I also don’t see any issue using WF1mm with FET DD single 18650 setup.
As you said we just have to add more resistance like longer thinner wires, no spring bypass, low current batteries…
For example FET DD setup will work this way(with low current battery) 4.2V > 3.5V = 5.7A > 3.5A…
Proportional current drop happens when we turn on the light so no freaking chance of overcooking the led and very constant performance on lux meter to… :+1: Yes! Lux performance should not drastically drop… It will not drop even 10% from 5.7A-5A…
Since led has very constant performance we will not notice significant performance drop even up to 3.5V/3.5A of battery discharge, and even beyond that mark… FET DD cools itself naturally when performance starts dropping. So what is bad in that?
So even with unregulated setup like WF1mm + FET DD can work just fine.
Now since I also use Uni-T clamp meter it seems that current measurement are bit lower than originally measured on UNI-T clamp meter but that does not changes anything… In fact… Even Better!
And then you go on describing the somewhat ambiguous solution to resolve the issues…
I mean, you choose to over drive the LED up to 5.5.Amperes on a freshly charged cell, which doesn’t even add output anymore.
Sorry, but i just don’t get it.
It’s not as if there are no proper CC drivers out there.
Nothing against proper CC drivers but nothing bad with FET DD either.
5.5A with constant and proportional current drop like in FET DD setup is not overdrive. It is just fine… So natural current drop with FET DD also means less temperature stress plus FET DD does not generate any heat on driver board while CC linear does generate?
Where can I get a 21 mm or 28 mm CC driver at 5.5 amps running decent e-switch firmware like NarsilM or Anduril with as low, or lower parasitic drain? I do really want to know because I can't keep up with all the goin's on.
I'm confused because since when is a 17 mm power switch driver the only one we need? Granted, it's the most popular but for my usage, it's still in the small minority of flashlights I have or am interested in.
Yeah, you’re right.
Limited choice.
Not sure what Lexel has to offer though.
As for diameters, you could use an adaptor ring of some sorts.
Either way, i’m looking for e-switch 17mm FET CC drivers.
I don’t care too much for elaborate UI’s though.
3 modes usually suffices for me.
I will work on D1S and likely some other sizes CC FET drivers, but this will take 5-6 weeks at least to get to production if first design works out well
