages í cannot post "exclusive" deals here atm
i hope you understand
also nice:
15% OFF a lot of items!
WHOLE SITE! - comment your best catch!
use this link: https://goo.gl/8p92MU
Code: 502C6B
Hello my dear friends!
Neal sells a very nice light for a very nice price:
NIGHTWATCH NS22 SEEKER
SST20/SST40/XHP50.2 LED FLASHLIGHT
Specification:
Emitter: SST20 (1250Lm available in: 3000K 95CRI / 4000K 95CRI / 5000K 75CRI)
SST40 (2100Lm)
XHP50.2 (3200Lm)
Battery: 18650 (not include)
If you want to use 21700 battery,pls add the option 21700 tube
Reflector: 38 mm,aluminum,smooth finish
Lens: Glass with anti-reflective coating
Body: Aluminum with Type III hard-coat anodizing
Swtich: 20mm,10A reverse switch
Ingress rating: IP68, underwater 2 meters
Weight: 184g without cells
Dimensions: 41 mm head x141 mm length
please use my SHOPLINK and the Code: NDNS22 to get 17% discount
also available:
NITECORE MH23
CREE XHP35 HD 1800 LUMENS RECHARGEABLE LED FLASHLIGHT
51% OFF (38.99 USD)
Klarus Mi1C and Astrolux MH10 codes expired, could you get new ones?
i just received another list with deals:
please note: do not share my deals on other places!
Item | Code | Coupon price |
IMALENT DT70 | CHBF1 | 165,00 |
Folomov A1 | HBGLK | 5,69 |
FOLOMOV 18650S | drop directly | 20,50 |
IMALENT HR70 | JKLH1 | 53,00 |
LUMINTOP EDC05 | BGED5 | 22,00 |
Ultrafire 7W Zoomable | drop directly | 2,69 |
Nitecore EC4S | BGEC4S | 58,99 |
Convoy L6 | BGCL6 | 44,84 |
XTAR VC4 | drop directly | 14,80 |
NEW Convoy L2 | drop directly | 35,49 |
Astrolux MF02 CW | BGMF02 | 75,00 |
Astrolux MF02 NW | BGMF02 | 75,00 |
DQG Lighter 2.0 | BGDQG1 | 18,22 |
DQG 4th | BGDQG2 | 24,50 |
DQG Hobi 10180 | BGDQG3 | 16,99 |
DQG Fairy Brass | BGDQG4 | 16,99 |
DQG Slim | BGDQG5 | 23,75 |
DQG XP-G2 | BGDQG6 | 31,99 |
DQG Capsule Mini | BGDQG7 | 6,69 |
ThorFire VG10S | BGS70 | 15,99 |
ThorFire TG06S Upgraded Version | BGT6S | 11,90 |
ThorFire TK05 | BGTK05 | 14,99 |
ThorFire C8s Suit | BGC8S | 19,99 |
ThorFire 360 | BG360 | 6,99 |
5Pcs USB Mini Night Light | drop directly | 1,10 |
due to code stealing and brainless publishing of some 4$$holes i cannot get new Klarus deals atm
/\ … …. Utterly amazing what dipshytes a very few people can be…. but messing things up for Martin & everyone else.
Excuse my ignorance, but how the “drop directly” works?
Thanks!
i hope they fix those tomorrow - sorry
M4X: And what about that Astrolux MH10?
i ask for a new code
Many of you asked me where to get the RovyVon brand with "Member Benefits" - so i pulled some strings...
banggood listed at first 2 modells (the link in the pictures take you to the shop for detailed infos)
do not forget to check my list for the deals
RovyVon Angel Eyes E300S
Features:
- Rectangle EDC Angle LED Flashlights
- Made of aluminum alloy with Hard Anodization III finish
- Utilizes 3 x CREE XP-G3 S5 LEDs, max output 2000 lumens
- Uses replaceable rechargeable Li-polymer 2200mAh battery
- Max 5C discharge rate
- Micro USB charging and quick charge
- Breathing charging indicator and low battery indicator
- Overcharge and over discharge protection
- An internal thermal control sensor
- Ergonomic design for a comfortable
- Heat dissipation and anti-slippery grooves
- Strong detachable reversible pocket clip
- Stand capability
Parameters:
Body Material: 6063 aerospace aluminum alloy
Clip & bezel material: Stainless steel
Dimensions: L101mm x W36.7mm x H17.3mm
Package Included:
Accessories: 1 x 1m paracord, 1 x Clip, 1 x Micro USB cable, 1 x extra USB port cover
RovyVon Aurora A5
Features
- Semi-transparent luminous body glows in the dark
- CREE XP-G3 LED, max output 550 lumens
- Sidelight: White, Red, Red flash
- Built-in Micro USB charging port
- 130mAh lithium polymer battery
- Charging indicator & quick charged in 45 minutes
- Side switch prevents accidental activation
- Ergonomic design, one-hand operation
- Tail paracord hole
- A lanyard and two-way clip included
- IP65 water resistance
What's in the box
- 1*A5 flashlight
- 1*User manual
- 1*Beaded chain
- 1*Clip
- 1*USB cable
- 1*Lanyard
*The max output 550 lumens at High mode will step down to 65 lumens in 2 minutes to protect the user and the core components of the light from the heat produced by the light working at High mode.
