It’s like a night light that turns off, or a reading light that will dim and shut down when you fall asleep reading. That was the intention actually, according to TK.
I use Candlelight a lot, love it. Even with the big 17 emitter Ham’r, I primarily use it in candlelight mode. Lightning mode is impressive, sure it is, as is the tactical strobe, but I use it in a medium level to walk the trash to the road or when taking a hot bath to ease aching muscles/joints… so candlelight is the most used mode for me.
I think it uses the lowest ramp setting, so you can set it to be higher by raising the floor. I don’t believe there’s a settable timer on it like the additional 30 minutes on candlelight. Turn it on and leave it. See what it does…
You know, it is strange that fireflies started this thread and has not chimed in any to address anything. Not even a “we are fixing the issues customers are having with our quality control” ?
None of these Chinese companies prioritize checking these forums. Even for Giveaways which is free marketing for them they have to be reminded to come back and finish it. I reminded Vapcell about their giveaway and they were thankful and completed it within 15 minutes of me reminding them. They said they work out of the office mostly and just didn’t think to check back.
People should just contact them for support and come back here and post about their experience. I’m sure some of the issues are user error and some will be resolved in fair and unfair ways from the manufacturer, like any company and vendor. Those reports are more valuable in my opinion than some of the things being posted.
Yea they dont monitor these forums. You have to contact them directly and point them to specific posts to get their attention. Previously I PM them regarding improving the thermal capabilities of the E07 and got response from them that they will be improving upon it in next prototype
In my light, I can tell one leg is broken off because the 4 holes do not look identical. 3 of them look the same, but the 4th looks noticeably different.
[/quote]
Beware that even if one looks completely different, you can still have optic without any broken leg. My optic is fine and one hole looks different. That is because one leg is dirty - it’s bottom part is slightly covered by excess thermal paste. So, you will never know until you take it apart
can one simply unscrew the bezel and have a better look? I don’t want to break anything! I should and probably will just leave it alone, but am curious.
If you don’t want to risk breaking anything dont bother. There is always a possibility you introduce dirt or mess up a LED or component when re-tightening.
When I took mine off some bits of plastic/silicone/glue or something showed up that I had to clean off the aux board and I felt it moving around when I unscrewed the bezel. I cleaned it off and cant notice anything damaged but who knows. Bottom line, I wouldn’t bother if you would be upset if something broke. In my case I cant leave well enough alone and would have just modded it had I broke it.
I have promised myself I will leave this one alone, don’t know if I can keep that promise if the optic is improperly installed. Will just have to wait and see, I think it may have arrived in the States but I still don’t have a definitive arrival date…
If there were other choices of optics or it supported a larger domed LED I would buy a second one for sure. There is very little room to improve/mod this one (which makes me a little sad cause half the fun for me is modding to make my own unique version)
contactcr, try modding the E07 with larger wires, maybe check to see if the FET can be swapped for a slightly better one… there could be some lumens in there hiding somewhere.
