My dark gray is not rounded. Anyone with a clear have a good enough camera to show that edge? I know Dale will take his signature pics
Clear
Grey
best I can do
Wow more than I could have hoped for. You can even see the machining on the flats. Thanks for the pic i bet that makes a big difference in how it feels
I noticed the extra chamfering on the clear ano version when I saw vinh’s pic. Thanks for confirming this.
Max ramp should be under 50% power by default.
The default ramp ceiling is 120/150 for the dimming levels. Not sure how that correlates to output though, it would probably change a lot per LED/battery type/# of LEDs.
I get 8300 Turbo and 2830 max ramp.
I’d like to know if setting max ramp to 8300 lumens increases the brightness of Lighting mode
Pretty sure lightning mode utilizes the full DD capability and is not influenced by the ramp setting.
Shirnask, great pics, shows quite clearly that FF was listening and I, for one, love it!
Edit: Mine is at the local Post Office, scheduled for delivery tomorrow (Monday)
It’s a lot of fun, I’d love to see Acebeam implement lightning mode on the X70-GT.
I’d feel like The God of Light and Thor at the same time. Turning night to day or creating lightning.
I have Anduril on my 458 Ham’r (25,000 plus lumens) and it is, indeed, a lot of fun. All that’s missing is the thunder…
Time to add a speaker and fake thunder sounds synced to Lightning mode to the Ham’r? :smiling_imp:
Does fireflies have any plans to make big light?? Like the size of the acebeam x70gt with the 48 xhp 35 hi ?
Can the illuminated button be switched off?
At night I would like to only have the aux LEDs switched on.
And the button off…
Holy shot! That would be sweet! Maybe 48 White Flat 2mm at 1.5MCD would be a dream come true. Imagine using Anduril lightning mode. That will make you truly feel like Thor like Flashaholic said.
But I have a feeling they wouldn’t want to make something that expensive. At that price, people will be expecting perfection, which is unlikely to achieve for a light of this calibur, and some will be taking advantage of Paypal disputes to get free lights from them for minor imperfections so there’s too big of a risk to make such an expensive light. I hope I’m wrong and FF does have plans to make world record breaking lights at the top end.
Quick calc, 1.5 Mcd with a 1mm white flat would require a 10cm reflector, just one 18650 would do the job. The 2mm2 white flat would need a bigger reflector, and more than one battery would be most convenient.
And the button off…
Don’t think so but you can always have the illuminated button face away from you if it bothers you.
But I’m wishing for 60k+ lumens at 1.5MCD.
^so do I, but I’d be ok with the limited output if the light is kept lightweight and compact (I’m still in favor of the box format, batteries and electrical parts at the side of the reflector, led mounted directly on a finned heatsink).
And the button off…
Nope. Two of the four button LEDs are hardwired to power, and can’t be turned off without disconnecting power. The other two are controlled in sync with the aux LED board, so it can’t have one on while the other is off.
Tapping 3 times adds a 30 minute timer to candle mode, does 6 taps add an hour?
