Oopsie, had the last 2 pics labeled wrong -- fixed that.
Yeah, wonder why they did went with an OP. I'm sure there's loss's for throw. Based on the D4S specs, the best thrower LED seems to be the SST-20 at 5000K or little better at 6500K. The 3000K and 4000K's drop off quite a bit, but in the same % drop as does lumens.
Thanks for the pics! Good to see they changed that tailcap design, though it looks like it won't work well with 18650's because of the width and flatness of the protrusion. In mine, the spring inside the battery tube was stiff and relatively short, so there wasn't much margin to fit differing size batteries - not sure how the spring looks, and how it handles battery sizes now.
I liked the matte finish, maybe anodized, finish of the SS bezel before but least they stayed with SS. The OP vs. SMO - I'm ok with that, no one else seems to use OP in reflector triples so it makes it unique. Probably better looking beam though it cuts down on throw.
Just might have to order this SE model now - great price for the quality of this light.
Yea, depends on the cell wrap's overlap. I guess they narrowed the protrusion, not just filled it in, because mine was pretty wide (can't measure right now). 11 mm is still twice as wide as most spring tops. Again, it all depends on the spring inside that battery tube -- anyone have a measurement or pic? It's fairly easy to remove the top USB charging assembly -- I did it a while back. I dunno - for the NA40 (non SE), I had to use magnets to get my batts to work properly but no one else seemed to complain about it. Or I just like to whine and pick bout something...
Has anyone tested these 26980 batteries yet? 5mOhm sounds way too good to believe it. There are some offers on AliExpress but it would be nice to know who's the manufacturer. I don't think this one will fit into any charging bay of available chargers except for those magnetic cable-chargers like Olight UC.
