Andúril 2 coming to Sofirn - The general Sofirn development thread
I would love an SP36 in a 3500K to 4000K. Maybe even with SST-20’s.
Updated sf30. Could be simple as driven harder to produce 1000 lumens.
Or a emitter swap to xpl hi.
Or even another sale again. About a year ago these went on sale for $5.99 on amazon. Discount code maybe?
Do you plan on producing the SP36 with Andúril?
So far, Sofirn is already collaborating with Utorch. Right? I ask you to think about the idea to renew or buy out the Utorch UT03 Triple CREE XHP70 project under the brand Sofirn. Or implement it on 3 * XHP50 or 4 * XHP50 emitters.
These would be very practical lights, powerful and without problems with overheating.
Some tells new new colors: Purple, navy blue, sand/tan…
We tried Purple but always more like red, not satisfied.
How does sand/tan color look like?
Sand/tan look good. Also bring back NW tint please.
I would like if Sofirn will soon finish the LT1 lantern and the Q8 extension tubes. Preferably those have matching threads so the lantern can use the extension tubes as well.
Also, it would be great if Sofirn would make another edition of the Q8 using OSRAM KW CSLNM1.TG (1mm2) “Flat White” emitters, giving it a super tight beam with great throw, and still over 2000lm output, in a “soda can” style light.
I still think what could be a real winner would be a tubelight that takes standard 20mm TIR lenses. This way they can be swapped easily (well, as long as nothing’s glued :laughing: ) to go from a tight beam to a wide flood, clear or pebbled, and even oblong (for using as a bike-light).
Sofirn wouldn’t have to source all the TIRs, but it might be nice. But anyone then could swap in the TIR of choice.
Eg, the SP32A would be a good candidate for something like that. Any XP/3535 chip would be a good candidate for TIRs.
Or… if you still like reflectors, a shallow reflector that would be the same height as a TIR lens could satisfy anyone who “needs” a reflector, yet still be able to use a TIR after the fact. Shallow reflectors won’t be good for throw, but (nudge nudge wink wink) would be “made” for substituting a TIR lens.
I'd avoid all the silly colors and stay with solid rich deeper colors like dark chocolate brown dark greyish army greens or dark blue and sand but even then a darker sand like convoy c8 has ..I'd never make pastel girly colored lights no matter how many people asked for orange yellow or pink .never never never .
I'd also almost always make a naked no ano version since it costs nothing extra . High cri lights are always appreciated and Sofirn has gotten a bunch of credit for just those slightly warmer tints(5700?5300k?) vs cool white garbage everyone else uses .
I'd make an interesting Headlamp ...and applaud you for working on a blf lantern project
Gearbest did quit. Don’t know why this project cancelled and don’t know how many people still want this light. But Sofirn do wanna make a new light of >10K lumens.
I personally prefer 4* XHP50.2 emitters.
Correct me if I am wrong but did not Sofirn plan to build a Q8 with 4x XHP50.2 some months ago, did they? That should be feasible without too many changes except for the driver and the extension carriers (2s2p instead of 4p IIRC).
A driver for 4 xhp50.2 might be tricky since I don’t think you can use a FET design. The xhp50.2 are known to be quite sensitive to current consumption and are easily burned up by 2 x 18350 cells. Maybe there is a way to use a FET and still limit the max current? I think Texas_Ace was able to do this with 4S 18650 and 3 x xhp35. Careful selection of MOSFET and springs in the carrier were able to keep the LEDs in the safe zone.
I’m not sure about a Buck or Boost driver designs. Producing 10,000 lumen might require a very expensive driver design. Lexel probably knows for sure since he designed a 30,000 lumen buck driver for 10 x 18650 cells (21v IIRC). His lower powered bucks are still quite pricey.
SP32 V3 maybe with hi cri led, deep pocket carry black clip(silver clip looks cheap), shortcut to moonlight. shorten the length of the light and lastly ability to indicate batt voltage. :slight_smile:
Yea, me too. A small sized but feature pack like Emisar D4. I don’t need 4k lumens but
2k will be good enough without the extreme heat.
I would like to wish the driver is built on the principles of drivers Sofirn SP33 (XHP50) - with stabilization modes, thermal control, only without stepdown by timer.
Turbo mode 6000-8000Lm would be enough.
Light of >10K lumens is certainly interesting, but less massively it seems to me and may require more emitters XHP50, which will increase the price. I think such a special monster should go second in turn.
Thank you for communicating with consumers!
I even pointed out that, re the SC31. It’s a really strong clip, no complaints, but the same typische silver clip just has a cheap look to it.
The 1buk DC clip from FT fits perfectly on lights with a narrow groove (eg, the Nitefox UT20), but on lights with a wider groove, it’ll go (more) lopsided when clipped onto anything, and probably eventually wear out the ano in that location.
Yes.
Get the Sofirn SP32A V3.0 with the SST-20 4000k 95CRI.
We’ll get be getting more throw than the XP-L2, and it’s cheaper for manufacturers too :slight_smile:
You should checkout the purple on the Convoy S2+. They chose the perfect purple tint. My wife likes it.
do you mean body color or led color?
Suggestion — as someone asked above:
I suggest putting a sticker on each light identifying the software installed on it.
So if you change the programming of the driver, change the sticker as well.
