What did you mod today?
9047 posts / 0 new
Tom E
Tom E's picture
Last seen: 6 min 56 sec ago
I'd go by DEL's 17 mm design here: https://oshpark.com/shared_projects/qsbLVgh0
He eliminates the least needed components, C2 and the 47 ohm in line to the FET gate, but kept in the 100K. I know he had a specific order of priority and definitely that 4.7 ohm guy before the diode was very important. Before DEL's design in of the 4.7, it was hit and miss whether a 25/45/85 would work or not. Richard at MtnE had a different approach that worked but DEL's design is better, as proved on the scope.
Ohh, fyi. The classic 8x7135 ATtiny13A driver design was out of spec for the 13A, but seemed to always work. The 25/45/85's turned out to be more finicky/sensitive, so that's why the 4.7 ohm is needed -- it should have been in the classic 13A 105C/105D boards all along.
Cereal_killer
Cereal_killer's picture
Last seen: 5 months 4 days ago
I think what I’ll do is net the two R4 pads together, that way if anything is wrong (doubtful but still…) I can cut the trace and solder the resistor in place later.
Edit:
djozz wrote:
… but then I saw that even in that small gap is a trace running.
Welp I’m an idiot…
My first thought was 0402’s but nixed that right away. better think again
chadvone
chadvone's picture
Last seen: 4 days 20 hours ago
Stuck a Lexel TA driver and a Luxeon V2 (3000k) into my Wowtac A2. Got to break in my Zeny soldering station.
pinkpanda3310
pinkpanda3310's picture
Last seen: 9 hours 11 min ago
Follow on …
MRsDNF
MRsDNF's picture
Last seen: 1 hour 30 min ago
Sweet. Love the centre. Did you make the adaptor?
pc_light
pc_light's picture
Last seen: 1 day 9 hours ago
Pinkpanda, nice stuff, will continue to what with excitment (and envy.)
Enjoyed your earlier 21700 light as well, hope you finally got some cells to power that beauty Wink
Reflowed a couple of SST-20 4000K 95+CRI into a CF8… now its warm and tight, the way I like it (but probably not as bright on Max.)
Seeking the light.
pinkpanda3310
Yeh, I made the adaptor because I didn’t want to use the body to hold the head for turning as it is a soft metal. The head is ti.
Thanks mate. Yeh, I got a couple cells eventually for the 21700 light. Looking back now that was a pretty simple build in comparison to this one.
Firelight2
Firelight2's picture
Last seen: 1 hour 51 min ago
Another day and another pocket destroyed by my Emisar D4. Oops! Even with my switch button trim I still had an accidental pocket activation. GRRRR.
To try to protect my remaining pants from the Emisar deep fry, this time I tried something new:
Flip up switch cover for Emisar D4.
  • The cover is made from 0.032” aluminum sheet for the main piece with 0.016” for the hinge.
  • The hinge pin is a piece of copper rod I had laying around bent into the shape of a staple.
  • I drilled 2 holes in the top of the head for the hinge pints. They aren’t very deep. Maybe 3 mm or so.
  • I used Fiberfix optical super glue to hold the whole thing together. I accidentally got some glue on the top of the switch boot. Looks unsightly but has no affect on operation so I’ll probably leave it.
  • The sides of the cover grip the sides of the head keeping the cover securly in position while closed.
  • I removed the anodizing from the aluminum head so it would match the aluminum cover. I also polished the bare aluminum on both the cover and the head.
  • When the cover is closed the switch cannot be depressed. The cover can be flipped up or down with a quick thumb action.
Hopefully this will protect my pants pockets from being burned.
TheOnlyDocc
TheOnlyDocc's picture
Last seen: 8 months 3 weeks ago
@pinkpanda3310
Really nice work! I envy you!!!!
A lathe could make things so much easier. But on the other hand it would end up in me spending much more hours now not only modding lights. No now i had to build them. Maybe i should be lucky to no longer having access to a lathe Big Smile
New WildTrail (former LuckySun) D80v2 Sale has Started http://budgetlightforum.com/node/66255
Wieselflinkpro
Wieselflinkpro's picture
Last seen: 4 hours 24 min ago
What is with the electronic lockout? Doesnt it have this?
