the other day i replaced the driver of my dads utorch ut02. When i put the battery in, the side switch lit up but no light out the front. After a quick search it turned out the tube that was in the wrong orientation.
the E07 has different threading on both sides of the tube ;)
Yeah, so I’m wondering if a particular light might have a slightly short tube that doesn’t contact the driver when assembled? Or on the other end, the switch PCB? Perhaps a shorter cell would allow this light to function properly?
easy to test with a 18650 and a wire without the tube and tailcap...
thats my first test (direct at the driver) usually if something does not work
My rot66 had a similar problem; lit up in the beginning but weak, later died completely. Not even any of the switch or aux leds turn on anymore. Of course I did M4D M4X test of connecting the head directly, no change.
So the problem F-O-M has with the E07 also happens with other models.
Can we have a built in USB charger?
Martin, that SHOULD be an easy test, but a slip and all kinds of things can go wrong. I was testing a 30T on my 17 emitter Ham’r and the wire slipped from my grip and shorted… ever so briefly with the tiniest of sparks… killed my monster. Well, it worked, but only the FET’s worked and it wouldn’t shut off at the switch. So I had to completely disassemble the entire light, all 5 drivers, and replace the RPP diode and all 5 7135 regulation chips. Works now, but what a pain it was all due to that one easy slip…
I think all the Fireflies I’ve seen have purple led buttons. Should they not all match unless specified?
E07 and PL47 always have purple button leds regardless of what color aux leds you order. I don’t know about ROT66.
How cool would it be if Jack had matched his lights to specific Firefly colors? Each model having it’s own distinct switch color?
“When fireflies give off light, they do so in a handful of different colors. These colors include vivid yellow, yellowish-orange, green and yellowish-green.”
And yes, I’m aware that my post count is, once again, about to trip an epic rollover… how does this happen? I may have to make a light from scratch for this one, seeing as how it coincides with the new year and all…
Since there are trimpots on the aux board, am I right to assume the bezel is not glued?
There are pots on the other models with glued bezels too…but yes, the E07 bezel is not glued.
I AM IN! :D
I wish they would have made it more clear that the button LED color is always purple. had I known this, I would of course had ordered purple aux instead of blue…
Come on, whoever thought that it is a great idea to offer different LED options and then not match the buttons, what where you thinking…
I already know I will hate this. Probably I will just try to find a way to cover up the button somehow or just disable the blue aux. Sigh.
Is the button on E07 as mushy as the one on PL47? I’m still on the fence and while I love the idea of clear ano I’m worried of QC issues. Has anyone received this flashlight without any flaws?
I have 2 pl47. One has mushy button and the other one doesn’t.
Thanks for the pic!
My guess is the E07 on the picture has the “purple” aux-LED (Fireflies website list “ice-blue” and “purple” aux-LEDs, though NealsGadgets had also “red” aux-LEDs for the E07).
The middle PL47 has the “ice-blue” aux-LED (I also got the PL47 and the aux-LED looks the same).
The rightmost one — is that a different aux-LED or is that the low-voltage “red” color (looks “amber” or “orange” in the pic)?
You can’t put the tube in backwards on an E07. The threads are totally different.
My EO7 will hopefully arrive tomorrow. Hope it works with no defects. Keeping fingers crossed!
Anyone have a picture of an EO7 next to an Emisar D4 with 18650 tube?
