Yes it does. Thanks teacher. no pun intended
use good cells like keeppower which are protected and raised flat tops they will make contact, or unprotected like efest both works its up to you, i wouldnt use that connector really might aswell buy the batteries with built in top instead.
Good, glad it did help gracia85 & your welcome, it was my pleasure!! . :+1:
I have a bunch of Liitokala 26650’s I use. I did not want to use magnets (that sux… ) and really did not want to solder b(. )( .)b them because about half of them just happen to work in series.
Soooo, I just use the Jaxman Battery Connector when need be.
It works great!!! . :+1:
How easy is it to swap out the OP reflector on the L6 for a SMO? If so, what are the steps? Can someone who has never modded a light do this?
Well, that is very easy.
Just unscrew the bezel, take out the reflector, (check if you dont accidently remove the gasket around the led), insert new reflector, screw on the bezel, done!
ok awesome! thanks a bunch
My order is still at the “processing stage”, after 6 days.
Anyone else having this issue?
what tint did u buy ? it says on 2 “Processing time:Expected on January 28, 2019”…
AH, that would be the problem then. Thanx.
I guess I just assumed they were clearing existing stock at this price.
classic banggood things as usual!
Expected Shipping Date:
2019-01-24 04:45:42
You can also visit the ShockLi store at AliExpress, where you can get button top variant of the ShockLi 5500mAh unprotected 20A continuous current battery - which means far more runtime at the maximum designated output compared to when it is used with the older Keeppower protected batteries.
i use keeppower 6000mah they fit and provide longest runtime, no need for 20a batteries really in this light.
I just got an email from banggood apologising for the delay and giving me the option to request a refund.
I got something similar - along the lines of “choose your option”, but the only choice available is refund, so I am not responding.
I will be very upset if they cancel and refund, this happened with my last Banggood order as well.
I hope I will not get such email.
I want L6, not refund.
Maybe they have wrong price in system and now they will refund all orders.
Not good.
Kind regards
they should honor the price since it was a legit promotion ? but perhaps they got swamped with orders more then they had units or something that can explain some lights will not ship out sadly i dont know ?
I contacted the online chat to make sure the order is not cancelled, this is their response, I got the transcript emailed to me as evidence in case they do still cancel:-
Reagan 03:28:12 pm
let me check it now
Zulumoose 03:28:22 pm
I want to make sure the order is NOT cancelled. I want to wait for it.
Reagan 03:29:11 pm
okay, I see
wait a moment please
we will leave a note in the order , and it won’t be cancelled
Zulumoose 03:35:06 pm
ok thank you, my last order was cancelled against my wishes so I am worried the same happens
Reagan 03:35:47 pm
please do not worry
My L6 have status “Shipped”
I received the out of stock email a few hours ago
The same - Out of stock - I think that they are trying to persuade buyers to cancel their orders.
Last time my light was also “out of sock” and it was shipped 2 days after I’ve chose “I’ll wait”