The lack of anodisation is not verry good for such a flashlight at all.
contactcr
Last seen: 7 hours 19 min ago
I finally took a beam shot that included the Luxeon MZ build from the below quote in case anyone was curious, far right:
WB=5500K, ISO=125
contactcr wrote:
Last MZ for a while..
25 degree TIR
kiriba-ru copper single
H17Fx driver
I think this TIR is probably the most narrow that could be used with the MZ without a donut. I’m sure anything wider or more diffused would be even better but I’d rather use a LH351D/219C/XP-L for anything wider so I opted not to.
My first time using kiriba-ru’s copper single and it’s great as always. Machining is nice, threads fit perfect. Thin ring is buttery smooth
Also first time using H17Fx. I will probably use this again when i’m too impatient to wait for Lexel Smile
pinkpanda3310
Some work on the tail…
MascaratumB
MascaratumB's picture
Last seen: 4 min 19 sec ago
Shocked That’s looking pretty nice Wink
[REVIEWS] ACEBEAM: H20 / TK16 // AMUTORCH: S3 / S3 vs 219c / AM30 / AX1 / VG10 // BLITZWOLF: BW-ET1 // BRINYTE: T28 // DQG: AA Slim Ti // FIREFLIES: ROT66 GEN II // HC-LIGHTS: SS AAA // KLARUS: XT1C // LIVARNOLUX: 314791 // LUMINTOP: Tool AA V2.0 + Tool 25 // NITEFOX: UT20 / ES10K / K3 // ODEPRO: KL52 / B108 // OLIGHT: M2R Warrior // ON THE ROAD: M1 / i3 / M3 Pro // ROVYVON: A2 + A5R / E300S / A8 // SKILHUNT: M150 / M200 // SOFIRN: SF14 + SP10A / SP32A / SP10B // WUBEN: TO10R / E05 / T70 / E10 / TO50R / E19 // XTAR: PB2 Charger // Tricks: 1 / 2 / 3 / 4 / 5 / 6 / 7 / 8 // TIR: 1 / 2 // Others: Biscotti 3 + 1*7135 / Triple TIR w/ XP-G2 /// My Collection /// My Review's Blog (PT) /// OL Contest 2019 /// GIVEAWAY: 1 / 2
djozz
djozz's picture
Last seen: 1 min 50 sec ago
The ti D4 does lock out with tail unscrewed because the current path does not use the cap, it goes directly from the insulated tailboard to the battery tube.
KawiBoy1428
KawiBoy1428's picture
Last seen: 6 hours 2 min ago
I like this alot……. Love the tapered head! How much with shipping to the States when your done? Thumbs Up Edit: DIBS!
KB1428 “Live Life WOT
Cereal_killer
I replaced the quad with a triple luxeon V2 and polished the body of my Sinner Gen1 aluminum host. Went from ~40% optics loss with the downsized quad to a respectable 16% optics loss with the unmolested carlco triple. Using 22AWG wire and no spring bypass its running 2.6A/led and doing 2563 lemons, down 2.6A and up 313lm from when it was a quad!
I’ve got pcb’s coming for a new driver for it, once those get here and I take it apart again I’m going to try to find a better fitting O-ring for the lens, I think that may be robbing a lemon or two (it’ll also get 18AWG then and spring bypasses for unrestricted turbo since it’s a 3ch driver so it’ll have a regulated high mode).
I like this one, it looks like how it looked before polishing but it was taken today, I had dropped it into the snow, picked it up and blew it off and it steamed up from my breath, not actually a before pic at all.
MRsDNF
MRsDNF's picture
!{width:80%}https://lh3.googleusercontent.com/v62ByeraN6Mwm04FXUShmdLBrr0Ko2JnowzspF...!
Shipping is a lot cheaper to me in Australia. Smile
Are you enjoying the build pp?
KawiBoy1428
True…but I edited my post….
MRsDNF
MRsDNF's picture
Smile
Tom E
Tom E's picture
CK, nice mod! I've seen similar results with triples getting about the same as quads.
