Are we talking about the 4 switch leds only or also the 12 main auxiliary leds in the front? I would imagine 16 leds total would be a pretty good drain.
Of course they also act like a battery indicator and can also shut themselves off if the battery voltage gets too low. Still, it seems like a twist for mechanical lockout is a good idea. I always mechanically lock out my lights when I’m not using them for more than a couple hours.
Oooops! On a PL47, 7 clicks, followed by 7 clicks turns off 2 of the 4 switch LED's and all the front AUX LED's - think the ROT66 works the same? My ROT66 was before the added AUX LED's.
I think it’s because of the low voltage warning the main auxiliary leds can give that they are wired up directly to the battery. The side switch lights are wired to the mcu which has regulated voltage (regulated on the 2S and 4S drivers, I’m not sure about the 3v drivers).
If you don’t mind losing the low voltage warning, I believe you can wire the aux led board to the side switch lights in parallel. Then the 7 clicks will control them both. I think 2 of the 4 side switch lights are still wired direct. Those can be disconnected or wired in to the others.
You can always turn them off with a twist. Mechanical style. All e-switch lights have some amount of parasitic drain. The Thorfire S70S has a crazy high 4,430 micro amp drain and it only has a single green led switch light. Compare that to the Q8 at 123 microamps. So it’s best to always cut the power.
One possible option for turning off aux LED’s is a component called a bistable or latching reed switch. Some of those I’m finding spec sheets for are very small - about the size of a 1/4W resistor - but I’m not sure where to buy them.
It might be possible to wire one in series with the aux LED board, and if it can be located close to the lens, trigger it with a neodymium magnet.
Normal reed switches are momentary. Latching reed switches switch on or off depending on the direction of the magnetic field.
On Fireflies lights so far, the buttons have 4 LEDs:
2 LEDs: always on, hardwired to power
2 LEDs: wired to a MCU pin so the MCU can turn them on and off
… and the aux LED boards have more variety:
Always on, hardwired to power
Wired to a MCU pin so the MCU can turn them on and off
Wired to power and a MCU pin, so the MCU can tell it to turn on and off but it still gets power direct from the battery
The 2 controllable button LEDs could have low and high modes, but this option isn’t compiled into the firmware because Fireflies didn’t want it. It doesn’t really make much sense when the other 2 are always on.
The aux LED boards typically have potentiometers to manually adjust the brightness, and the adjustment range tends to go from ~200 uA to ~800 uA. However, the pots are physically inaccessible on some lights, like the PL47.
The aux LED boards also typically have their own built-in LVP:
Above ~3.3V: outer rings are lit up
~3.0V to ~3.3V: inner ring it up
Below ~3.0V: aux LEDs off
Because of the way this LVP function is implemented, and the way it attempts to regulate aux LED brightness, the aux LED boards cannot do low and high modes controlled by the MCU.
There is no LVP on the 2 hardwired button LEDs. Also, there is not yet any LVP in Anduril while it’s asleep, so if voltage drops too far during standby it won’t respond until after the user wakes it up. But the aux LED board LVP is always active, which helps a lot since it draws about 98% of the power during standby.
I must say that I’m very disappointed with ROT66. If I bought it in local store, I will return it.
The problem is that returning FL to China is too expensive. So I’m stuck with this FL.
Can you calculate, measure how much power do all blue leds and swich leds consume together?
It can be measured with a common DMM / multimeter.
However, that may not be necessary because measurements have already been posted. It should have a standby time of 1.5 years to 9 years with the aux LEDs on all the time, depending on how you configure them. It can also be turned off entirely by using physical lock-out.
Why does this change your evaluation from “I love it” to “I’m very disappointed and want to return it”? It seems like a large reaction to a small problem.
I still love it but after I found out that small leds can not be turned OFF, I’m not so happy anymore.
This is my frist FL which has leds always ON and I don’t like this feature.
What is physical lock-out?
Can you please explain?
And if I understand correctly, internals can be rewired so that leds will not be on 24/7.
But for this procedure you must be expert in custom DIY projects. I never opened any FL.
The Aux-LEDs on the ROT66 are an afterthought.
The D4S had it first and ROT66 was always out. Then Lexel designed an Ledboard based on a lit tailswitch.
I don’t get all the angst about the aux LEDs draining the battery in these lights. Charge your batteries once a quarter and your flashlight is probably 3/4 full or so, no?
All I read is you shouldn’t just let batteries sit in there for months on end anyhow.
Not wanting them on “just because” - that I understand a little more. Mine is tucked away a bit so the “purple haze” causes no problems.
Or should have I posted in the unpopular opinion thread???
On my nightstand, the PL47 throws some decent amt of light when your eyes are fully adjusted to darkness, so I can see for that reason not to want the front AUX LED's on, but can always give it a twist. It would just be more practical for all if controlled from firmware.
