So I have cleaned everything. Even went as far as to disassemble everything minus desoldering the wires, checked everything visually. Reassembled everything and it still does the same thing. With one cell it will turn on. The switch will be blue then blink red and then the whole light shuts off. Every once and a while it will turn on and ramp about half power before the light turns off in the same manner. (Switch blinks red and then powers off.) With 2 cells it does absolutely nothing. I mean nothing at all. Banggood has agreed to refund my money. May contact Mtn. Electronics and see if they have a new driver that may work. I’m guessing it’s the driver at this point. Not sure what else to try.
That seems a little strange. I don’t think any of my lights have done that. It might be likely if there is a big surge of current, like a light that turns on turbo when the tailcap is turned on. If the switch is on and you put the tailcap on there is the big current as the led lights up. I don’t have an SC04, but I don’t think it automatically turns on when the tail cap is installed. So it’s strange to me. I can’t say anything definitive about that spark.
Well Banggood refunded my money today. I contacted Mountain Electronics about a new driver and they were reluctant to help. Gave me an option which I may take just to have it work to some degree. Also sent a translated message to Haikelite but it may take a day or 2 if they even respond.
Mine didn’t work right out of the box either. After fooling with it I would get a flash the several quick flashes. I don’t know what that mode is or what. I ended up cleaning the contacts with IPA since there was plenty of grease to go around. Also, this isn’t regular Ramping IOS so it seems and wasn’t used to it’s simplified features, no batt check? But the switch isn’t super sensitive so it seems to need pretty positive inputs. I also found that it seemed pretty picky with what battery I used and button top 26650s were a must in 2 bat configuration vs flats with a magnet, for whatever reason.
I doubt Richard would be willing to custom make I driver just for this model flashlight. You would more than likely need to choose a driver that he already makes. It’s also possible that Lexel has a driver that might work. It seems unlikely it would still be able to operate on two different voltages, though. You probably need to choose either 3 Volt or 6 volt and then whatever diameter driver will fit.
Why would you think there is any relation? Haikelite tends to make their own user interfaces unless they specifically say they are running such and such UI version xx.
Told Richard I would be willing to sacrafise one. I would prefer it work with 2 cells. He did have one that may work but wasn’t sure how lo g it would last. It was because the LED’s were in a series I believe.
When it first comes on with one cell, they all light up. The power switch is blue. Within 10 seconds it begins blinking red, the LED’s flash 3 or 4 times and shuts down completely. The light will not work at all with 2 cells. Nothing.
That means either the MCPCBs are wired incorrectly, which should not be too hard to fix. The driver would see that with one cell, the LEDs can still be lit up without any problem.
With 2 cells, the driver sees that there is a case of overvoltage, and shuts down quickly.
So doable to fix for anyone with a soldering iron.
Or the driver is faulty, which would take a lot more time.