Ohhh - I received the first batch of 3 of the ZY-T11 clone OSHPark drivers and started on them. I cut down the small Blue BeCu springs, expanded the spring pads a bit (scraped off some surrounding soldermask). Also sanded down the edge of the board in front of the switch - not sure if it was necessary or not. Fitted the bare driver in - looks good so far. It's thicker than the stock driver but should be ok. In the past I've used the Maxtoch 26 mm MCPCB's and UCLp lenses from flashlightlens.com, but kind of drives up the cost of the mod. I've also used a copper slug of some sorts under the shelf, but the stock shelf isn't all that bad. These are old pics below:
KawiBoy1428
Woke up this Bored and Stroked Surefire 6P with a Copper (kiriba-ru) P60 Quad (hand fit to a press fit) pill using Lumileds V2 2×5000k by 2×6500k on a Mtn Quad mcpcb, Mtn. FET+1 Infineon FET driver Guppydrv3 with 18awg Leads. A Surefire Z59 modded KAN9 tail cap Fwd. click, pulling just over 18amps at the tail for 4500+lms. on a VTC5A.
I Left the shoulder inside battery tube, (instead of boring thru) to retain/stop the battery from slamming into the driver, one of Blue’s springs in the tail cap with 18awg bypass covers the 6P’s six.
Borofloat double AR coated glass lens in the Z44 head.
A Wolf in Sheep’s clothing if you will…I used to have a Pro Built ( Corky’s Competition) 498 cubic inch Bored/Stroked (under the hood) Dual Quad Olds 442 in primer that was the same way…. Wink
Scallywag
Scallywag's picture
Last seen: 19 hours 20 min ago
djozz wrote:
@Scallywag, I did that (but reflowed the V's on the stock board) and those 7 seconds are over 5000 lumen. You must love that! :D
Oh, I do... And it's a beautiful beam, too.
EDC Rotation: ZL SC62(w) | Jaxman E2L XP-G2 5A | Purple S2+ XPL-HI U6-3A | D4 w/ Luxeon V | RRT-01 | Purple FW3A, 4000K SST20
EagTac D25C Ti | DQG Slim AA Ti | Jaxman E3 | UF-T1 by CRX | Nitecore EX11.2
L6 XHP70.2 P2 4000K FET+7135 | Jaxman M8 | MF02 | Jaxman Z1 CULNM1.TG | Blue S2+ w/ ML Special
Unfinished: Supfire M6 3xXHP50.2, Sofirn C8F, Sofirn SP70
Others: Nitecore EC23 | Nebo Twyst | Streamlight ProTac 1AA | TerraLux LightStar 100
Tamagotchi
Tamagotchi's picture
Last seen: 11 months 4 weeks ago
Body: Nitecore HC33
LED: XHP50 90CRI 4500K
Driver: Caerus 1.7h
Lens: Carclo 10140
MRsDNF
MRsDNF's picture
Nice mod Tamagotchi. Do you have any more info on the driver?
Tamagotchi
Sorry I do not speak English.
Output 6V 2A
6 modes including moonlight and turbo
1 short click – on/off
press and hold to switch modes
2 short click for Turbo
PID thermal regulated outputs (turbo and max)
Battery capacity indicator and battery protection
Chatika vas Paus
Last seen: 31 min 44 sec ago
It looks great. I think I found it: Project Caerus
djozz
djozz's picture
Some very high end mods up there from Kawi and Tamagotchi !
Wieselflinkpro
A similar driver is the H1-A: http://kaidomain.com/S026606-H1-A-20mm-3A-1-cell-1-Mode-or-5-Mode-Boost-...
I have seen somewhere a tutorial to use it as eSwitch driver. You have to remove the Capacitor and solder the switch wires on that points, i think.
Virisenox_
Virisenox_'s picture
ZozzV6 wrote:
The C8 with White flat:
How did you get that so perfectly centered? I have a C8 with a white flat and I can’t get it that good, and you’re even using an XM-L2 centering ring.
Reviewer for ThorFire, Olight, Sofirn, and others.
More active on Reddit: /u/Virisenox_
"I go hard."
- Zeroair
"Don't quote me on that."
- Zeroair
contactcr
Probably glued the centering ring
