Keychain sized lights are rendered mostly obsolete by the introduction of smartphones with flashlight apps. I just have to draw a “V” shape on my locked smartphone to activate it.
Flashlight industry is at least 15 years behind of modern user interface technologies. No bluetooth/wifi, hardly any configuration or personalisation.
Two buttons next to each other to switch higher and lower make for a much better interface than a single side switch.
99.9% of owners who buy a “tactical” flashlight have never and will never be in a “tactical” situation.
Strike bezels on tactical lights are useless. If you are good enough to strike someone with that without getting knocked out you are already good enough to win the fight.
I don’t mind Turbo mode for only 30sec-1min… On all my lights i keep it at a level enough to see, and only raise it to Turbo when necessary. If I need more than a minute to see a target from a distance I probably have adult ADD…
IDK if this is a thread where we’re supposed to reply to other comments at all but…
in emitters like the Optisolis for example whites aand other colors are so accurate because there is good red rendering (+other parts of the spectrum in the correct proportions). If you have the yellow, green, part of blue, but very little red and deep blues like most low-CRI emitters white will not look correct and greens will be over-exposed or unnatural.
I’m not a tint junkie and I don’t really care about beam pattern too much.
I have lots of tints and some are nice when looking at my orchids, or other flowering plants, but tint isn’t the ‘end all be all’ for me.
As for beam pattern, I don’t much worry about that, as I use my lights to find stuff in the dark, or light the way. I have SWM V11Rs and M11Rs and they’re ‘ringy’ as all get out, but using them outside, I never notice that.
I understand that plenty of us are ‘white wall hunters,’ sitting on the couch with a bag of Cheetos, but that’s basically where it ends, for me at least.
I agree with a lot of this. Arduino and Raspberry Pi are so small now they could easily be implemented in medium to larger flashlights, with GUI programmability and control on a phone instead of blindly clicking and praying. Remote light operation is a huge plus especially if it’s mounted or on a tripod. A GoPro is infinitely smaller than a BLF GT yet that can take 4K60 video with image stabilization, and send a live feed to YouTube through your phone. The only big issue would be the aluminum housing of most flashlights - there needs to be some outer plastic for the antennae to work. I think a combination rocker/pushbutton would make a nice interface. Even a slider. And I agree with the strike bezel - if the strobe didn’t scare the perpetrator away, you won’t even get a chance to use that strike bezel… unless you happen to be a Navy Seal or MI5 or something…
I’m not against a light that has high CRI, just saying that if it does not also have a neutral CCT (to my eye somewhere around 5000) then it cannot make white look white. I don’t understand people who are so happy they have a 90+ CRI when the light is 3000K and makes a white wall look like someone threw orange juice all over it last week. 70CRI in 5000K will always look more natural to me, no matter how much a 3000K gives some people the warm fuzzies. I can ONLY appreciate high CRI if it is on top of neutral CCT, and don’t quite get how anyone can think otherwise.
Include me as one finding it difficult to understand the position of some posts.
Has this turned into a complaint thread ?
Are we still supposed to treat it as an unpopular opinion thread ?
Should there be a popular complaint thread ?
Agreed. Some fantastic unpopular opinion have been posted, though there may be a fine line between a unpopular opinion and a complaint that we should observe.
To add to the theme of the thread; I believe the Manker have the best UIs in the business.
The ‘always starts on lowest’ ramping UI from the first Emisar D4 prototypes (vers. 1) sent to RMM is a valuable model to avoid burned pockets, holsters, and damage to the retinas of unsuspecting innocents.
A short single press is not the only way to access turbo flamethrower or memory modes.
1-click to turn on, click again to change mode and hold to turn off isn't that bad as long as you only have to hold less than 1 second.
Flashlights in pure white look absolutely beautiful, something like Led Lenser F1 White Edition's white not Haikelite or Emisar's white.
Flashlights with optic look more expensive than flashlights with reflector.
Best UI I have ever seen is on the Nitecore MT10A/MT10C. A tail switch to turn on, 2 side switch to change mode higher or lower with shortcut to lowest mode and highest mode right from off without having parasitic drain from the e-switch working.
And finally, too floody flashlight is kind of useless. If you want a flood light, all you need is a diffuser or some tapes on the lens.
Andy Xie is an unsung hero.
Photons are not a Panacea.
(Understated lumens versus innovation and art.)
The market pressures eliminating Sunwayman from the available stock of the most popular flashaholic suppliers in the USA represent a step backwards in many regards.
Design and innovation, art and ‘understated’ conservative output claims have not had long legs.
Andy Xie is a production engineer and businessman with rare goals and talents.
Fortunately, from the beginning, the security of military purchases has provided income for artistic expression, keeping Andy’s Sunwayman in business.
I don’t get the hype about copper. Especially when I see green patina rot that looks like the light has been in a sunken greek tradeship for 2000 years. If I want my nice EDC light be a bit heavy, I will take Stainless Steel every time.
That being said, I proclaim the Thrunite T10S the best EDC light of all time.
