12695 posts / 0 new
iamlucky13
Last seen: 1 day 21 hours ago
It definitely seems worth trying a swap, given the low cost a triple board with SST-20’s can be had for. I’m hoping to compare it LH351D’s and SST-20’s and decide which I like better.
dotBLF
Last seen: 12 hours 59 min ago
Hi I would like to sign up for the buy if I still can. I’m in for an XP-L HI and a Samsung LHD!
Thanks!!
zak.wilson
Last seen: 11 hours 33 min ago
I think the SST-20 is a great option for a future update. I will definitely put SST-20s in one of mine.
It wasn’t yet known to this community when voting on the emitters for the FW3A took place, and trying to add an additional option now would only delay production.
Ceilingbounce – flashlight testing and runtime graphs for Android
BlueSwordM
BlueSwordM's picture
Last seen: 3 hours 26 min ago
The SST-20s 4000k are easier to get than the LH351Ds.
So unless the LH351Ds are of a good chromacity bin, going with SST-20s would be great for even better color rendition, and more throw.
JasonWW
JasonWW's picture
Last seen: 1 hour 47 min ago
Why would they give more throw?
BlueSwordM
Much smaller die area than the LH351D, and even optical emission area is smaller than the XP-L HI.
JasonWW
JasonWW's picture
So they are also less bright?
BlueSwordM
@JasonWW
Q2 tint bin LH351D currently available: 340 lumens at 1050mA(minimum)
J5 tint bin SST-20 4000k(highest one available): 279lm at 1000mA, 292lm at 1050mA(minimum)
So, with the current Q2 tint bin, the LH351D is 16,5% more efficient.
With the higher R2 tint bin being available for 4 reel orders: 360 lumens at 1050mA(minimum)
With the R2 tint bin, the LH351D is 23,5% more efficient than the SST-20.
So, yeah, less overall light will be emitted.
However, since this is an EDC light, the LH351D will be much more floody, and will require higher power levels to be usable outdoors.
The SST-20 would be a better overall choice in terms of usability.
DB Custom
DB Custom's picture
Last seen: 2 hours 31 min ago
That all sounds good on paper but my Ti/Cu scratch built EDC uses a Carclo quad optic with Samsung LH351D 80 CRI 5000K (U6 power bin) emitters and works quite nicely outdoors in the big wide open area’s we have here. It’s certainly no thrower, but it’s not lacking either, even run on an 18500 cell. Wink Beam profile is sweet, sans the Cree artifacts, with a defined fat hot spot that I’ve found very much to my liking.
BlueSwordM
At what level are you running the light Smile ?
cabfrank
Last seen: 7 hours 13 min ago
Max. Always Max. Wink
JasonWW
JasonWW's picture
BlueSwordM wrote:
@JasonWW
I like the LH351D because it gives nice NW color while still giving similar output to xpl or xml2.
So the SST-20 is a bit more similar in die size and output to the XP-G3 or 219C?
ToyKeeper
ToyKeeper's picture
Last seen: 50 min 58 sec ago
cabfrank wrote:
BlueSwordM wrote:
DB Custom wrote:
my Ti/Cu scratch built EDC uses a Carclo quad optic with Samsung LH351D 80 CRI 5000K (U6 power bin) emitters and works quite nicely … Beam profile is sweet, sans the Cree artifacts, with a defined fat hot spot that I’ve found very much to my liking.
From what I hear, it’s not always max. It’s frequently at lower levels, especially candle mode. A lot of people care about the tint in low modes, not just turbo. And unfortunately, a lot of emitters have their worst tints at low power levels. The color temperature and tint can shift quite a bit between a low mode and a high mode.
That’s why I didn’t like the SST-20 4000K 95CRI emitters I tried. The tint was okay on high modes, but I almost never use those… and at the lower levels I actually use, it was a long way from white.
KawiBoy1428
KawiBoy1428's picture
Last seen: 2 hours 33 min ago
My Triple SST-20 5000k isn’t any better, unless you like yellow, even in Turbo side by side with my XP-L HI 5000k triple (same) optics, the yellow stands out…
KB1428 “Live Life WOT
DB Custom
DB Custom's picture
I have my Ti/Cu DBC-04 set up to always start at the lowest level, I use it according to the need. Very seldom use Max, but sometimes. Max is around 3500 lumens on the 18500.
Level 1 or 2 get’s used in the house a lot, outside I seem to go straight to 4 or 5 out of 7.
zak.wilson
The SST-20s I got from Kaidomain (FB4 tint bin) are kind of yellow at low power and not really my favorite tint at any power level, but I just got done reviewing a light that came with an XP-G2 that I think was a 5S tint bin so I’ll take it.
I’d put more emphasis on getting FA4 or FA1 tint if I was buying a bunch of SST-20s than I would on flux bin. I have a suspicion that sometimes non-green tint and the highest flux bins are incompatible, because adding more 555nm has a strong tendency to increase lm/W, being the peak of human visual sensitivity.
Agro
Agro's picture
Last seen: 4 hours 1 min ago
BlueSwordM wrote:
@JasonWW
The peak current of FW3A won’t be 1.05A per emitter but significantly more. At higher currents the efficiency gap will be larger when comparing both LEDs at the same current.
Furthermore SST-20 actually has lower Vf than LH351D so it will draw more current. This will make the efficiency gap yet another bit larger, but it will reduce the brightness gap slightly.
DrinkingJar
I’m am interested in one, please add me to the list.
contactcr
Last seen: 4 min 5 sec ago
Agro wrote:
The peak current of FW3A won’t be 1.05A per emitter but significantly more. At higher currents the efficiency gap will be larger when comparing both LEDs at the same current. Furthermore SST-20 actually has lower Vf than LH351D so it will draw more current. This will make the efficiency gap yet another bit larger, but it will reduce the brightness gap slightly.
vF a lot closer than you think when comparing both in high CRI. The LH351D has much higher vF in the 70CRI model but the 90CRI is a different beast.
From maukka:
LH351D 5000K 90CRI @ 4A
3.4x vF
1189 lm
SST-20 4000K 95CRI @ 4A
864 lm
3.43 vF
diesel72
I would like one, in XPL-HI if I have a choice. If no choice, I’ll take whatever is made.
bluereidon
bluereidon's picture
Put me in the list for one with LH351D 4000K 90CRI emitter
pb00
I am interested in one as well please, thanks Smile
Smokecutter
Smokecutter's picture
Last seen: 4 days 2 hours ago
Interested. please add me. Thank you.
lotrbfme
lotrbfme's picture
Last seen: 1 hour 23 sec ago
Interested in the XPL HI
thank you!
olivedrab
olivedrab's picture
Last seen: 1 week 3 days ago
Put me down for one please. Thanks
scdaf
Last seen: 22 hours 15 min ago
Interested xpl hi. Thank you all for your efforts.
PreacherCasy
Last seen: 6 hours 11 min ago
I’m very interested in this!
dealgrabber2002
Last seen: 1 day 15 hours ago
Hello, I requested to be on the list for one on 1/7/19 but do not see my name. I just want to make sure I am in with this awesome group buy.
teacher
teacher's picture
Last seen: 8 min 51 sec ago
Give it some time. The list has not been updated yet. You should be in there when it is. Thumbs Up
dealgrabber2002
Thanks!
