Martin’s solid wire fix works fine but the wire I have on hand is too thick and exposes the oring completely so I used the copper washers I had already for the PL47
If your battery got crushed it’s likely because it HAS to be shipped IN the light which is not a good way to guarantee a battery will not be crushed. If you have something NON conductive you can probably pry it back up a little but the battery should be safe to use if it makes contact. Now you know, stick with your separate purchase for future batteries.
I’d like to thank those that shared the info about their lights.
I’ve been contemplating an E07 of my own, but I’m afraid I’d have to wait until they get the kinks out (battery tube length, proper screw placement and unmolested optic) before I’ll consider it again.
I know that these first runs can be a little risky, but dang, some of this seems very sloppy.
There are 4 holes. One for each leg. If you look into those holes all 4 should look identical with a white dot at the bottom.
In my light, I can tell one leg is broken off because the 4 holes do not look identical. 3 of them look the same, but the 4th looks noticeably different.
I’m currently reviewing the XPL 6500k, I’m getting 8300 lumens at turn on, dropping sharply to under half that by 15 seconds. It only gets hot though if you bash another 15 seconds within 10 minutes.
One last complaint. I was feeling the threads on the tailcap end and it sliced my finger open. Wow. Be careful people them threads are sharp. First time ive ever been cut open by a flashlight.
Adhara the tolerances are so tight and the spring bypassed to keep the output high. If they soldered multiple of the layers of the spring together by accident it could be too tight. My batteries sit flush with the light when the tail is off and fit fine.
I feel it is important to point out people who like their lights tend not to complain about them. You are mostly hearing about the trouble, folks with trouble, are having, because they are the ones talking most.
Do what you want with that information.
the e07 is easily the best edc i have ever owned. And i have owned- many-and regularly used many, for a very, very long time.
First impressions of my yellow E07 now that I’ve tried it with a fully-charged 30T:
Ridiculous output. MUCH brighter than a D4. It’s basically as bright as a good popcan light, but in a much smaller package. My XPL HI 4000K E07 is noticeably brighter than my Nichia 219B ROT66 in a ceiling bounce test.
The light looks good with good looking anodizing. The bezel and switch lights look great.
The yellow anodizing is grainy, like fine sandpaper. This provides better grip, but many people dislike it as it feels a bit like holding a stick of chalk. Comparable textured anodizing is found on the grainy Emisar D4.
As expected the E07 is a bit too large for pants-pocket EDC. The size is better for jacket pocket-carry.
Even though the output is like that of a big popcan light, the E07 is much smaller and is much easier to hold in the hand.
I like the Anduril UI better than the D4 UI. Electronic lockout is a more sensible 4 clicks instead of 6. And I like having double-click from off go to an adjustible ramp.
Overall, this is one impressive light. Well worth adding to any flashaholic’s collection.
So i fully charged my samsung 40t and let the light run for 15 minutes @ 577 lumen… i detect some kind flicks or PPM later. the light is xpl hi 6500k. how can i fix it ? Thanks
Have you tried adjusting the temperature setting? If you check out AdventureSportFlashlights E07 review it looks like it drops output before even getting hot. Lame default setting for sure.
Beware that even if one looks completely different, you can still have optic without any broken leg. My optic is fine and one hole looks different. That is because one leg is dirty - it’s bottom part is slightly covered by excess thermal paste. So, you will never know until you take it apart
Mine arrived today. I went for grey with 219B and purple aux, and a 40T.
Of course it has a screw in the wrong hole, and a broken leg. I can see the stripped phillips head through the front. Also, the switch lights are not aligned with the body.
Apart from these issues, the light looks and feels great.
I appreciate that and understand your point completely.
Still, it’s hard to ignore that Fireflies has had some challenges with each of their last three releases. Not just one or two reports, but there have been more reports of complaints that make me think I see a trend.
I’ve said before (maybe in this thread) that this light could be a game changer with the output, size, UI and even the awesome looks. I would love to buy one, but the repeated reports of very similar issues makes me pause at this time. I’m not asking for perfection, just tightening up on the details, which I’d bet could be solved down the line with a little care and attention.
I’m not trying to dump on Fireflies. They are putting out lights that appeal to many of us here. They’re doing their homework in the areas of size, features, UI and power. Now if they could work out the kinks. they’d be quite the company.
I’m using default settings for my review but tbh having the temp set low allows me to reapply turbo within 10 mins. If you knocked the temp allowance up you could get another 10 seconds maybe initially but you would have to dial it right down or it’ll continue to get really hot and going to turbo again would be pointless, it’d step down in a second and get you over 60c as it continues to step down to a few hundred lumens.
I’ll probably whack it up a bit though as I only use my lights for reviews and showing off, never for sustained use.
