I will sacrifice one to do a capacity test, I have a RC hobby charger, on what settings should I do the discharge test? What is the industry standard? 500mah? to what voltage? 2.5v?
If itās a 1450mAh cell, then 500ma is .3cā¦thatās good enough.
I donāt know the industry standard for testing uniform capacity but discharging down to 2.8 volts, the usual termination voltage of several chargers is I believe appropriate enough for āourā standards at least!
Itās now gone up to $ 7.20 !ā¦.13min to go as of this writingā¦for a new code at 7.20ā¦quick, what do you think of the quality of this Morpilot brand?
ā¦ā¦ Okā¦. I just checked Vipon & it does seem the code has expired. Butā¦ if you already had it in your cart & had applied the code, it might still work. It canāt hurt to try.
I just got 20 batts for $5.09 shipped
Use the check box on items page for additional 10% off before you put it into cart. Proceed to checkout and use the Vipon code.
The 20 pack 123A batts were $0.24each @ $4.80
You can only ad 1 item to cartā¦
Anyone still wanting more of these batts you can still get a 16 pack @ $4.00 or $0.25ea (plus tax if applicable)
with another 10% coupon code and vipon coupon at checkout.
@ Pennzyā¦ā¦ I canāt find the Vipon link for the one I got. . BUTā¦ I think I found an even better deal while I was looking. It says the Code will be available in about 2 & a half hours.
Iāll keep looking for a Vipon link to the one I got & post it if I find it.
Here is the link to what appears will be a better dealā¦ā¦
Just a little info for some of the members who just dropped in. Some of these vipon discounts only last for a few minutes some seem to last forever.
Usually the discounts that stack with amazon coupons are the quickest to expire.
I think it maybe the fact that the seller didnāt realize they were running
two coupons at the same time. That could be why they donāt last long, when the seller seeās a spike in orders and realizes what they sold the item for they
pull the plug. Just a guess, I donāt know for sure why.
If you want to get in on some of these vipon deals you have to be ready and fast to the draw.
