And it’s gone. Good luck getting the light. Got screwed on this fake deal before
*still there. Link is bad
It is not gone, just type search Convoy l6 and it is still there.
Just ordered. Still available.
Great price. I got one for about same via direct purchase from seller here.
Yeah… no. I can’t. Got Q8s coming out my bum, fairly unused L2s and an MT09R. Do I really need another light-howitzer?
A while ago I wouldda jumped on this, but now…
Great deal! I bought it for like 45 usd 1,5 year ago.
Now thinking of buying another one to mod.
It is even cheap as a host for this price
its not fake, deal is still running i see, for this price its insane no reason not to buy one atleast if havent already.
Pity the exchange rate is low and banggood apply the gay tax which kills the deal.
For similar price i would pick Fireflies E07 but far more nicer pocket light.
thanks for the link by the way,
thanks ordered one 5000k.
I have the black version…wonder why the silver one is never up for a bargain price…if it were, I’d snag another.
stupid firefox does have again security block everywhere
trying to buy on IE it went 17:00 and price changed to noarmal
Looks like it’s over.
Code AC18 should bring it down to $46
Got one with with SMO shipped.
i guess it doesnt sell as much as the black looking at reviews it has alot more then silver.
Does this have to take “button top” 26650? or both?
well, the cells do need to have contact with each other, my Liitokala’s didn’t work, so i solder blobbed them
The light uses springs on both sides, so button tops are not necessarily needed
Either will work on the driver end, it has a spring. But the cells must contact each other in the battery tube to create the series connection.
Personally, I use flattops & one of these Jaxman battery connectors….
HERE is a link to the ‘Battery Connector’ if you need it.
nice, awesome thanks. I might order me some. So, what’s the big difference between button top and flat top, other than the obvious. Is it the added resistance??? when do you know when you need either or?
@ mgracia85….
1. As long as the driver has a spring either should work.
2. If the batteries have to make a series connection they must touch positive to negative. If they don’t, either use buttontops, solder b(. )( .)b, or use the connector. Some people use magnets, I do not. To me that method sux.
3. Some battery carriers are designed to accept ‘button top’ batteries only due to reverse polarity protection constructed in the carrier. So you must use buttontops, correctly sized solder b(. )( .)bs, or remove the reverse polarity protection designed in the carrier.
4. Resistance between flat tops & button tops is negligible for my purposes.
5. The Battery Connector probably adds a bit of resistance too, but to me it is not enough to matter one way or the other.
Hope this helps……
